Old 04-28-2008, 09:02 AM   #11 (permalink)
I'm a dude.
Toni's Avatar
Drives: 13geed 92 rt tt
Trader Rating: (44)
Toni Level 7Toni Level 7Toni Level 7Toni Level 7Toni Level 7Toni Level 7Toni Level 7
Default Re: Replacing taper bearings complete necessity for a rebuild?
Originally Posted by JackM View Post
That will be a little dangerous. The races float when the case is fully warmed up, so they will possibly come apart or loose in the trans if you cut them. If you heat up the case the races should fall or slide out pretty easy.
Jack
Thanks for the tip. I used a little heat and my puller and they came out pretty easily.
Originally Posted by Devilmightcry View Post
wait. so in our tranny the shims are behind the race and not the bearings?
Yup, behind the races, once the bearings are pressed onto the shafts/diffs etc they stay on.
Originally Posted by phantomrt View Post
The shims are behind the outer bearing race. I'm not sure what is meant when you say "behind the bearings".
I am an overall inexperienced transmission rebuilder, so stick with Jack's advice over mine. I have replaced taper roller bearings in a few of my own manual transmissions over the years. Every time I did it, replacement of the bearing alone resulted in perfect bearing preload by using the exact same shims that were in there before. My theory is that the bearing manufacturing tolerances are so good that the shims are not there for taking up slack in bearing tolerances, but instead all the tolerance is in the cast aluminum transmission case instead. Or maybe tolerances in the transmission shaft also.
On a 2nd note, how in the world did you mess up one of these bearings just by assembling the transmission? They are made of the hardest metal in the world and no chisel that I have in my tool box can do more than barely scratch them. Maybe they're just cheap chisels.
Next time I do this, I am going to try heating up the aluminum housing to remove the outer race--I've always carefully cut the race with my dremel, and at which point it just falls out.
I just replaced all my bearings and I did have to remove the smallest spacer from each of the races to bring them in spec. That dremel technique will only work removing the old races but you will need to be able to remove the new races when properly checking the preload.
-Antoni
My site, tons of pics/faqs(Added LED faq!)
DIY LED Kit for Sale
Speed Factor 2nd place best interior modified
'92 pearl white stealth Rt TT: Mitsu 13gs, Black Racing pro n1s, LC1/LM1 logging (rpm, tps, map, dual egt), RPS street disc/fly,255 Walbro, high flow filter, -6an from tank, AFPR with RobBeck adapter, Apexi el2 5 gauges, maximalperformance tcase bracket/adjustable arms/powdercoating, Tein S-Tech, Greddy Type S bov, Custom exhaust, poly motor mounts, short shifter, led interior.
'06 ninja 500r
'08 vw rabbit
Toni is offline   Reply With Quote
