Old 05-12-2002, 07:13 PM   #51 (permalink)
It's like that
KingNothing's Avatar
KingNothing is an unknown quantity at this point
Default
Originally posted by ROD
I was under the impression that it is the synchros in our transmissions that are the most common problem with our cars. So if they recall the transfer case, that will only take care of the leaky TCs and reduce the risk of a lock up at highway speed. Unless they fix our trannies too, will they have solved our problem? I'm kinda confused as to what the transfer case involves and what the transmission involves.
The transfer case is a safety issue, the syncros aren't.
1993 Sandstone Gray Metallic VR-4
"Find the job you love and you won't have to work a day in your life." -Confucious
3SI Member #705
KingNothing is offline   Reply With Quote
Old 05-12-2002, 07:20 PM   #52 (permalink)
Corn Its whats for boost
Import Power's Avatar
Drives: Vicki Insane
Trader Rating: (217)
Default
And that is only if you let it drain out (which happens because the leak issue) and get dry. It can lock up and at high speeds is very dangerous.
AEM Factory Trained Tuner
91VR4-3.0L-Stock heads and Cams-770AWHP 747AWTQ 30psi E100 Daily Driver 10.57@136mph
T4 AWD 9.21 @ 154.98
T2 FWD 10.19 @ 140.31
T2-820FWHP 3.1L 27psi C16
NG09 Title Sponsor
3SX Performance
3SX Performance Service Email
Old 05-12-2002, 07:30 PM   #53 (permalink)
ROD
ROD's Avatar
ROD is an unknown quantity at this point
Default
So they won't even touch our trannies? I'm still assuming that most people's problems are the weak syncros.I've read over and over about this problem but have heard very little about the tc until now. Fixing the leak in the TC won't fix the tranny problem so we're back at square 1 if you ask me. I might as well start saving up to buy a rebuilt one from Kormex cuz it's my tranny, not my tc that's leaking and going bad. So much for getting my hopes up that Mitsu was going to fix my tranny problem. There goes $2000 . Oh well....anyone interested in a '94 VR-4 with a bad tranny? lol
ROD is offline   Reply With Quote
Old 05-12-2002, 07:59 PM   #54 (permalink)
Rice cop
91VR4Driver's Avatar
91VR4Driver is an unknown quantity at this point
Default
OK, i dont know if this has been anwsered or what.....i have a 1991 VR-4, and my transmission has 110,000(aoorox) on it and my transmission just went.....its at the transmission shop right now, and if the 91 was already recalled, what do i do? I DO NOT by any means have the money to get a new transmission, and this month, my car payment, and insurence payment are due.....
91 3000GT VR4
(Im back on the Road!)
few cosmetic upgrades -- snake eyes -- K&N FIPK -- Stillen DP -- Borla 3 inch exhaust -- Gutted cats -- 13G turbo upgrade -- HKS SSQV -- Hardpipe intakes -- Hardpipe intercooler pipes -- Nice aftermarket spark plug cover -- Chrome mistsu oil cap -- Centerforce Clutch -- Red Silicon Hoses -- Blitz DSBC -- Blitz FATT turbo timer -- Hks EGT -- Red underglow kit -- 450cc injectors -- Apexi S-AFC -- Skyline Fuel pump --
91VR4Driver is offline   Reply With Quote
Old 05-12-2002, 08:32 PM   #55 (permalink)
One Ring to Rule Them All
BlackLight's Avatar
Drives: 95 VR4, 02 RAM QUAD
BlackLight is an unknown quantity at this point
Default "OK, i dont know or care if this has been anwsered "
Good, then you dont care if I dont answer you.
Thanks, Matt
3Si Member #0548
BlackLight@Planetice.net
www.BlackLight.5u.com
90 Mits Eclipse Base:SOLD: -rolling stereo-
91 Mits Eclipse GSX:SOLD: -first "fast" car-
91 Eagle Talon TSI AWD :SOLD: with AT and LSD 61k miles!! Dam does it handle good for stock! Only mod is me in the driver's seat
1991 Stealth ES:SOLD: PowerStop cross drilled rotors, Accell 8.5 mm plug wires, Bosch Plat +4 plugs, Remanufactured engine, rebuilt tranny, Eibach springs, 18x8.5 Advanti racing Revo wheels, 265 35 Kuhmos in back, 245 40 Toyo's in front, serious stereo, Centerforce Dual Friction clutch, K&N Aircharger, no resonator.
94 RT TT, "Grayish Pearl White":SOLD: 13.024 first time ever on the track, Blitz DSBC, Blitz turbo timer, APEXI S-AFC, 450cc DSM injectors, Fidanza cam gears, Unorthadox UD Pulley, 3SX 12 puck clutch, Centerforce throwout bearing, Fidanza flywheel, Matrix intake, TurboXS RFL BOV, hotwired fuel pump, test pipe, executed pre-cats, 3SX motor and tranny mounts, Lo-tec 3 gauge pod, Autometer Ultra-Lite Boost, EGT, and Air Fuel ratio gauges, all fluids Redline except tranny, Xenon headlights, brights, and fog lights, Intrax , Revised lifters, new driveshaft carrier bearings, early 60k service, Yoko Tires, Optima Red top, rebuilt 6spd with Kormex 2nd gear syncro.
95 VR4 :SOLD: Panama Pearl Green Intrax, Jay's rear camber correction, Mitsu Specialties 4.5 intake adapter, ek2 test pipe, and the biggest K&N I could order! (Fits after some pushing & shoving!)
-=CURRENT=- 01 Corvette convertable Puter (Silver/gold) Stock and ohhh so fun
BlackLight is offline   Reply With Quote
Old 05-12-2002, 08:43 PM   #56 (permalink)
Registered User
Drives: 92 Stealth Turbo
Deman is an unknown quantity at this point
Angry Canadian Models Exempted???? WHY?
Did I read a thread correctly? Canadian models are exempted?
Please let me know
D
Enjoy the Ride...in AWD!
1992 Stealth Twin Turbo
Firestorm Red
Tan Leather
OBX 3" Stainless Downpipe with Custom 3" exhaust (quad tip) NOT installed
Blitz DSBC
Blitz BOV (to atmosphere)
Stillen Intake
3KGT Short Throw Shifter
Snake Eyes Mod (John M's mod)
Other modes of transportation:
1. 2005 Kawasaki Ninja 636 Pearl Magma Red
(362 lbs and 131hp!!!) NOW STOLEN!
2. 2005 Ford Focus ZX5 (POS for the winter)
"Some people are alive simply because it is illegal to kill them."
Deman is offline   Reply With Quote
Old 05-12-2002, 08:45 PM   #57 (permalink)
Rice cop
Default
Sorry, i was just a little mad after reading all that, and owning a 91 whos tranny is blown, and im in a hell of a bind here, and there is no mention of 91's getting fixed....
Old 05-12-2002, 09:18 PM   #58 (permalink)
VA Turbo
DrewVR4's Avatar
Drives: 97 VR4
DrewVR4 is an unknown quantity at this point
Default
91VR4Driver- I see you also have the picture of the girlfriend over the tachometer mod and the blown tranny mod, welcome to the club
1997 3000GT VR4
—[ 99 front end / 99 Sail Panels / CF Hood / GT Pro/Black Racing Pro N1 18x9 / Intrax Springs / Full ATR Exhaust / 3SX Control Arms / iRotors Brake Kit / Big Sound / K&N Filter / Apex'I Rev/Speed Meter / Autometer Boost + A/F ]—
Drew Berreth
c: 540-220-8185
DrewVR4 is offline   Reply With Quote
Old 05-12-2002, 09:27 PM   #59 (permalink)
Me Tarzan..u Jane
MeTrzan's Avatar
Drives: 95 R/T TT
MeTrzan is an unknown quantity at this point
Default
the 91's are not included due to being 10yrs old and already having a recall on it.....and the Trannines are not the subject it is the Transfer Case, if that locks up then your in for a scary ride....the grinding synchros is just a part of diving one of the Top Super cars. I have noticed when I changed the fluid in mine it usually keeps it from grinding when I shift for a while and I have done it 2 times in the year that I have had the car...
Rich
Passion Red '95 Stealth R/T TT
3Si # 802
Tag: RUQUIKR
More Pics and Mod List
"This year will go down in history. For the first time, a civilized nation has full gun registration. Our streets will be safer, our police more efficient, and the world will follow our lead into the future." - Adolf Hilter, 1935 -
MeTrzan is offline   Reply With Quote
Old 05-12-2002, 09:31 PM   #60 (permalink)
Hellfire Master
devilmanVISA's Avatar
Trader Rating: (22)
devilmanVISA is an unknown quantity at this point
Default
I can attest to the locked up transfer case four wheel shimmy mod being hellified. Been there done that, over a 25' embankment upside down. That is why I don't have a stealth anymore, but it paid for my VR4.
devilmanVISA
Who will survive and what will be left of them...
devilmanVISA is offline   Reply With Quote
