Old 03-25-2008, 11:03 AM   #1 (permalink)
FLAV's Avatar
Drives: 3000gt
FLAV is an unknown quantity at this point
Default tranny is going crazy!!!!..... help
after peeling out last night i got home i went to reverse and my car wasnt reversing at all....... and i got my first gear in neutral and and in drive.... 1st gear is second and 2nd is first..... wtf happen there ?!?!?!? seriously i need help.... thanks guys.
FLAV is offline   Reply With Quote
Old 03-25-2008, 11:29 AM   #2 (permalink)
GTONW is good to go
Colt45_GTO's Avatar
Drives: Black '91 TT
Colt45_GTO Level 3Colt45_GTO Level 3Colt45_GTO Level 3Colt45_GTO Level 3
Default Re: tranny is going crazy!!!!..... help
manual box?
if manual sounds like the pin has broke or come free on the selector arm at the end of the cable. you can just see it between the pipes.
Colt45_GTO
Semper Fidelis
go register at www.gtonw.co.uk
Old 03-25-2008, 02:58 PM   #3 (permalink)
FLAV's Avatar
Drives: 3000gt
sorry
n0 its auto....
Old 03-25-2008, 03:40 PM   #4 (permalink)
GTONW is good to go
Colt45_GTO's Avatar
try changing the oil. doubt it would work but your oil might be a little frazzled, just to edit this post abit....
get on to IPT import power transmissions and buy an oil filter and pencil filter for your tranny, both easy to fit but before you do, if your oil is shot you need to flush the system including the oil cooler which is part of your rad. the pencil filter fits in the rubber hose on the oil cooler pipe ontop of the gearbox.
flush with something like parafin or similar but make sure you do this soley to the rad and not the gearbox. once the oil cooler is showing clear fill the gearbox with new oil and engine flush loop the oil cooler pipe back from outlet to inlet start the car work the shift from p>low back to park for 2 mins and drain.
remover gearbox sump and pan filter. replace with new filter. replace pencil filter connect oil cooler back up fasten sump bolts make sure of no leaks. fill gearbox with atx fluid run the sequence agan and dip the oil with engine running and in either P or N . top up untill right level. and try the car on the road.
this is the simple solution. hard solution and possible cause is that the clutch packs have burnt out and foul'd up the sensors.
Old 03-25-2008, 04:04 PM   #5 (permalink)
GTONW is good to go
Colt45_GTO's Avatar
check the cable make sure its not come loose on the selector gearbox side
Old 03-27-2008, 02:28 AM   #6 (permalink)
FLAV's Avatar
Drives: 3000gt
lol... uu think this is gonna work ???... i start the car today and i gave the car some gas and it doesnt even pass 3500rpms its like stuck lol no power or sumthing..... when the car used to run soo nice and smooth with great acceleration.... it blows dude!!!!!!!!!!!!!! ......
anymore sugestions ??
