Old 04-11-2008, 08:42 AM   #1 (permalink)
Vidiit's Avatar
Drives: 1991 vr4
Vidiit is an unknown quantity at this point
Default Random vibration at highway speed
It starts randomly, mostly at highway speeds at60 and up. engageing the clutch wont make it disappear, changing gears makes no difference neither. when turning it feels worse, its the worst when braking- steering wheels starts shaking badly like the car is falling to pieces. Anything i tried wont change the vibration at all, it just get faster when i speed up,slower when i slow down. First i thought its brake rotors, but then the vibration goes away and everything is fine again, no vibration at all, not even when braking.As i said, it starts and goes away randomly. Just got new tires, balanced the wheels.Changed tie rod ends, ball joints, swaybar end links. New passenger side front driveasxle. Alignment done.
My only guess is driver side driveaxle carrier bearing. Is that it?
Im pretty sure my shocks are also going since on uneven pavement it knocks baldy on front driver side as if the wheel is loose. Lifted nose up to check everything. Rattled both front wheels, wheel bearings seem to be fine also since the wheels dont move at all . But i dont think it has anything to do with the vibration.
Any thoughts on this?
Vidiit is offline   Reply With Quote
Old 04-13-2008, 08:44 AM   #2 (permalink)
L_P
Woot!
L_P's Avatar
Drives: '95 Dodge Stealth TT
Trader Rating: (29)
L_P is an unknown quantity at this point
Default Re: Random vibration at highway speed
Wheel bearing and or carrier bearing also. What that sounds like.
1995 Dodge Stealth R/T TT, Dark Green ext, Dark Int, 1 of 20 available to the US.
Mods: 13T turbos, FMIC 3" in/out, Spec Stage 3 clutch, RPS Billet Aluminum Flywheel, Gutted front and rear precat, test pipe, MSD 8.5mm SC Wires, 3rd Gen lifters, EGR Delete, 3SX EGR Block off plates, Blitz DD BOV, Hotwire Walbro 255 Fuel pump, Map ECU, Dual Pillar pod w/ AEM Wideband and AEM Tru Boost, Halo Hybrid Data logger, Supercar Engineering 1/2 billet aluminum Shift fork, fresh 1/2/3 friction rings, custom solid front and rear engine mounts, 3" Straight pipe exhaust single out.
Looks: DCC Conversion, White face glow gauges.
Sound: Infinity components up front, infinity 10" sub in back with Smokin' VR4 corner sub box, Pioneer HU.
Myspace
Must go faster project underway.
L_P is offline   Reply With Quote
Old 04-13-2008, 08:47 AM   #3 (permalink)
stans3000gt's Avatar
Drives: 1992 VR-4, 1993 SL
stans3000gt Level 1stans3000gt Level 1
I would say check your whole driveshaft for worn U joints and for Carrier bearings being worn that was my problem, in most driveshafts I have seen the front U joint is good and the two rear once go bad how many miles are on your car?. good luck!
stans3000gt is offline   Reply With Quote
