#1 (permalink) |
Does anyone have a good technique to remove the rear axles from the differential? I already tried pry bar and chisel with hammer and they still would not come out. Manual say there is a C-clip in there. Going to try again tomorrow ...
#2 (permalink) |
Wrench Pimp
yea u got it. Pry bar, shouldn't need a hammer, just proper placement of pry bar, I use a long flat head that has the the end angled, similar to a cro-bar, idk how to spell that. But the shafts come out just like the ones in the front, little pressure and the c-clip will pop.
#3 (permalink) | |
est. sept, 2000
yup. just proper placement of the prybar.
97 VR4 12.417@111.16 9b time. whats next?
95 mark viii. 14.35@98 03 cobra vert. 4 mods=118mph traps 91 stealth TT. td05 18G, heads/cams, 3000lbs ![]() |
#5 (permalink) |
SOHC Power!!!
I also had to use a hammer...pry bar bent.
'93 Green 3000GT - Back on the road!!! Fidanza 2.1 cltuch / Fidanza flywheel / 3SX ss clutch line / 3SX crank pulley / Lethal_VR4 manual steering rack / TT radiator / BigTyla ground wires / ebay intake / '99 lifters / TT fuel pump / Maximal solid motor mounts / 3SX long headers / TT race pipe / TT cat-back / KSport coilovers / Maximal rear toe & camber arms / ![]() ![]() |
