Hey everyone! Ok, so hopefully all of you are aware of the recall that was sent out regarding the transfer case on the 92-99 VR-4 and 92-96 R/T TT. I have decided to do some research on this issue, as the recall, to me, looks to be woefully inadequate. This is what I have found so far.
First. I called Diamler-Chrysler (mine being a Stealth) and found out that the unit they would replace the old TC with is a new design that is supposed to rectify the problems with the old one. However, as the bullitin says, they will only replace the unit on your car if the old one is damaged. I wasnt satisfied with that because of the potential safety hazzard that having the TC lock up on you presents. Sooooo.......
Second. I called the NHTSA about the recall. Since the recall, according to D-C was approved by them. I discovered that it is my RIGT to have the old unit replaced regardless of condition due to the safety risk. The gentleman there said I should call the dealer, and if they refused to replace the TC, I should contact the FTC and report the dealership.
Third. Ok, so I called the and asked them about it. Sure enough, the absolutely refused to do replace the TC without evidence that it is damaged. BTW, if you live in So Cal, NEVER go to Dodge World in Torrance for ANYTHING. They are HORRIBLE. Anyway, they told me that if I got authorization from D-C, then they would replace it regardless of condition. So......
Fourth. I called D-C again and mentioned that I had talked to the FTC and NHTSA and I got the same thing. They will only do the recall as specified on the notice. There is also no one there who could authorize such a thing, nor did they have the contact info of someone who could. Anyone see a pattern forming here???
OK, so here is the deal. I need everyone's help. We need to have all of the TCs replaced, regardless of condition due to the safety hazzard that the Fed is well aware of. Everyone please call D-C or Mitsu and discuss this with them. Also, everyone NEEDS to register a complaint against both companies with the FTC in order for the Federal Government to get more involved. DONT let Mitsu or D-C push us around!!!!! I dont want to hear about someone getting killed because their TC failed at high speed and they plowed into a school bus. Everyone please add your thoughts and comments. Good Luck......
Re: Transfer Case Recall - IMPORTANT, Pleas Read!!!!
Originally posted by Jiveslug However, as the bullitin says, they will only replace the unit on your car if the old one is damaged
What bulletin are you talking about? On the "recall notice" card i got in the mail it says " Your '91 year vehicle is in need of correction to assure its continued safe operation"
Tell your dealership there is a reason its called a RECALL and i can fax you a copy or give you the number of the dealership i got my recall notice from. Its in Dallas Tx though
If you havent already seen , heres what it looks like:
My transfer case failed as a result of a leak or inadequate seal. As a result my output shaft on my transmission went bad along with the transfer case. I had to replace both and paid out 4800.00. They say on the recall notification that if i already paid for service in regard to the recall parts then to conatct them for a reimbursement. Did I read that right. A REIMBURSEMENT!!!! Yeee haaa Yippy yi Yay. Must be my lucky day.
The VR4god has spoken......
1992 VR4 (Red)* K & N * NGK double platinum Plugs .032/Magnecore KV85 wires* Gutted precats* Blitz DS BC *18" SSR GT1 wheels* Falken Tires Z+ Rated Tires* Black Leather Interior * Glass Top* Tinted windows * Many tickets* Speedbleeders* RPS Street Disc (SHIT) Now back to factory OEM* RPS 11 lb. Flywheel (SHIT) old one fell apart and RPS wont replace it under warranty as they claim.* Kenwood /JL Audio /Rockford Fosgate sound system* New Short block and rebuilt heads with 3rd Gen lifters as of 8-10-06* 15 G Turbos* Stock injectors right now.*Greddy Type S BOV * Borla Exhaust * Intrax Springs * PST 2 piece driveline * Slotted & crossdrilled Brake rotors * Walbro 255 Fuel Pump (hotwired) * EK2 Downpipe ....
Ok, here is the BS. Good and Bad. BAD NEWS FIRST, the service mgr. tells me that they are going to order a new seal kit, because as he understands this recall, it's the "seals" that are faulty and "not the TC itself." A NEW BULLETIN IS OUT WHICH STATES THAT THEY HAVE TO TAKE THE TC APART AND INSPECT IT, AND IF DAMAGED THEY HAVE TO GET APPROVAL FROM TECHLINE TO GET A NEW TC. FOR NOW, THE NEW SEAL KIT HAS IMPROVED SPRINGS AND WHATEVER ELSE IS INVOLVED.
THE GOOD NEWS, there's also a recall on the front brake lines, they've been known to crack, so I'll get new ones for the bubble(sorry if you already know this). That's good! Mr. Mechanic, tells me that its a foolish recall because the trannies leak worst of all, and that the method behind the is recall makes no sense. If he had it his way, replace it with the New TC and call it a day.
So, without making a scene I politely say, "Ok, but if when you remove the TC and find that there is damage inside, will you then replace the TC?" Yes. Right now they are treating this problem as a "rebuild" because they feel its just a seal problem.
What I need to know is the part #s for the seals in a 94 3000.
For now, I have to wait until the parts come in. The downside is that if the TC reveals and internal problem, then my car will be tied up for ???time until they can locate a new TC
my engine is currently out along with the tranny and t-case. upon my inspection, i've noticed the input shaft and sleeve are both rusted. the input shaft is worn where the teeth look like triangles rather than rectangles. i'm not positive, but i'm pretty sure both of these were caused as a result of my t-case leaking. now, when i put my engine back in the car, obviously i'm gonna refill all the fluids.
are they gonna assume my t-case isn't leaking because it's full??
should i not "fill" it up all the way??
should i tell them i inspected it myself, or will they possibly try to say it's rusted because i removed it??
if they agree to replace my seals or the whole assembly, should i tell them i think the rusted sleeve caused the damage to my output shaft?? do i have a strong argument there??
