Old 04-09-2008, 10:49 AM   #1 (permalink)
Schurmia's Avatar
Drives: '91 3000gt VR4
Schurmia is an unknown quantity at this point
Default Nelson 5-spd X-Case Bracket
I have a transfer case bracket from Nelson Performance Pro but it didn't come with any extended bolts...does anyone know if the original bolts will be fine or if I should go look for some longer bolts?
Thanks,
'91 VR4 - Construction Complete...
Schurmia is offline   Reply With Quote
Old 04-09-2008, 11:15 AM   #2 (permalink)
Never finished
1viciousVR4's Avatar
Drives: Nowhere Fast
Trader Rating: (28)
1viciousVR4 is an unknown quantity at this point
Default Re: Nelson 5-spd X-Case Bracket
yeah i have the same bracket, just use the original ones they work fine for me.....just becareful installing it on your TC cause its slightly off center, i used a press.
Also u have to install the bottom bolt that screws into the trans with the bracket or else once its on your case you wont get it in at all without some modification.
99 Chevy Silverado 2500
93 3000GT VR4
So far: 3sx TD05 E16g Turbo Kit, polished Greddy FMIC with IPS tdo5 extensions, Poopra pump, 3sx pulley, MSD wires, NGK coppers, Maximal powdercoated valve covers, polished plenum, Tial Q bov, Hallman Pro RX MBC, Maximal solid mounts, Maximal test pipe, JIC catback, Tein s-techs, Mod-Express 8k HID, Nelson TC bracket, PST CFDS, Fidanza flywheel, RPS Max street, Deft CF hood.
Still Need: AEM EMS, injectors.
1viciousVR4 is offline   Reply With Quote
Old 04-09-2008, 11:22 AM   #3 (permalink)
Forum user
Monster Stealth's Avatar
Drives: 93 VR4 & 99 A4 1.8T
Trader Rating: (23)
Monster Stealth Level 1Monster Stealth Level 1
I am pretty sure you will need extended bolts. OEM ones are too short and may start, but not tighten enough to have enough threads threaded in.
Edit: Really vicious? I know the maximal ones come with longer bolts and the nelson bracket is bigger then his I beleive.
Performance
6G72 Rebuilt w/ 3SX Stage 3 Heads (+1mm intake/exhaust) - ARP Headstuds, Wiseco 8.5:1 Forged Pistons & Kevlar Timing Belt - TD04 9B - Greddy Profec B Spec 2 Boost Controller – Greddy Turbo Timer - SSQV BOV - K&N FIPK - Dejon Tool Y-Pipe - Dejon Tool Intake Pipes - OEM 360cc Injectors - IPO Hotwire Kit - EK2 Fuel Rail Loop – eBay 3” Downpipe w/ custom Flex Section - IPO UD Pulley – RPS MAXX Street Clutch - Maximal Xcase Bracket - MSD 8.5mm Plug Wires - NGK Copper Plugs - Maximal Performance Front & Rear Solid Motor Mounts - 3SX EGR Block Off Plates - Vac. Reduction - AC Delete – Cruise Control Delete - ProSport Gauges (Boost, EGT) - Odyssey PC680 Under Fuse Box
Sitting in garage: EVO 560cc Injectors - MAP ECU - WRX 13T Turbos - Krank Vents - Walbro 255
Suspension/Wheels/Brakes
OEM 17” Chrome Wheels – 245/45/17 Michelin XGT Z4's
Sitting in garage: RS*R Springs – Bilstein Struts – Maximal Adj Control Arms
Exterior/Interior/Dress-up
Autometer 2x52mm Gauge Pod - 99 Rear Center Garnish – Weevil Custom Boost Controller/Turbo Timer Mounting Plate – Snake Eyes Delete Sylvania Silverstar H4666ST – Powder Coated Upper/Lower Intake Manifold, Front/Rear Valve Covers, Y-Pipe, Waterneck, & Alternator Bracket
6G72 Engine Manual - M-Spec Vac Reduction Diagrams - My Picasa Web Album
Monster Stealth is offline   Reply With Quote
Old 04-09-2008, 11:25 AM   #4 (permalink)
Never finished
Trader Rating: (28)
your only talking about an 1/8th of an inch. maybe less, his case isnt thick its just more complex than maximals. I have it bolted in, even with it out th bolts still had a lot of threads to grab onto.
EDIT: im sure longer bolts would be the right thing to do but my stock bolts r doin good for me.
Old 04-09-2008, 11:41 AM   #5 (permalink)
never a dull moment
DCIV's Avatar
Drives: 92 VR4
Trader Rating: (12)
DCIV level 6DCIV level 6DCIV level 6DCIV level 6DCIV level 6DCIV level 6
my e2k bracket was sent with longer bolts and I would love a couple more.
Coop
To many mods to list.
Old 04-09-2008, 02:08 PM   #6 (permalink)
Schurmia's Avatar
Anyone know what size bolts stock are or what size would be needed?
Old 04-12-2008, 08:18 AM   #7 (permalink)
Schurmia's Avatar
I've just installed it with stock bolts for now...there seemed to be a lot of threads to grip with..I will get some extended bolts sometime.
Looks good and went on pretty easily. Took a couple light taps with a rubber mallet to get the bracket on all the way and lined up.
Old 04-12-2008, 02:17 PM   #8 (permalink)
The dark shall be with us
Devilmightcry's Avatar
Drives: 93' VR4
Trader Rating: (12)
Devilmightcry Level 1Devilmightcry Level 1
how is your tc holding. i am thinking to get his braket too, but not sure if my tc is safe with them.
Devilmightcry is online now   Reply With Quote
