Old 04-23-2008, 04:01 AM   #11 (permalink)
Play that Funky Music
Import Power's Avatar
Drives: Vicki Insane
Trader Rating: (209)
Import Power Level 7Import Power Level 7Import Power Level 7Import Power Level 7Import Power Level 7Import Power Level 7Import Power Level 7Import Power Level 7Import Power Level 7Import Power Level 7Import Power Level 7
Default Re: Rebuilding trans-Input on 3rd gear? Pics inside
Yes, the parts 3SX sells for the Getrag are OEM Mitsu/Getrag Straight from Japan. No chinese transaxle parts.
Personally, I would change that gear out. It will cause engagment problems.
Both the dogs on the gear and teeth on the slider need to be sharp/to a point in order for the gear to engage quickly and smoothly without grind. If they are flattened/chipped you will not have smooth engagement.
AEM Factory Trained Tuner
T4 AWD 9.21 @ 154.98
T2 FWD 10.19 @ 140.31
T2-820FWHP 3.1L 27psi C16
91VR4 Red-17Gs w/supporting mods-sold
93SLTT/T2
91VR4 Pearl White-sold
91VR4 Black-sold
92VR4 Sandstone-sold
94VR4 Green-sold
93VR4 Pearl White-sold
91VR4 Black-5027s-3.0L-Stock heads and Cams- 625AWHP 557AWTQ uncorrected 24psi 102 octane Daily Driver
3SX Performance
3SX Performance Service Email
Old 04-23-2008, 06:41 AM   #12 (permalink)
GTONW is good to go
Colt45_GTO's Avatar
Drives: Black '91 TT
Colt45_GTO Level 4Colt45_GTO Level 4Colt45_GTO Level 4Colt45_GTO Level 4Colt45_GTO Level 4
+1 for good advice and supplying good quality parts
Colt45_GTO
Semper Fidelis
go register at www.gtonw.co.uk
Old 04-23-2008, 07:25 AM   #13 (permalink)
My name is.. Eli
Drives: Red '92 TT
mynamiseli is an unknown quantity at this point
Thanks for the input everyone.. I guess I will try to scrape my pennies together to buy a new 3rd unless I can find someone parting out a 5spd.
mynamiseli is offline   Reply With Quote
Old 04-23-2008, 09:50 AM   #14 (permalink)
jackstransmissions.com
JackM is an unknown quantity at this point
Originally Posted by Colt45_GTO View Post
brass is brass jack regardless of where it comes from. its not as hard wearing as steel. i'm not saying those who use them suck, i'm saying its the part its self that sucks!
and i'm sure that if the steel ones were as easy to sorce as brass, rebuilders like you would prefer the steel too
The ones we use are steel with a bronze friction surface in the center. They are the latest version of the rings from Japan. The all brass synchros do not expand so I have no clue what you are talking about there. We used to use all brass synchros in all of our DSM and 3S trannies a few years ago and as long as they were from Japan, they were excellent. We now use all bronze synchros in the DSMs and the steel unit with bronze friction centers in the 3S. I don't know why you think we don't use the latest and greatest stuff :shrug:
Jack
www.jackstransmissions.com EVO VIII, DSM, 3S tranny rebuilding.
JackM is offline   Reply With Quote
Old 04-23-2008, 10:14 AM   #15 (permalink)
GTONW is good to go
Colt45_GTO's Avatar
either way they are shit! brass/bronze.....is never as strong as steel!
get muh drift?
