Old 10-02-2004, 02:08 PM   #21 (permalink)
Member
massstealth's Avatar
Drives: 95 Escort
Trader Rating: (16)
massstealth Level 1massstealth Level 1
Default Re: Output shaft replacement without tranny pull: EASY
Well i finally got it fixed. All i did was pull the little plate off, pull the springs and ball bearings out. Made sure i could shift into 1 + 2. Left it in neutral. Reinstalled the ballbearings and springs. Made sure I put the cover on the right way. It does seem to be position sensitive because the recesses where the springs lay are different depths.
Thanks to AbsurdParadox for the tips. I thought I was gonna have to pull the trans out for sure. Thanks to Kormex for a quality part and some tips over the phone.
Bob
Bob
Rear ended by homeless drunk driver July 12 04
Please wait 13 seconds..
RPS full face clutch, Fidanza flywheel, ATR downpipe, TurboXS dual stage boost controller, K+N fipk, Turboxs h34 bov, Kormex 25 spline, recall transfercase. 180k service done thanks Clint. Soon>>>Hotwire + fuel pump, water/meth
Image hosted by Photobucket.com
SOLD
Now driving 38mpg Escort
massstealth is online now   Reply With Quote
Old 10-02-2004, 02:15 PM   #22 (permalink)
Unforeseen dichotomy.
Drives: 350z
Trader Rating: (16)
AbsurdParadox is an unknown quantity at this point
Glad to hear it worked out man! And its good to know I really helped someone out.
Jason
03 350z Track
94 Stealth TT
95 3000GT base
93 Stealth R/T (sold)
92 3000GT VR-4 (Sold)
91 3000GT VR-4 (Totaled)
AbsurdParadox is offline   Reply With Quote
Old 10-05-2004, 06:20 PM   #23 (permalink)
Drives: 350z
Trader Rating: (16)
Okay Norm, why do you keep posting and deleting it...?
E-mail me the pic of the bearing at t_nosaj@hotmail.com, and I will see if I can identify it.
Old 10-06-2004, 06:22 AM   #24 (permalink)
New User
Norm's Avatar
Norm is an unknown quantity at this point
Couldn't get the photos to attach. Emailed offline.
Thanks,
Norm
Norm is offline   Reply With Quote
Old 11-29-2004, 02:03 PM   #25 (permalink)
Drives: 1991 3000gt VR4
Hi-Rev is an unknown quantity at this point
I know I'm bringing a post back from the dead here. I just wanted to add a few tips of mine from doing a output shaft replacement without pulling anything. Reason is, I could'nt find any of this stuff before I did it and consequently some of it became a real pain. Also, this is not a procedure, just some tips.
1. Don't remove the retainer bolt on the side of the transmission cover. Its on the top left. If you do you will be finding parts and putting them back together as I did.
2. The case can be extremely hard to get off the input shaft. Prying and tapping the allen bolt don't always work. I had to beat mine a lot to get it to finally come off.
3. Reinstalling the VCU is a pita. There are a lot of gears that must line up the insides won't slide all the way in the case. I had to keep pulling it out a little and rotating it before I finally hit the right line-up. If someone else knows a easier way then maybe they could post up.
Good Luck.
91' VR4 (87k miles)
Go Fast: Complete 60k done, New clutch and spline, MSD Superconducters, Proboost mbc (14psi), Autometer boost gauge Shiver's datalogger, Stillen DP, gutted rear precat, K&N Intake, Hotwired stock pump, Kormex 18 spline o.s., and Yokohama ES 100's
Hi-Rev is offline   Reply With Quote
Old 11-29-2004, 02:14 PM   #26 (permalink)
1320' to Fame
TsunamiStealth's Avatar
Drives: to Win
TsunamiStealth is an unknown quantity at this point
Is there a way to do the input shaft also or this will just work with the output shaft?
CHICAGO Crew "We wake up drunker than you were last night..."
http://www.myspace.com/nospray
TsunamiStealth is offline   Reply With Quote
Old 11-29-2004, 02:25 PM   #27 (permalink)
I don't think you could possibly do it without dropping the tranny. Anyone else know for sure?
Old 11-29-2004, 06:15 PM   #28 (permalink)
Member
Drives: 95 Escort
Trader Rating: (16)
I would say no. I am quite sure the gears are pressed on.
I agree with #1. The bolt seems to align that plastic swingy thing in place and thats it, doesnt hold the cover
#2. yes, very difficult. Took like 3 hours and a call to Kormex I put that hex head bolt back in and used a large socket w/hammer.
#3 Mine just slid right out and in like butter
Old 11-01-2005, 10:31 PM   #29 (permalink)
Drives: An AEM car in -10F
Trader Rating: (9)
MustGoFaster Level 5MustGoFaster Level 5MustGoFaster Level 5MustGoFaster Level 5MustGoFaster Level 5MustGoFaster Level 5
Haven't read the thread but all you have to do it lift the lower control arm by the ball joint with a jack and you will be able to get the big long bolt out. If that's already been posted sorry.
~Ryan
92 Stealth R/T TT- Not exactly done- 93 RT TT- Not much of a car anymore.
"This is a solution looking for a problem." - Not me
MustGoFaster is offline   Reply With Quote
Old 04-25-2006, 02:17 PM   #30 (permalink)
Member: Burned valve club
cbatters's Avatar
Drives: 91 Stealth RT/TT
Trader Rating: (12)
cbatters Level 2cbatters Level 2cbatters Level 2
About to toss in a new transfer case / output shaft. (xfer case finally started leaking due to a crack after 193k and is being replaced for free under the safety recall.)
Directions in this thread mention the cover plate with three balls but the site with the photos / directions don't.
I'll be doing this at MassStealth's shop and he has first hand experience repalcing an output ahaft so it should go smoothly. Looks like the hardest part is getting the case cove off.
Any guesses on how long it should take just to remove / reinstall the output shaft from the tranny? (I know I can have the xfer case on the ground in under 30 minutes now that the exhaust and xfer case have been greased correctly when I did my clutch job.)
I'll keep track of time and any tips to pass along.
Clint
Maint: Castrol 10W40 / Mitsu Filter / Rislone
Replaced: 2X clutch / 3X brakes / 2X front rotors / 2X ABS HU / 1X NGK Plugs / 1X Ball joints / 2X Antenna mast / 1X Active exhaust cable / 1X Windshield / 1X Fuel FIlter / 1X Struts / 1X rear rotors / 1X Front Head / VSS / 1X rear wheel bearings / 1X Transfer case (warranty) / 1x Tie rod end (drivers side)
Overhauled: Starter, IAC, BISS, CV Boots
Upgrade: SilverStar Headlights / ebay "Xenon" Fog Bulbs (no more yellow!)
A/F Gauge / MAP - Electronic Boost Logging / MMCd Data Logger
Pending Projects: Steering Rack
cbatters is offline   Reply With Quote
