Old 12-18-2009, 08:38 PM   #1 (permalink)
Xx3si89xX is an unknown quantity at this point
Feedback Score: 1 reviews
Default Output shaft seal leak help......
Can anyone help me on removing the output shaft seal for my vr4 w5mg1 without removing the trans? Need to know if possible with out removing tranaxle and how to do it. Any info is greatly appreciated. Thanks
Xx3si89xX is offline   Reply With Quote
Old 12-18-2009, 09:51 PM   #2 (permalink)
Spartan for Life!
aaronatstate's Avatar
Drives: A Dodge Import.
aaronatstate Level 1aaronatstate Level 1
Feedback Score: 9 reviews
Default Re: Output shaft seal leak help......
18 spline or 25 spline? 18 can be done from the outside, 25 has to be done from the inside.
"A turbo: Exhaust gasses go into the turbocharger and spin it, witchcraft happens, and you go faster." -Jeremy Clarkson
January 2009 - ROTM
aaronatstate is offline   Reply With Quote
Old 12-19-2009, 01:58 PM   #3 (permalink)
25 spline. So i need to remove trans?
Old 01-05-2010, 02:08 PM   #4 (permalink)
Gear Head
Bret Brinkmann's Avatar
Drives: Rear wheels only...
Bret Brinkmann Level 1Bret Brinkmann Level 1
Feedback Score: 5 reviews
Yes. Some 25 splines have a lip on the outside that will damage a seal if you attempt to install it from the outside. Even if it doesn't there is not enough room between the output shaft and the flywheel to work with. Don't worry, it's an easy job. Time consuming for a beginer, but easy. The bell housing is the first to come off during disassembly anyway.
250 RWHP
