#1 (permalink) |
Now a VR-4 driver
Okay guys, first of all I rarely ever launch my car, the only times I have on dry pavement are at auto-x events.
Here is the problem, When I launch my car at an autox I ususally feather/dump the clutch at 3-4 thousand rpm, thats all my car needs and it doesn't bog. It feels as if there is almost no strain on the tranny. when I do this on dry pavement everything is fine the tires screech and I'm off like a rocket. However... when I do this where i have little traction like on snow, or on wet slick pavement the whole drivetrain goes nuts! the transmission feels like it's being bounced around a lot(very loud and clunky). I've been under the car(still new to the awd, I had a fwd tt that i learned everything on.) and the driveshaft seems to have a lot of play in it, far more than I'd expect. like maybe even an inch, or more. When this happens it just seems to me that It would be motor mounts, that's what i initially expected. Why does this only happen when the wheels can easily brake traction and not on dry pavement??? and what do you guys think is the problem. thanks for the answers guys, any help is appreciated. David
Gewalt evoII's
#2 (permalink) |
Unknown 3000GT VR4 :**
Worn out carrier bearings can cause DS jerking...
Carrier Bearing and Hardware AWD 3000GT/Stealth*-*Mitsubishi 3000GT*/*Dodge Stealth
![]() ![]() Daily: 2002 BMW 330ci (Angel Eyes+HID, 19" Rims, aFe Stage 2 Intake, ACS Exhaust, Interior Detailing) Wkend/Track/Kill Ride: Rare 1994 Custom Pearl White/Blue 3000GT VR4 - 82250 Miles - Weight: 3560lbs Best 1/4 Time: 13.0@???MPH with a ?.?? 60' Ft Click to read all about my rare 3000GT VR4 <---> Rate my vr4! |
#4 (permalink) |
Forest Gump
motor mounts, sounds like wheel hop and it will break shit if you don't take care of it.
![]() Power: DSM 13G/DR650 Combo, DSM 450 cc bluetops, SAFC I, K&N, Ebay Downpipe, ATR Dual Catback, no cats, DN Y-Pipe, HKS SSQV, HKS EVC 5 at 14.5PSI, Walbro 255 with AN Bulkhead 8.07 @ 85.55 1/8th mile 1.84 60FT Suspension: KYB GR-2 - Tein S-Techs, Crossdrilled/slotted rotors, AWS Delete Drivetrain: RPS Street Max, M.W. 300m O/S, Seattle F&R Poly Mounts Etc: Roller Bearing Short Shifter Smokinvr-4 Corner box, 10" Rockford Fosgate Punch sub, Eclipse Headunit Leatherseats.com Charcoal/Dove Grey Interior, 99 front end/lights/wing/sideskirts/doorcaps Maintenance New VSS, all 60K stuff, new 1st,2nd, 3rd syncro, trans seals, oil pump, rod and main bearings. Mobile 1 10w40, Redline MTL in trans, 85w90 Coastal GL5 in transfer case and rear |
#8 (permalink) |
Breaks all but Xfer case
i say check all the suspension and drivetrain mounts for play. It has to be something like that.
Can you determine if its the front or back of the car?
![]() Black 93 VR-4 12.60 @ 108 w/ 9b's, 550's BlowThrough MAFT and E-Manage 11.77 @ 123 w/ 14b's (22psi), FMIC, MAFTPRO, 650's ??.?? @ ??? w/ 14b's (26psi) ??.?? @ ??? w/ 14b's (24psi) + NOS (35shot) Show and Go: 98 rear garnish, EGR block off plates, Intrax, JayVR4 control arms, 1-4 Syncros, Kormex output shaft, RPS MAX Street Disc, Resurfaced Flywheel, ATR Downpipe, HKS SQV, Dejon dual intakes, AEM Wideband, mobo shift/ebrake boots, Battery Relocation, MAFT PRO, 14B Turbos, DNP TDO5 Headers, Tial Wastegates, DNP FMIC, P+P Heads, 99 Lifters, Vac Reduction, 98 Body kit, 94 Robot headlights, Ross Pistons, Balanced Crank, 720cc's, IPO FPR w/ Gauge, Flexalite fans, Boost a Pump, ARP Head Studs, CF 575 Hood, 50HP NX Wet Kit, NOCAR Xfer Case, Veilside CF spoiler, ACPT CFDS, 19x9 SSR D5R, Blitz SBC-ID, Prosport gauges, Boomslang harness, Corbeau LG1's, Yogurt's 4" cat-back, dual feed fuel system |
#9 (permalink) |
Maybe get some strut bars that usaually helps out with wheel hop.
![]() Mods:3kgt Short Thorw shifter,Matrix intake,DNP Pre-cat eliminator kit,DNP downpipe,DNP 3" Test pipe,DNP cat-back exhaust w/4"tips,polished spark plug,polished upper intake plenum,Polished Wire harness cover,Carbon fiber interior dash kit,Chrome oill filler cap,R1 concepts Drilled and slotted rotors,Ceramic Brake pads,TurboXS BOV,new kelvar timing,new water pump,new oil filter housing,new motor mount,new serpentine gator back belts, katzkin leather seats,Defi BF serires guages eng temp,oil press.,boost,aluminum deforst vents,modifield DSM SMIC,DNP ic piping,big tyla ground wire kit,H4 conversion kit,vac reduction,clutch tank removed,greddy wieghted shift knob,alluminum door seals,and Setrap FMOC. Need plastic pieces under fornt bumper. FOR 1ST GEN STEALTH DO NOT WANT ACTIEVE AERO.If you have these peices pm me or email my at: jeremytwinturbo@yahoo.com Check out the rest of my stealth tt on cardomain:http://www.cardomain.com/ride/2417870[/] |
