Old 04-17-2005, 03:17 PM   #641 (permalink)
mitsu_3000gtvr4 is an unknown quantity at this point
Default Re: Transfer Case Officially Recalled
hey my t case is screwed i dont suppose anyone would tell me the transfer case recall number and the details of it cause i dont have much time at all to look through 64 pages id really appreciate if someone could im this to me thanks a lot please help
mitsu_3000gtvr4 is offline   Reply With Quote
Old 04-17-2005, 09:39 PM   #642 (permalink)
Trader Rating: (6)
Mark Hindelang is an unknown quantity at this point
take it to a dealership, and they'll know what to do. i know i didn't help with the number, but they'll be able to give it to ya
GTPRO 368sx Turbos [ported and clipped 15 degrees]
GTPRO 368sx Aluminum FMIC and InterCooler Pipes
GTPRO TD04 Headers
Dynamic Racing Stage 3 Heads
Dynamic Racing Hi Rev Kit
AEM Stand Alone Engine Management System (EMS)
AEM 3.5bar MAP Sensor
AEM UEGO Single Channel WideBand 02 Sensor
AEM C2DI [Capacitive Discharge Ignition system]
AEM Air Fuel UEGO Display Gauge
ATR Full Exhaust System with Straight Pipe
APEX'i Oil Pressure Gauge
APEX'i Coolant Temp Gauge
APEX'i Fuel Pressure Gauge
APEX'i EGT Gauge
APEX'i Boost Gauge
APEX'i Actuator Valve Controller Type-R (AVCR)
Cusco Rear Strut
Carbon Fiber Hood
99 Front End
02 Eliminators
Custom Dual Filter Intake (speed density)
3SX Aluminum Radiator & Hi Flow fans
3Sx Aluminum Crank Pulley
3SX Stainless Steel Braided Brake Lines
IPO Dual Feed Fuel System
Poopra Fuel Pump hot wired
Blitz 720 Injectors
TIAL Blow Off Valve
Greddy Oil Catch Tank
Greddy Turbo Timer
Kevlar Timing Belt & New 60k
Custom 6 point Grounding Kit
Custom Steel braided Turbo coolant and oil lines
Solid Steel Motor Mounts
RPS Lightened Flywheel
Horsepowerfreaks 700+hp Race Clutch Kit
MSD 8.5mm Wires>
[Installed by Jeff W. MotorSports and Wayne K. MotorSports]
[ Tuned by TorqueFreaks.com and HorsepowerFreaks.com ]
Mark Hindelang is offline   Reply With Quote
Old 04-18-2005, 05:42 AM   #643 (permalink)
Mod O' Day Pron
Sean Johnson's Avatar
Drives: 99 C5
Trader Rating: (13)
Sean Johnson Level 7Sean Johnson Level 7Sean Johnson Level 7Sean Johnson Level 7Sean Johnson Level 7Sean Johnson Level 7Sean Johnson Level 7Sean Johnson Level 7Sean Johnson Level 7Sean Johnson Level 7Sean Johnson Level 7
Make : DODGE Model : STEALTH Year : 1991
Manufacturer : DAIMLERCHRYSLER CORPORATION
NHTSA CAMPAIGN ID Number : 93V033001 Recall Date : APR 02, 1993
Component: POWER TRAIN DRIVELINE
Potential Number Of Units Affected : 2700
Summary:
A CONDITION EXISTS THAT ALLOWS OIL TO LEAK FROM THE ALL WHEEL DRIVE TRANSFER CASE. LOW OIL LEVELS IN THE TRANSFER CASE CAN CAUSE BEARING DAMAGE AND FAILURE.
Consequence:
BEARING FAILURE IN THE TRANSFER CASE RESULTS INPOWER TRAIN LOCKUP WITHOUT PRIOR WARNING, WHILE THE VEHICLE IS AT HIGHWAY SPEED.THIS COULD CAUSE IN A LOSS OF VEHICLE CONTROL AND AN ACCIDENT.
Remedy:
INSTALL A C-RING TO TRANSFER CASE TO PREVENT OIL LEAKAGE, OR REPLACE TRANSFER CASE TO MAINTAIN SUFFICIENT OIL LEVELS IN THE TRANSFER CASE.
Notes:
SYSTEM: DRIVE TRAIN.VEHICLE DESCRIPTION: PASSENGER CARS; MODEL STEALTH RT TURBO.
Sean Johnson is offline   Reply With Quote
Old 04-19-2005, 07:28 AM   #644 (permalink)
Audiophobe is an unknown quantity at this point
Just bring it do the dealership. You donīt need a number. They absolutely have to check it anyway, and they further need to check if the car has had the recall done already so donīt worry about the number. But you do need to insist on a new TC and not a fix. Tell them that you hear whirling and grinding sounds and make it sound bad.
93 VR4: 2006 Engine Rebuild/Port and Polished Heads, '99 Lifters, DR 500's, CFDS, TC Bracket, Custom Catback/DP w/precat elims, Unichip, EBC, 680cc injectors w/Denso/AEM fuel reg/Hotwired, H&R springs(-1")-new struts, SPEC 3/PLUS clutch w/Fidenza Flywheel(new), MAFT, Front/Rear strut bars, polished plenium and chrome engine dress, 18" chromies. Newer TC (recall but never had problem!) 60k tune with all new parts(redone during rebuild).
93 SL:
DP/ 3sX Lightened pulley, K&N intake w/ SuperMac Cold wall. SS Grey!(Died 2/07 Gone but not forgotten)
Audiophobe is offline   Reply With Quote
Old 04-21-2005, 08:00 PM   #645 (permalink)
just another toy
Jason20_03's Avatar
Drives: 93 & 92 Vr4
Trader Rating: (14)
Jason20_03 is an unknown quantity at this point
does this only apply to stealths? or are vr4s included in the recall?
Jason20_03 is offline   Reply With Quote
Old 04-21-2005, 08:10 PM   #646 (permalink)
just another toy
Jason20_03's Avatar
Drives: 93 & 92 Vr4
Trader Rating: (14)
disregard message
Old 05-02-2005, 05:14 AM   #647 (permalink)
Mod O' Day Pron
Drives: 99 C5
Trader Rating: (13)
Originally Posted by Jason20_03
disregard message
I know it's a lot to read through.
Old 05-20-2005, 03:05 PM   #648 (permalink)
moeras's Avatar
Drives: Black 1995 VR-4
moeras is an unknown quantity at this point
Hello everybody.
I just got a '95 VR-4 last night.
Does this thread applies to me???
let me know so I can take a look.
Thanks,
-Erasmo
moeras is offline   Reply With Quote
Old 05-22-2005, 08:09 PM   #649 (permalink)
Drives: 92&93TT, 00 CamaroSS
Trader Rating: (7)
smokinstorm is an unknown quantity at this point
My 93TT is going in next week for a rebuild or replacement of the transfer case. They checked it and oil is literally pouring out of it. I talked to the mechanic and he told me that he'd do everything possible to get me a new unit but they were very strict on the replacement of it. Some gear or something has to be damaged in order for them to have to replace it. I'm going to try to slip him a 50 or something and have him chip one of the gears. I want a new transfer case, not my current one rebuilt.
smokinstorm is offline   Reply With Quote
Old 05-23-2005, 03:31 AM   #650 (permalink)
It is very important that you tell them that you hear a "whiring sound" and sometimes a grinding sound. The service rep "asked me" if I heard those sounds. I said no and he said "yes you did" (wink wink) and that garentteed me a new TC case.
The wierd thing is that I was told that it's the same TC case, that is, no improvements to eliminate or avaoid the problem from recurring. Is that true? And if it is true, if the problem recurs, is it still a warrantee issue, or one replacement and you're done?
