Old 03-01-2006, 07:32 AM   #661 (permalink)
Mod O' Day Pron
Sean Johnson's Avatar
Drives: 99 C5
Trader Rating: (13)
Sean Johnson Level 7Sean Johnson Level 7Sean Johnson Level 7Sean Johnson Level 7Sean Johnson Level 7Sean Johnson Level 7Sean Johnson Level 7Sean Johnson Level 7Sean Johnson Level 7Sean Johnson Level 7Sean Johnson Level 7
Default Re: Transfer Case Officially Recalled
That's BS, they should be able to pull up your VIN number and see if the recall has been performed. If it has been, but the TC is still leaking, they are required to fix it again.
Sean Johnson is offline   Reply With Quote
Old 03-01-2006, 12:52 PM   #662 (permalink)
Vr4 Addict
Drives: 93 vr4
viva le greg Level 1viva le greg Level 1
well this is the scoop so far..i called a bunch of dealers in my area and the first guy told me that he couldn't find out if my car had got it done, so i called two more dealerships and talked to two different guys both tellin me that they would call me back about it. only one of them called, and fortunately for me this guy was cool about it and did some research and gave me this hotline number to call to see whether or not my car has got the recalls done. so i call the number up and this lady was able to tell me that yes there are recalls for my car and no my car has not been serviced for them.. she even gave me a number to the nearest dealer that would look at my car and possibly repair it under the recall order..
heres the number for the hotline in case any of you would like to call to check up on your car.. 1888-648-7820
viva le greg is offline   Reply With Quote
Old 03-01-2006, 01:07 PM   #663 (permalink)
Mod O' Day Pron
Drives: 99 C5
Trader Rating: (13)
Good deal, glad to hear that.
Old 03-03-2006, 02:32 PM   #664 (permalink)
Jr Tech
gd1996's Avatar
Drives: Slow ones
Trader Rating: (6)
gd1996 is an unknown quantity at this point
Thanks for the #, just picked one up and not sure if the recalls have been done... so wanted to check into it.
Joe B
92 Stealth RT TT sold...
94 Trans Am
68 Sport Satellite
70 challenger
gd1996 is offline   Reply With Quote
Old 04-07-2006, 08:18 PM   #665 (permalink)
3si #1390
david1 is an unknown quantity at this point
I had the transfer Case replaced under recall about a year and a half ago. The transfer case is whinning very loud now and the fluid has leaked out. You can actually see it leaking out one of the seams as soon as you pour the oil in. I read through the recall, but I don't see anything about replacing it everytime it leaks. Is it true that they will replace it again?
1992 dogde stealth Evo3 turbo,660 injector, 85 mass air flow and translator 2.1 ,water/methanol injection,
supar fuel pump, k@n air filter, greddy blow off valve, , ips front mount interccoler and pipes ,tires BFG KD d@n down pipe , no cats, blitz sbd-id, msd wires, cross drilled rotors.pst drive shaft ,msd, e2k TC bracket . lsd .spec 3+ clutch
Dr650 1/8 7.5 at 94mph 453HP 470 Torque
Evo3 1/8 7.3 at 98mph 559hp 514 Torque slipping cluch
david1 is offline   Reply With Quote
Old 04-09-2006, 04:39 PM   #666 (permalink)
3si #1390
http://www.3si.org/forum/showthread....7&page=1&pp=10
there is a crack
Old 04-10-2006, 06:48 AM   #667 (permalink)
Audiophobe is an unknown quantity at this point
I'm sure they're supposed to replace it if the new one fails. The question is will they replace it if the new one fails.
As with any dealings with the dealership, you go in confident, telling them that you deserve a new one and not asking if you deserve a new one.
No doubt there will be a battle.
93 VR4: 2006 Engine Rebuild/Port and Polished Heads, '99 Lifters, DR 500's, CFDS, TC Bracket, Custom Catback/DP w/precat elims, Unichip, EBC, 680cc injectors w/Denso/AEM fuel reg/Hotwired, H&R springs(-1")-new struts, SPEC 3/PLUS clutch w/Fidenza Flywheel(new), MAFT, Front/Rear strut bars, polished plenium and chrome engine dress, 18" chromies. Newer TC (recall but never had problem!) 60k tune with all new parts(redone during rebuild).
93 SL:
DP/ 3sX Lightened pulley, K&N intake w/ SuperMac Cold wall. SS Grey!(Died 2/07 Gone but not forgotten)
Audiophobe is offline   Reply With Quote
Old 04-24-2006, 05:18 PM   #668 (permalink)
I Love TOYS
AllEyezOnMyVR4's Avatar
Drives: all my toys
AllEyezOnMyVR4 is an unknown quantity at this point
hmm not sure if that will be quite as easy tho...bc if a recall was done and a brand new TC was installed, since that is a new TC there is NO RECALL on those. just the older ones. so the chances of getting a new one are slim. i think it would kind of being like a "lifetime warranty" on it. which isnt the case. i dont think they are required to replace the "recall" case after the fact bc that one is deemed safe by federal standards im assuming and whatever the problem was before has probably been remedied on the new one.
Driving Exotic
AllEyezOnMyVR4 is offline   Reply With Quote
Old 06-21-2006, 06:46 AM   #669 (permalink)
Vr4 Addict
Drives: 93 vr4
well update on all this when i went and brought my car to the dealership they thought the problems with my car were with just the clutch but ended up being in the transfer case too and YES they went ahead and replaced it with a brand new one under the recall...it worked for me so i say it can work for any of u who havent had it done
Old 06-21-2006, 07:18 AM   #670 (permalink)
Mod O' Day Pron
Drives: 99 C5
Trader Rating: (13)
Kick ass Greg. If you don't mind me asking, what state are you in.
