#11 (permalink) | |
Corn Its whats for boost
AEM Factory Trained Tuner
![]() 91VR4-3.0L-Stock heads and Cams-762AWHP 747AWTQ 30psi E100 Daily Driver 10.63@121mph SLTT-10.9 @ 140MPH Stock NA motor and NA heads/Cams T4 AWD 9.21 @ 154.98 T2 FWD 10.19 @ 140.31 T4-159.23 MPH Ran on 6G72 3.1L! T4-995AWHP Uncorrected 6G72 3.0L C16 T2-820FWHP 3.1L 27psi C16 91VR4 Red-17Gs w/supporting mods-sold 93SLTT/T2 91VR4 Pearl White-sold 91VR4 Black-sold 92VR4 Sandstone-sold 94VR4 Green-sold 93VR4 Pearl White-sold NG09 Title Sponsor 3SX Performance 3SX Performance Service Email |
#12 (permalink) | |
hoping
This would be a good thread for the "how to section"... Too bad id doesnt exist.
1991 pearl white STEALTH tt with 86,364 k&n fipk, 2nd gen vr4 wheels, snake eyes, proboost mbc, turbo xs type h 34 bov
05 quicksilver metallic GTO 6 speed (slow),lingenfelter intake, 06 tails (ricer) s.f. h pipe, gmm ripshift, dba 4000xs slotted and drilled rotors, porterfield r4-s pads, slp long tube headers with offroad pipes, heads? cam? fast 90? little squeeze? ls7 clutch (not currently doing its job very well)? few "extra" heavy pieces removed? 270/40/17 nitto drags? No dyno. Beats buick centuries from rolls so i'm assuming it could possibly go 14.5-17 @ 86-95 mph 1990 toyota 4runner, sr5, 197,000 miles, new (junkyard trans), broken master window switch, broken power steering pump, cracked windshield, rotted off exhaust, slightly crinkled front end, ripped intake hose, coolant leak from somewhere (headgasket?), misc stains everywhere from random stealth parts. FIRES UP EVERYTIME (except for when it is wet outside) havent figured that out yet. 1993 chevy lumina (track whore) 123,000 miles 2005 chevy corvette, m6 22000 miles, f55, 3lt, vararam intake |
#13 (permalink) | |
Member
In step 3 where you say to remove the plate that holds the 3 balls and spins in, where is this. I am trying to remove the cover and was thinking the dowl pins are rusty and preventing removal. I can get the cover off about 1/16 " at top and 1/2" at bottom. Is this plate located on the front side towards the top? Any help appreciated.
Bob
Rear ended by homeless drunk driver July 12 04Please wait 13 seconds.. RPS full face clutch, Fidanza flywheel, ATR downpipe, TurboXS dual stage boost controller, K+N fipk, Turboxs h34 bov, Kormex 25 spline, recall transfercase. 180k service done thanks Clint. Soon>>>Hotwire + fuel pump, water/meth ![]() SOLD Now driving 38mpg Escort |
#14 (permalink) |
Unforeseen dichotomy.
Hmm its been a while, but if you're looking at the back case of the tranny, it should be on the side of it, on the right side. These balls are what keep it in gear, basically. If you don't remove the little cover (look for a piece with only two bolts on it) the cover will be EXTREMELY hard to remove.
Jason
03 350z Track 94 Stealth TT 95 3000GT base 93 Stealth R/T (sold) 92 3000GT VR-4 (Sold) 91 3000GT VR-4 (Totaled) |
#16 (permalink) |
Puts Out On 1st Date !
If you happen to lose one or more of those balls let me know. I lost 1 of mine so I bought a box of 50. I have 49 left over !!
Driver of Turbo Dodges. A '92 Stealth RT/TT and an '03 Ram 2500.
Stealth - 15G's,FMIC,E-Manage Ultimate and other supporting goodies Ram 2500 - Single turbo, FMIC and 4" exhaust (aka-stock) ![]() |
#18 (permalink) |
Member
Well I thought everything was going smoothly. Got the new 25 spline in. Went to start it and go for a test drive. The shifter will not go into 1st or 2nd gear position. All others work fine, 3 4 5 reverse. What could I have messed up. Im almost ready to give up on this car. I am assuming Im gonna have to remove the end cover again. Please help me.
#19 (permalink) |
I would pull that side plate off that holes the three balls in, pull them out, and esnure you can run through all the gears that way, and then ensure its in neutral when you put it back on. Maybe you're getting stuck in two gears at once (1/2 is already engaged, and then you're also able to go to the other gears). Its hard to say, but it could just be something simple as your cables are getting caught on your wiring harness or something, so check that first, of course.
| Thread Tools | |
