Old 12-02-2004, 09:28 AM   #51 (permalink)
Member # 2818
cred05's Avatar
Drives: 2000 Audi S4
cred05 is an unknown quantity at this point
Default Re: Transfer Case Recall - IMPORTANT, Pleas Read!!!!
so from what i understand, if you paid to have it fixed, mitsubishi will reimburse you for it? I took mine to a shop, who sent it to kormex, costing me over $3000, will mitsu give me my money back?
SOLD the vr4 for an s4
13T's @ 15psi on Pump gas: 330HP/340TQ?
*DN Performance Y-Pipe*Magnacor Sparkplug Cables*NGK Irridium Spark Plugs(2 steps colder)*HKS Dual Sequential BOV
*3SX Lightweight Crank Pulley*Borla Catback*Test Pipe*ATR Downpipe*Fidanza Flywheel*RPS 6 puckClutch*Kormex Rebuilt Tranny*450cc Injectors*Apexi S-AFCII*Apexi Turbo Timer*Boost, and EGT Gauges*Stillen Brake Pads*Enkei RPO1 18X9*2 Nitto 555, 2 Pirelli PZero Nero 265/35/18*97 VR4 Brakes*GroundControl Coilovers*Drilled and slotted rotors*15psi*ProBoost MBC*FMIC, custom piping*3" GM MAS*MAFT*Dejon Tool Dual Intakes*Walbro 255 Fuel Pump*3SX Adjustable Control Arms*Fuel Rail Loop Adapter Kit*-6 Steel braided fuel lines*Aeromotive FPR*Battery Relocated in Trunk
cred05 is offline   Reply With Quote
Old 12-03-2004, 01:02 PM   #52 (permalink)
Krusher's Avatar
Krusher is an unknown quantity at this point
Yes, you can get your money back but if you do that then they wont replace your TC. I would rather get a new one but I still don't knw if the new ones are redesigned. I don't think they have really fixed the problem properly. It's just a new bandaid.
94 Stealth R/T TT Sold
2001 Honda RC51
Krusher is offline   Reply With Quote
Old 12-03-2004, 04:41 PM   #53 (permalink)
Member # 2818
cred05's Avatar
so your saying if i get my money back it would void the recall for me? So i would not be able to get it replaced for free next time it breaks?
Old 12-03-2004, 06:24 PM   #54 (permalink)
Krusher's Avatar
I think that's how it works. Because you already had it replaced and they are paying for that replacement they will not replace it again. You would have to ask them about that though.
Old 12-04-2004, 04:49 PM   #55 (permalink)
18_SSX's Avatar
Drives: his girlfriend mad
Trader Rating: (14)
18_SSX is an unknown quantity at this point
WELL, SO WHERE DO WE COMPLAIN? i HAD MY tc INSPECTED AND NO LEAKS. BUT IF DESIGN IS FAULTY, THEN I DEFFINITELY WANT TO GET IT REPLACED/
Sold: 1995 3000gt vr4 with dr800's and other pimp sh$t
18_SSX is offline   Reply With Quote
Old 12-05-2004, 03:10 PM   #56 (permalink)
SM-4's Avatar
Drives: Mazdaspeed6
SM-4 is an unknown quantity at this point
This still isn't clear to me. I had my car checked out at the dealer for the recall and it checked out OK. Now if my TC locks up, breaks, cracks or whatever I can still take it in to be replaced under the recall? What if it keeps breaking does the recall still cover it?
SM-4 is offline   Reply With Quote
Old 12-05-2004, 10:21 PM   #57 (permalink)
18_SSX's Avatar
Trader Rating: (14)
my understanding is that once the dealer inspeacted the TC and everything checks out fine, then they will not replace the TC if something happens in 3 months. I used to have a TC recall in my carfax report but after I took the car there, the recall notice was removed and it said that the car was inspected.
Old 12-08-2004, 07:14 AM   #58 (permalink)
I've been here way too long
Drives: 91 vr4
Trader Rating: (61)
walek is an unknown quantity at this point
Hello, i just went to dealership in elgin, il and they isnpected it OK. but the guy that was a manager was fuckin jackass, he was like : no we just order kits with new seals, we dont replace them. Im like what if it is broken. Well we dont know so far. ok then just replace the seals if it looks ok. At least nothing was breaking already
walek is offline   Reply With Quote
Old 12-08-2004, 09:53 AM   #59 (permalink)
Krusher's Avatar
They will make it hard for you becasue it's an expensive fix but if you have any problems with it after the recall is done then call Transport Canada or the NHTSA. If enough people have problems after the recall is done they will have to do it again.
Old 12-09-2004, 11:03 AM   #60 (permalink)
Mod O' Day Pron
Sean Johnson's Avatar
Drives: 99 C5
Trader Rating: (13)
Sean Johnson Level 7Sean Johnson Level 7Sean Johnson Level 7Sean Johnson Level 7Sean Johnson Level 7Sean Johnson Level 7Sean Johnson Level 7Sean Johnson Level 7
What's the matter guys - Don't want to read the 70 page orig t-case thread
If the dealer runs your vin number and it comes back the the recall has been performed they are obligated to fix it again. It's the dealers choice. In my case, they chose to fix it again, more than a year after I had the recall performed.
SJ
Sean Johnson is offline   Reply With Quote
