#2 (permalink) |
Gear Head
Sounds like a linkage issue. Did the shift lever start feeling different after the problem? Pull up the shift boot in the car and make sure the cables are still attatched. The other end of the cables are on the tranny. Check that end also. Let us know what you find.
![]() 250 RWHP If you want the exploded views of both 5 and 6 speeds or pics e-mail me at SavagTiger@AOL.com. 94 VR-4 Panama Green Tan Interior RPS II, gutted cats, flipped BPV, 3SX control arms, 3SX shift bushings, Red Line, Auto-Meter. Rebuilt TC, transaxle, steering rack, heads, and turbos. 360cc's blue printened with in 1%. New short block. RWD convertion and welded rear end. |
#3 (permalink) |
Alright so finally got working on the car, the linkage is attached at both ends. The control arms on the transmission function as follows:
The one closest to me standing on the passengers side of the car moves while the one furthest away is stuck. Any ideas? |
#6 (permalink) |
Gear Head
Take the cable off of the one that is stuck (sounds like the it goes to the arm that is verticle correct?) and push it into and out of it's sheath. If the shift lever in the car does not move, then the shift cables need to be replaced. They come as a set and there are two different kinds out there. One has adjusting nuts on the cabin side for both cables and one has the adjusting nuts for only one cable.
#7 (permalink) | |
tranny is stuck. |
