Old 05-02-2008, 07:24 PM   #1 (permalink)
mabbott74's Avatar
Drives: '88 Mazda 323 GT
mabbott74 is an unknown quantity at this point
Default Stock driveline max power
I did some searching but I could not find an answer (not good at finding stuff on forums) - apologies if I am repeating.
I am curious what power should I start looking into rebuilding/upgrading the xfer case/tranny if I am looking to do mainly roll races.
Thank you for your input.
EDIT: Oops, AWD models.
mabbott74 is offline   Reply With Quote
Old 05-02-2008, 07:38 PM   #2 (permalink)
VR-4 broken again.
Malaziel's Avatar
Drives: 1992 3000GT VR-4
Malaziel Level 2Malaziel Level 2Malaziel Level 2
Default Re: Stock driveline max power
If you never do races from a dig you should be fine at almost any reasonable power level. However high power launches from a dig with sticky tires most definitely demand a transfer case bracket and upgraded output shaft.
"I have no fear of death. It just means dreaming in silence. A dream that lasts for eternity."
Vincent Volaju
Malaziel is offline   Reply With Quote
Old 05-02-2008, 07:40 PM   #3 (permalink)
Fool...No man can kill me
JasonY's Avatar
Drives: -tee-dee-oh-fived-
Trader Rating: (25)
JasonY Level 5JasonY Level 5JasonY Level 5JasonY Level 5JasonY Level 5JasonY Level 5
What do you have now? Its almost 100% reliant on how you drive the car also. I went from beaking shit all the time driving like a moron to never breaking the car again and getting the same times. But there is a limit eventually of course...
Better tecnique instead of rev/dump and hang on.
Jason
"Busting your butt doesn't guarantee success but sitting on your butt will pretty much guarantee failure"
Quality parts and service from I.P.S. And yeah, ^^^ is a real one...
2001 Silver Dodge Ram/Cummins diesel - tow vehicle for ^^^
JasonY is offline   Reply With Quote
Old 05-02-2008, 07:40 PM   #4 (permalink)
Z15A Tweaker
Trevor's Avatar
Trader Rating: (12)
Trevor Level 7Trevor Level 7Trevor Level 7Trevor Level 7Trevor Level 7Trevor Level 7Trevor Level 7Trevor Level 7
The 6-speed driveline is pretty good up to about 590-600 AWHP. About then you should brace the bellhousing if you're going to be launching the car. After that...ummm....yeah. It's solid.
The iron 6-speed T-Case is about bullet proof.
5-speed wise the aluminum T-case is the limiting factor. Not sure of an absolute power number but I would (personally) be weary of launching a 500 AWHP car with an aluminum T-case. You can get a billet T-case which holds up just as well (maybe even better than) the 6-speed t-case. T-Case brackets aren't exactly a proven fix. I wouldn't trust one to hold together an aluminum T-Case on a 600+ AWHP car.
5-Speeds have split bellhousings occasionally too but they seem to take more launch abuse than the 6-speeds...so that's good.
96 Dodge Stealth R/T TT w/58k
10.396 @ 138.94 (C16+Meth)
10.898 @ 130.00 (91+Meth)
05 Mercedes Benz C230 6-Speed Sedan
06 Dodge Magnum SRT-8
Trevor is online now   Reply With Quote
Old 05-03-2008, 11:40 AM   #5 (permalink)
mabbott74's Avatar
Awesome, thanks for the info. You guys are great.
Old 05-14-2008, 03:13 PM   #6 (permalink)
Drives: 1995 VR4, 1989 240SX
rossfashow is an unknown quantity at this point
what about outputshaft? how strong is that on a sixspeed? launching wise
rossfashow is offline   Reply With Quote
Old 05-14-2008, 09:15 PM   #7 (permalink)
Drives: An AEM car in -10F
Trader Rating: (9)
MustGoFaster is an unknown quantity at this point
The output shaft that goes to the transfer case. It is possible to twist them off. There are upgrades available.
Brackets for the 5 speed t-case help the longevity of them greatly, but it seems they still end up breaking anyways on the higher (500+) power cars.
~Ryan
92 Stealth R/T TT- Not exactly done- 93 RT TT- Not much of a car anymore.
"Failure is just a part of life - and specifically part of owning these cars - failure will sucker punch you in the gut, but you have to spit in it's face and kick it in the nuts - the essence of owning a 3/S."
- lawdogg
MustGoFaster is offline   Reply With Quote
Old 05-25-2008, 08:23 AM   #8 (permalink)
Gear Head
Bret Brinkmann's Avatar
Drives: Rear wheels only...
Bret Brinkmann Level 3Bret Brinkmann Level 3Bret Brinkmann Level 3Bret Brinkmann Level 3
Everything you need to know about your AWD drivetrain.
Here is a link detailing weak links, up grades, and a few other things you should know about. Just read the 1st post and follow the links.
250 RWHP
