Old 01-05-2007, 08:32 PM   #161 (permalink)
Forum user
CheapStealth's Avatar
CheapStealth is an unknown quantity at this point
Default Re: Transfer Case Recall - IMPORTANT, Pleas Read!!!!
I had the recall done about a month ago. 1991 Stealth they pulled it apart resealed it and gave me the keys. They also said if it leaks again bring it back and they will talk about a replacement.
1991 Dodge Stealth R/T T/T
234,000 miles and not going strong....For sale needs a bearing...
CheapStealth is offline   Reply With Quote
Old 01-05-2007, 08:46 PM   #162 (permalink)
est. sept, 2000
91vr4n00maxima's Avatar
Drives: slow 97 VR4
91vr4n00maxima Level 791vr4n00maxima Level 791vr4n00maxima Level 791vr4n00maxima Level 791vr4n00maxima Level 791vr4n00maxima Level 791vr4n00maxima Level 791vr4n00maxima Level 791vr4n00maxima Level 791vr4n00maxima Level 7
Originally Posted by Thourun
Ut ohh better get that done lol. Will they charge me anything? How many hours should it take?
Edit: I'm realy wondering now how I thought I could have had it done allready, wierd... Maybe I shouldent smoke so much.
just check it to see if its leaking. if its not keep an eye on it. ive seen too many go in not leaking and then come out with a leak. dealer says fuck off. its been done. not my problem.
every once in a while you find a good dealer who knows better and will take care of it if it leaks again.
97 VR4 12.417@111.16 9b time. whats next?
95 mark viii. 14.35@98
03 cobra vert. 4 mods=118mph traps
91 stealth TT. td05 18G, heads/cams, 3000lbs
91vr4n00maxima is offline   Reply With Quote
Old 01-05-2007, 10:27 PM   #163 (permalink)
Forum user
i was told that if it continued to leak they would replace the xcase. So essentailly they fix it till it stops leaking unless it caused by somethign other than the transfer case. Mabye i just have a good dealer.
Old 01-05-2007, 10:40 PM   #164 (permalink)
est. sept, 2000
Drives: slow 97 VR4
yes you do have a good dealer. there have been many posts about this and then being refused service after it locked up or started leaking after the recall.
Old 01-11-2007, 01:48 PM   #165 (permalink)
JBrdr
Drives: 3000gt VR4
jbrdr is an unknown quantity at this point
So i just bought a vr4... lucky me i couldnt make it the 15 miles home from the dealership that i bought it from b4 the TRANSFER CASE blew. This of course was a lil scary seeing as i was on the highway!
The dealership quoted me 2500 but was willing to do halfsies on it since i just bought the stupid thing.
After doing some research i called MitsuAmerica; they told me that the TC was replaced under recall in 03, and if the part busted again it was not under the 12 month/12000 mile warranty and that they could not replace it again.?!?!
Other guys on this site have said that they have had theirs replaced multiple times by the dealership....
SUGGESTIONS?????
-also posted in the NEWB section-
jbrdr is offline   Reply With Quote
Old 02-27-2007, 07:32 PM   #166 (permalink)
Mean Green's Avatar
Mean Green is an unknown quantity at this point
Im catching hell from the dealerships around Atlanta Area. My TC IS leaking and starting to whine a little. I have called and called but they say it came into service in 03' and that they have no responsibility with it anymore. They only did a visual inspection of the TC and didnt re-seal it or replace it.
What should I do now?
1993 Panama Green VR4 - Bronze TE-37's with Nitto NT555's - XTD Stage 4 clutch - Pioneer AVIC-D2 - KYB GR2's - 10" MTX sub with 250watt MTX amp - Dejon "Y" Pipe - Blitz BOV - Optima Red Top - More mods comming soon!
Mean Green is offline   Reply With Quote
Old 03-01-2007, 12:53 PM   #167 (permalink)
HoW FAST is fast?
bxdiamante's Avatar
Drives: real slo (potholes!)
bxdiamante is an unknown quantity at this point
I am having the same problem, dealer only wants to reseal it. I told them that there was a service done to the transfer case in 93, but they dont see it on the warranty history, so they wont change the transfer case, but for some reason mitsu headquarters sees it in theres. And to top it off it was leaking , hope everything comes out ok ill let you guys know.
bxdiamante is offline   Reply With Quote
Old 03-03-2007, 03:35 PM   #168 (permalink)
HoW FAST is fast?
bxdiamante's Avatar
Got the car back, I actually picked it up after the dealership closed(heavy traffic on the highway, flooding and stuff). I looked under and it looked clean, so this morning I look under and guess what, I see drops, I told myself I knew this was gonna happen I knew it, I called the dealership, but everyone but one service advisor left. She told me call monday. I hope they dont give me bullshit about, no warranty or whatever. They better not argue when I say I need a new transfer case. urrrrrrrrrrgh so mad!!!!
Old 03-14-2007, 08:44 AM   #169 (permalink)
jfdr6911's Avatar
Drives: 1996 3000GT VR-4
jfdr6911 is an unknown quantity at this point
just took mine to mitsu, i heard what sounded like a tire whine in all gears at any speed and felt a slight shutter in the rear tires 1mph befor stop. Im guessing its my TC cause my car didnt whine before just recently. Hopefully they'll give me a new one but my ? is, Has anyone on this site actually gotten a new tc. I just glanced over the post so dont burn me if i didnt catch it, i was just curiouse. Ill keep u posted on what happens with mine
jfdr6911 is offline   Reply With Quote
Old 03-22-2007, 01:13 PM   #170 (permalink)
Drives: Stealth RT/TT
Hocky is an unknown quantity at this point
I dropped my car off today and they said they are replacing the TC, but none are available anywhere in the country and they're out of production. They placed an order but said they have no idea when/if they're going to get one.... they'd better, because mine is whining pretty well and I am going to be pissed if it locks up on me. Anyone else heard this? Any idea what kind of wait time I might be looking at?
Like a Mazda is supposed to be: Slow and broken.
Hocky is offline   Reply With Quote
