#581 (permalink) |
I am the king.
well, I took my car to a shop up in PA and noticed oil buildup under the TC, right around the seal. Called up a "local" mitsu stealership and was told that a visual inspection had been done and now I have to fight corporate to get it "fixed" WTF!
'06 Hayabusa LE (9" over) 164.3 RWHP 99.7 ftlbs *RIP* 8/30/07
should anyone want to get ahold of me: ![]() cell: 252.982.6404 |
#582 (permalink) |
I got my tc sealed by the dealership couple of months a go from mile high mits and now my input shaft is leaking. Does input shaft has anything to do with tc?
91 3000 Vr4, Red (FRIGGIN STOLEN)
Alba edge 17s chromes with z rate yokos, Main cat eliminated, Atr catback exhaust system, atr downpipe, dn y pipe, Greddy e-o1 boost controller, set@15psi, s-afc air/fuel controller, Warlbro 255 lph fuel pump, 3sx engine dress up kit with all the res caps, rps 6 puck clutch, stillen brake pads, race concept cross drilled rotors, blitz supersound blowoffvalve, hks dual intake, ngk wires, ngk spark plugs, panasonic cd player, infiniti speakers, viper alarm system, ichibahn shift knob, mobo shifter and ebrake boots, 3kgt short shifter,3kgt carbon fiber hood, midnight haze glow guages, custom katzskin leather upholstery, 2 guages pillar, air/ fuel, and boost , Gto rear garnish, tein s tech springs and kyb struts Future plans, Engine rebuild and dr5oos or dr 650r depending on the budget 1997 maxima se, light gold.(Sold) New ride 1991 Carcas red 3kgt vr4 with 44k, Bone stock (Sold) |
#583 (permalink) | |
Mod O' Day Pron
SJ
#584 (permalink) |
Paid Member
I'm waiting till I crack the case in half before I take mine in. I'll be damned if they're doing a reseal job.
Teamperformance - At first, I didn't like quality mitsu, and opted for Mile-High Mitsu, just based on what some local DSM owners had told me, but after going to mile high for a couple things in the past (oil pan reseal - did a shoddy job myself, and the brake line recall) I won't go back again, anymore, I'll only go to quality mitsu, been going there for oem parts for a while, if Tallahassee doesn't have them online, or I need it asap. If you can dodge the shady salesmen, their service department isn't too bad, compared to most. As for the input shaft... which shaft are we talking about here? The shaft that goes into the transfer case, or the one inside the transmission/bellhousing, that the clutch slides on? The shaft that leads into the transfer case would be a point of note - if it's leaking on the transfer case side, it may need to be resealed.
Joe D.
White 1990 Twin Turbo Z. JWT Pop, JWT Ecu, Borla catback (ugly), SBC i-D Boost Controller/Power Meter i-D, Xtec 5000k HIDs! 1993 3000GT VR-4. DR500 Turbos, RPS Flywheel, RPS Max Series Clutch, Supra Fuel Pump, Bypassed Fuel pump relay, 3SX Downpipe and Testpipe, Maximal Performance Solid Motor mounts, 132k miles, For Sale! PM or email! Will wrench for airfare to Japan. |
#585 (permalink) |
Mod O' Day Pron
Just remember that if you wait until the case breaks / cracks, you might be getting more than just the case replaced. As I personally know two people (One being my father) that when their case cracked & the fluid drained out, with no pre warning, both had their wheels lock up. My father was on a well traveled hwy, traveling 60 mph. Put the car into a spin. The other person was lucky, they were just traveling through a neighborhood.
Also, just because you'll have a nice new t-case, the teeth on your shaft are probably warn down, so don't really expect them to replace that. |
#586 (permalink) |
Paid Member
I know, it sounds bad, but I check up daily on the fluid level in the T-Case.
To be completely honest, that's only part of the reason I haven't taken it in. The other part of it is that in the past, most, if not all of the dealerships in Denver have either tried to screw me in the past, or are completely unable to keep their hands to themselves. After I took the car in to Mile High Mitsubishi for the brake recall, the car was overboosting. Hit 16-17psi, on a short run right when I pulled out of the dealership. Someone at that dealership had changed the settings on the EBC. Normal setting (blitz ebc) was Set: 55 Gain: 4. Was changed to 71 and 15, respectively. Plus, after working at a dealership for a few years myself, I've seen what can go on. Between parts/personal belongings stolen, all the way to sabotaging an engine. Anything from half of a lock washer in the valve cover, all the way to something as simple as vacuum hoses disconnected, or wires cut, and Joyriding customer's vehicles. If nothing else, I just don't want to let them touch my car, but I can't get the recall done without the transfer case on the car. Between that, and practically letting the case blow up, I'm not sure how I should handle the situation. |
#587 (permalink) |
Mod O' Day Pron
I totally understand your sutuation. When I went in for my t-case recall, shortly after my father's t-case failed, I sat there all day watching them from the corner of the bay. They bugged to take me to work & pick me up when they got done. Oh HELL no. Down side was my job was a bit pissed, but I'm like you, I don't trust those people at the dealerships. Dealerships are where mechanics go fresh outta school to get their first job. When they eventually get good, they leave to work for a privately owned place.
Just be careful. I check my case on occation, not everyday. Even though I had the recall completed. I get worried, because a month after I had that work done, I popped the fill plag to check the fluid level, and noticed that when they put that plug back in they stripped it. And I told them to hand torque the plug in. I asume they took an air tool to it instead. So I have carefully put that stripped plug back in. This Fall I'll get around to retapping the hole & buying a larger plug. |
#588 (permalink) |
For the focking 3rd time
in 2 weeks. Took my ride back to the dealership. Mechanics are still trying to figure out why in da hell seal is coming off again and again, anyway this is what these dum asses told me they did.Removed trans assembly and disassembled and replaced all seals including input seal and bearing assembly both axle seals, the speedo gear o-ring and the transfer shaft seal and reseal the center case.Tenshivr4, By the way I am going to new york for a week,when I come back we should get together sometime for a cruise or something and perhaps u can teach me a thing or 2 about these cars, ![]() |
#589 (permalink) | |
93 VR4: 2006 Engine Rebuild/Port and Polished Heads, '99 Lifters, DR 500's, CFDS, TC Bracket, Custom Catback/DP w/precat elims, Unichip, EBC, 680cc injectors w/Denso/AEM fuel reg/Hotwired, H&R springs(-1")-new struts, SPEC 3/PLUS clutch w/Fidenza Flywheel(new), MAFT, Front/Rear strut bars, polished plenium and chrome engine dress, 18" chromies. Newer TC (recall but never had problem!) 60k tune with all new parts(redone during rebuild).
93 SL: DP/ 3sX Lightened pulley, K&N intake w/ SuperMac Cold wall. SS Grey!(Died 2/07 |
#590 (permalink) |
Woot!
Knock on wood the Current TC in my car is not leaking and seems to be in good working order, how do I go about checking up to see if it was replaced already on my car? do I just car the dealership and have them run my vin?
-L_P |
