Old 07-19-2008, 08:13 AM   #1 (permalink)
TwinTurboStealth is an unknown quantity at this point
Default Need help finding tranny bearings please help!
I've finnaly gotten a good VCU and 18 spline shaft. Now heres my problem.
I wasn't 100% sure how to get the VCU out so I took off the top bearing on the intermediate shaft? and took one of the gears off so that I could get to that housing that holds the VCU.
One bearing has a part number 30207JR I have located this thrust/rolelr bearing through a local bearing distributer.
The problem is the plastic needle bearing assembly underneath that I melted when I heated up the Other race to remove it from the shaft. Not all of the needles turn now thats its melted. Does anyone have a part number? or a supplier to get just this one or both bearings?
Thanks
Mike k.
TwinTurboStealth is offline   Reply With Quote
Old 07-20-2008, 07:33 AM   #2 (permalink)
Trader Rating: (107)
Drweldin Level 3Drweldin Level 3Drweldin Level 3Drweldin Level 3
Default Re: Need help finding tranny bearings please help!
I would check with the vendors on here known for dealing with our trans...
Jacks, SCE, 3SX, Kormex come to mind....good luck.
1992 Stealth RT/TT:
Drweldin is offline   Reply With Quote
Old 07-20-2008, 08:13 PM   #3 (permalink)
sleeper
sleeper3000's Avatar
Drives: 1991 mits vr-4 :)
sleeper3000 is an unknown quantity at this point
Supercar Engineering
sleeper3000 is offline   Reply With Quote
