Old 06-05-2006, 07:08 PM   #1 (permalink)
mightymoose's Avatar
Trader Rating: (20)
mightymoose is an unknown quantity at this point
Exclamation Need info/advice on low mileage 25 spline--fire damage
Ok, I need some advice, I found a very good deal on a low mileage 25 spline TT 5-speed tranny-minus the TC. Has 42k mileage.90 day warranty However,, the engine suffered fire on the top side,, guys GF lite him up with Lighter fluid-seriously.
By hand, one can manually shift the levers perfectly. One can noticed discoloration both white and black(where hoses, etc,) had melted and fallen on top of tranny.. I wish I had pics, but I do not.
Naturally if I get this Im replacing axle seals. My main concern is- do you guys think I should get this or steer clear of it due to possible damage caused from the heat?
Any and all advice is greatly appreciated
James G
99 & 92 VR4
mightymoose is offline   Reply With Quote
Old 06-06-2006, 04:08 AM   #2 (permalink)
Trader Rating: (20)
Default Re: Need info/advice on low mileage 25 spline--fire damage
Anyone??
Thanks
James G
99 & 92 VR4
Old 06-06-2006, 08:15 AM   #3 (permalink)
Boostin' ...well, someday
NVisible93's Avatar
Drives: 93 RT/TT
Trader Rating: (8)
NVisible93 is an unknown quantity at this point
i guess it kinda depends on the price really. if its dirt cheap i'd say hells yeah.
.... i like things that go BOOST in the night ....
IPS E16G's, 4" exhaust, HKS SSQV, FMIC, 450cc Injectors, SAFC II, Solid Motor Mounts, Iridium Spark Plugs, CTC Plug/Coil Kit, 3SX PWR Aluminum Radiator, K&N Cone Filter, several nics dings and scratches mods, more to come (of the first ones, not the last ones)
NVisible93 is offline   Reply With Quote
Old 06-06-2006, 04:37 PM   #4 (permalink)
3si #1390
david1 is an unknown quantity at this point
i would get it
1992 dogde stealth Evo3 turbo,660 injector, 85 mass air flow and translator 2.1 ,water/methanol injection,
supar fuel pump, k@n air filter, greddy blow off valve, , ips front mount interccoler and pipes ,tires BFG KD d@n down pipe , no cats, blitz sbd-id, msd wires, cross drilled rotors.pst drive shaft ,msd, e2k TC bracket . lsd .spec 3+ clutch
Dr650 1/8 7.5 at 94mph 453HP 470 Torque
Evo3 1/8 7.3 at 98mph 559hp 514 Torque slipping cluch
david1 is offline   Reply With Quote
Old 06-09-2006, 10:16 AM   #5 (permalink)
Breaks all but Xfer case
flyman1981's Avatar
Drives: 08 RAM HEMI, 93 VR-4
Trader Rating: (7)
flyman1981 is an unknown quantity at this point
Look for hot spots on the case. If the case is fine, im sure everything inside gets hotter under normal operation. I would probably take a good look at the axle seals as well as teh output shaft seal. Change the fluid and look at/smell it. Depending on price grab it, You could also part it out. I know VC, output shafts, shift forks are common parts needed.
Brian
Black 93 VR-4
12.60 @ 108 w/ 9b's, 550's BlowThrough MAFT and E-Manage
11.77 @ 123 w/ 14b's (22psi), FMIC, MAFTPRO, 650's
??.?? @ ??? w/ 14b's (26psi)
??.?? @ ??? w/ 14b's (24psi) + NOS (35shot)
Show and Go:
98 rear garnish, EGR block off plates, Intrax, JayVR4 control arms, 1-4 Syncros, Kormex output shaft, RPS MAX Street Disc, Resurfaced Flywheel, ATR Downpipe, HKS SQV, Dejon dual intakes, AEM Wideband, mobo shift/ebrake boots, Battery Relocation, MAFT PRO, 14B Turbos, DNP TDO5 Headers, Tial Wastegates, DNP FMIC, P+P Heads, 99 Lifters, Vac Reduction, 98 Body kit, 94 Robot headlights, Ross Pistons, Balanced Crank, 720cc's, IPO FPR w/ Gauge, Flexalite fans, Boost a Pump, ARP Head Studs, CF 575 Hood, 50HP NX Wet Kit, NOCAR Xfer Case, Veilside CF spoiler, ACPT CFDS, 19x9 SSR D5R, Blitz SBC-ID, Prosport gauges, Boomslang harness, Corbeau LG1's, Yogurt's 4" cat-back, dual feed fuel system
flyman1981 is offline   Reply With Quote
