Old 01-22-2008, 07:06 PM   #1 (permalink)
BAWnCers
VRoom4's Avatar
Drives: '96 Vr4
Trader Rating: (6)
VRoom4 is an unknown quantity at this point
Default Shifting problems after clutch install
Recently after installing a Southbend clutch I have been having shifting troubles.
Sometimes when at a dead stop(sometimes on startup, sometimes while backing into a parking spot) I cant go into any gear. If I sit a while and play with it it will go in perfect with no grind.
I took it to the dealership after having no luck myself and they said it was an internal problem with the tranny itself.
I cant see it being the tranny as it worked fine pre-clutch install.
Things I have done so far:Adjusted pedal the entire way out, verified the Slave cylinder is pushing the entire way out(per S316).
Any ideas?
VRoom4 is offline   Reply With Quote
Old 01-22-2008, 07:11 PM   #2 (permalink)
AstonMartin's Avatar
Drives: 1991 3000GT VR4
AstonMartin is an unknown quantity at this point
Default Re: Shifting problems after clutch install
booster clutch set right?
Me: "What kinds of things does she like"
Trent: "Cherokee things"
Me: "And what exactly ARE Cherokee things?"
Trent: "Japanese food"
AstonMartin is offline   Reply With Quote
Old 01-22-2008, 07:16 PM   #3 (permalink)
BAWnCers
VRoom4's Avatar
Drives: '96 Vr4
Trader Rating: (6)
Behind the pedal? Never knew it could be adjusted.
How so or a link, S316 says nothing about it.
Old 01-22-2008, 07:18 PM   #4 (permalink)
To be honest, not sure but I've heard, and I use heard loosely, it done before. When you try to shift, does it seem like it hits a wall or something or catch on something mid shift or what?
Old 01-22-2008, 07:21 PM   #5 (permalink)
BAWnCers
VRoom4's Avatar
Drives: '96 Vr4
Trader Rating: (6)
Its not when I am driving, only when putting it in gear initially.
Feels like it is hitting a brick wall like there is no gear there at all. When it eventually goes in it goes into all gears smoothly. Until then I cant go into any gears.
Old 01-23-2008, 10:07 PM   #6 (permalink)
BAWnCers
VRoom4's Avatar
Drives: '96 Vr4
Trader Rating: (6)
Bump, no1 looks at the new subforums.
Old 01-23-2008, 10:34 PM   #7 (permalink)
Certified White Boy
92stealth15g's Avatar
Drives: 1992 Stealth RT/TT
92stealth15g is an unknown quantity at this point
yup, i had the same problem. Bleed the lines. that should fix it. If not, you probably need a new throwout bearing.
1992 Dodge Stealth R/T Twin turbo AWD, Dynamic Racing stage II heads, 99 lifters, 6-speed Getrag from 99 vr4, Southbend Stage 4 DXD-B Clutch, TEC 15g's, Greddy blow off valve, Dejon Powerhouse Blow-Thru Intake Pipes, DSM sidemounts, Denso fuel pump, 550cc fuel injectors, Apexi SAFC, HKS VPC, Apexi AVCR, msd ignition dis-4, MSD 8.5mm wires, NGK coppers 1 stage colder, y-pipe, borla catback, ATR downpipe, highflow cat, Lowered, Nitto tires.
In the future: intercooler hard pipes, hopefully close to 500 horsepower after a good tune.
When im rich: A second gen TD-05 VR4 monster.
92stealth15g is offline   Reply With Quote
Old 01-24-2008, 08:32 AM   #8 (permalink)
BAWnCers
VRoom4's Avatar
Drives: '96 Vr4
Trader Rating: (6)
Its got a brand new TOB, does something go wrong with them?
Old 01-24-2008, 09:23 AM   #9 (permalink)
Certified White Boy
It shouldnt... unless you dumped the $%&@ out of it during the break-in period. Did you bleed your lines and check to make sure your master is full? no leaks in the lines?
Old 01-24-2008, 06:54 PM   #10 (permalink)
BAWnCers
VRoom4's Avatar
Drives: '96 Vr4
Trader Rating: (6)
Bled it twice, the fluid line isnt leaking anywhere.
