Old 04-24-2008, 08:30 AM   #1 (permalink)
myfirststealth is an unknown quantity at this point
Default Syncro's? Or not? Weird........
Ok, so when the car is cold or at outside temp. It shifts fantastic, once it gets up to temp it gives the impression 2nd and 3rd gear syncros are out. Ideas????
Thanks!
myfirststealth is offline   Reply With Quote
Old 04-24-2008, 08:37 AM   #2 (permalink)
Here for the tuna.
lawdogg's Avatar
Drives: The Speed Limit
Trader Rating: (66)
Default Re: Syncro's? Or not? Weird........
Have you bled your clutch fluid lately? How's the pedal pressure?
94 VR-4: 11.8 @ 116, 17psi, pump, 13Ts
Old 04-24-2008, 09:26 AM   #3 (permalink)
Nope never have, seems to be ok. I know I have to depress it fairly far to disengage
Old 04-24-2008, 09:29 AM   #4 (permalink)
Here for the tuna.
lawdogg's Avatar
Trader Rating: (66)
If you put it in gear, with the clutch in, then give it a little gas does it creep forward?
Also is there a rattling noise from the bellhousing when not in gear with the clutch out, that goes away when you press the clutch in?
Old 04-24-2008, 10:53 AM   #5 (permalink)
never a dull moment
DCIV's Avatar
Drives: 92 VR4
Trader Rating: (12)
DCIV Level 7DCIV Level 7DCIV Level 7DCIV Level 7DCIV Level 7DCIV Level 7DCIV Level 7DCIV Level 7DCIV Level 7DCIV Level 7DCIV Level 7
Mine use to do that, an ss clutch line fixed it for me.
Coop
To many mods to list.
Old 04-24-2008, 11:48 AM   #6 (permalink)
No, no creeping. There is no strange noise that I recall. I'll check when I go out later today. There is a noticeable difference at idol with the clutch in versus out and neutral.
