#1 (permalink) |
Hi,
My transfer case and tranny are off the car for clutch replacement. To be on the safe side, I've already replaced tranny oil seals. Now I'd like to do the same for the transfer case. As far as I can see, it has only two seals: one where shaft from the tranny goes in, and, one where driveshaft connects. My question is about the first one. Can it be replaced from the outside? It appears to be sandwiched between transfer case and inner metal sleeve. Can I just pull it out, like driveshaft seal? Thanks, Sergey
94 3000GT VR4 (upgraded)
"Your 1994 Mitsubishi 3000GT VR-4 is one of 1650. There are 57 other cars that were made with both the same interior and exterior color. Exactly Identical - 8" For sale: 1. used A/C belt (10K on the belt) 2. Stock front and rear sway bars. 3. 3SX dual O2 simulator 4. Used 2'' couplers/reducers/hump hoses 5. Used stock flywheel |
#2 (permalink) |
kit part number MN156006
Input Spool Seal Seal for the drive shaft Fill and Drain Gaskets Side cover seal and mid case to front case seal for both 5 and 6 speeds price varys depending on where you get it my local dealer said that it wasn't a valid part number also their idiots because i ordered it from another place no problem http://www.trademotion.com/partlocat...24&catalogid=0 Total $41.68 shipped to me Use Search by factory part # MN156006 Kx
3000GT STEALTH CLUB of NEW YORK Last edited by Kx125kid : 12-18-2007 at 08:41 AM. |
#4 (permalink) |
The washer is to make sure you get the seal in the housing to the proper depth. (for the seal you have questions about) And yes you can just pry it out and pop a new one in. Be careful not to scratch any of the sealing surfaces. And be sure to get it far enough in there that the dust lip is past the tapered part of the sleeve.
~Ryan
92 Stealth R/T TT- Not exactly done- 93 RT TT- Not much of a car anymore. "This is a solution looking for a problem." - Not me |
#5 (permalink) |
oh sorry also
i forgot to add that some places will charge about 30 for the seal at least my stealership tried that so my point was that i would buy the kit just incase and yes it can be done like mustgofaster said kx |
#6 (permalink) |
I got my seals from Oriellys Auto Parts for 15.00$ total for the input and output shaft seals.
1993 Panama Green VR4 - Cream interior - Black TE-37's with Nitto NT555's - XTD Stage 4 clutch - Kenwood headunit - KYB GR2's - 2 Infinity Baselinks - Infinity door and rear speakers - Dejon "Y" Pipe - Blitz BOV - Optima Red Top - Maximal Solid Mounts - Brass shift bushings - 14psi - restoring the car one mod at a time.
**Also parting out a 91 TT with 57,XXX original miles with blown motor. Pm me for details** |
#7 (permalink) |
I tried to get various parts from my brother who works at Car Quest, and they can't get jack for parts for the AWD cars. I didn't try other places much yet.
That output shaft seal in the transmission has to be replaced from the INSIDE. You have to take the transmission apart to replace it. Or at least, thats the intended method of replacement. |
#8 (permalink) |
Never finished
if ur lookin to replace the side seal, I took the cover off, on the side, pulled the sleeve and bearing out and just hammered the old 1 out, put the new 1 in and put the sleeve back in and closed it up...took a half hour..
99 Chevy Silverado 2500
93 3000GT VR4 So far: 3sx TD05 E16g Turbo Kit, polished Greddy FMIC with IPS tdo5 extensions, AEM EMS, PTE 680cc, Poopra pump, 3sx pulley, MSD wires, NGK coppers, Maximal powdercoated valve covers, polished plenum, Tial Q bov, Hallman Pro RX MBC, Maximal solid mounts, Maximal test pipe, JIC catback, Tein s-techs, Mod-Express 8k HID, Nelson TC bracket, Fidanza flywheel, RPS Max street, Deft CF hood........1 sick ass driver!!!! |
#9 (permalink) | |
Black Beast Rebuild 94%
