#51 (permalink) | |
Member
If you forget a procedure with the trans on the ground....wouldnt that be more work to install the trans and find out later...then pull it back down. If you have done this particular procedure, its not that unfeasible to be done in the car. Everything is right there once the cover is off.....and this seems to be one of the more difficult duties of the job.
Bob
Rear ended by homeless drunk driver July 12 04Please wait 13 seconds.. RPS full face clutch, Fidanza flywheel, ATR downpipe, TurboXS dual stage boost controller, K+N fipk, Turboxs h34 bov, Kormex 25 spline, recall transfercase. 180k service done thanks Clint. Soon>>>Hotwire + fuel pump, water/meth ![]() |
#52 (permalink) | |
The 2nd time around I used a slide hammer to pull/hammer on each one of the tabs and the case came off much easier.
#53 (permalink) | |
Gear Head
In my experience and in talking with others, the hardest part of tranny R&R is mounting it on the block. Using a cherry picker hooked up at the bolts holes on the bell housing for the cable bracket is the fastest and easiest method. I personally have mounted one in under five minutes. With a properly aligned clutch I have never heard of it taking more than 25 minutes. Reassembly of the tranny will be intuitive. The center diff/output shaft ssembly goes in, reinstall the mid housing, place the front diff and pinion shaft back in, reinstall the bell housing, and finally the shift shaft. While their may be more bolts involved and it can sound intimidating, other than bolts, there are fewer parts involved and a significantly reduced chance of damaging anything. With the tranny in the car, you are disassembling it backwards relative to how it was designed to be taken appart and therefore it is not as intuitive during disassembly or reassembly, and there is a far greater chance of damaging parts. Based on the number of people who have asked me for help with in car shaft replacement and the kinds parts they are damaging, I believe it is easier, faster, cheaper, and far less risky for the average 3Si member to R&R the tranny. While it is feasible to do it in the car, I have seen too many members, even with the help from threads such as this, whom would have been much better off had they dropped the tranny. They almost never post their bad experiences with this proceedure. That is why I feel so strongly about this subject. If one uses the method of mounting the tranny to the block I mentioned above, there is no difficult part of the job.
![]() 250 RWHP If you want the exploded views of both 5 and 6 speeds or pics e-mail me at SavagTiger@AOL.com. 94 VR-4 Panama Green Tan Interior RPS II, gutted cats, flipped BPV, 3SX control arms, 3SX shift bushings, Red Line, Auto-Meter. Rebuilt TC, transaxle, steering rack, heads, and turbos. 360cc's blue printened with in 1%. New short block. RWD convertion and welded rear end. |
#54 (permalink) |
Member
If my clutch had any kind of miles I would have dropped the trans. The only part that messed me up where the detent balls and bracket. I had them on backwards when I reassembled. Other that not removing the detent before removing the cover and installing the bracket upside down, my actual time spent was probably 4-5 hours.
Removing the cover was frustrating but all in all im glad I tried this procedure. |
