Old 03-30-2008, 03:41 PM   #11 (permalink)
Giggity-no-jutsu!!!
ahkenaden's Avatar
Drives: 91 RT/TT
ahkenaden is an unknown quantity at this point
Default Re: need help fast
Originally Posted by plainoldstealth View Post
It sounds like the clip on the end of the shaft is not engaged-meaning the shaft is not all the way in. Or maybe there is no clip on the axle, and the shaft is popping out?
It takes a good amount of force to slam the axle into the trans, are you sure they are in all the way?
At this point the splines might be messed up, and not allowing the shaft to couple with the trans.
Agreed. You've got to seriously whack those things in. I suggest unscrewing the axle nuts on the hub a tad, and whacking the f%^k out of it with a soft faced mallet (or a regular hammer + block of wood).
Good luck.
Done.
ahkenaden is offline   Reply With Quote
Old 03-30-2008, 05:37 PM   #12 (permalink)
Paid Member
Drives: 92 Sandstone VR4
bert0mac Level 4bert0mac Level 4bert0mac Level 4bert0mac Level 4bert0mac Level 4
i dont see how the clip would just vanish. although i do think i could put some more force on the thing tommorow and try to get it in. i really hope i dont need to replace this axle.
the sounds its making scare me though.
ill keep you posted. thanks for all the help guys
92 sandstone vr4
dr-500 turbos
custom made exhaust
fipk
walbro fuel pump
more to come
bert0mac is offline   Reply With Quote
Old 03-30-2008, 09:18 PM   #13 (permalink)
Paid Member
out of curiosity. if the clip is gone, what would i need to do to fix it?
Old 03-30-2008, 09:32 PM   #14 (permalink)
est. sept, 2000
91vr4n00maxima's Avatar
Drives: slow 97 VR4
91vr4n00maxima Level 791vr4n00maxima Level 791vr4n00maxima Level 791vr4n00maxima Level 791vr4n00maxima Level 791vr4n00maxima Level 791vr4n00maxima Level 791vr4n00maxima Level 791vr4n00maxima Level 791vr4n00maxima Level 791vr4n00maxima Level 7
get a new clip...if you can. im not sure if its available seperately.
it takes some serious force to pop it in. youll know when its seated. it will pop, then bottom out with a thud. if it moves freely in and out of the trans its not seated. it should be tight.
97 VR4 12.417@111.16 9b time. full weight almost BPU
95 mark viii. 14.35@98
03 cobra vert. 4 mods=118mph traps
91 stealth TT. td05 18G, heads/cams, 3000lbs
95 montero SR. factory rear locker. 3.5 DOHC
91vr4n00maxima is offline   Reply With Quote
Old 03-30-2008, 09:36 PM   #15 (permalink)
Paid Member
it moves, but not too freely. im gonna spend more time on it tommorow. i was lost as to what to do today. trying to get instructions over the phone. but its definatley loose so im gonna give it my all and fix this damn thing.
thanks for the help
Old 03-31-2008, 06:02 PM   #16 (permalink)
Paid Member
ok. so its definatley not coming from the half shaft on either side. nor is the grinding coming from the drivers side.
im worried it might be the tranny. im gonna drain it tommorow and check the fluid to see how bad off it is.
anyone selling a used 25 spline 5 speed?
maybe ill penny up and spend the countless hours converting to 6 speed.
Old 04-02-2008, 10:01 AM   #17 (permalink)
Certified Car Nut
JeffWVR4's Avatar
Drives: Like a Grandpa
JeffWVR4 level 6JeffWVR4 level 6JeffWVR4 level 6JeffWVR4 level 6JeffWVR4 level 6JeffWVR4 level 6
So what's the verdict?
Jeff W.
Red '92 VR4 215,000 mile daily driver that run's 11's! Once I convinced the wife I needed 600hp to drive to work every day, 1/4 mile at a time, the rest was easy
Big 16G Turbos w/IPS headers and pre-cat eliminators, DR Stage 3 heads, 92mm Wiseco pistons, PTE 680cc injectors, ARC2 fuel controller, HKS Twin-Power Ignition, HKS EVC IV BC, HKS SSBOV, Alamo I/C's and HardPipe kit, ATR DP, Borla exhaust, NeedsWings Electronic Exhaust Cutout, MSD 8.5mm plug wires, Denso Stage1 fuel pump, DR Fuel Pump Hotwire Kit, South Bend FE/SS Stage 5 clutch, Boost Cooler water/meth injection, DynoTech Metal-Matrix aluminum driveshaft, no cats, Eibach lowering springs, PowerStop/Stillin rotors, Goodrich SS brake lines, PSI Tire Pressure Monitor System, AEM Wide-Band O2, Fittipaldi wheels, 2-tone all-leather Interior.
JeffWVR4 is offline   Reply With Quote
Old 04-02-2008, 07:02 PM   #18 (permalink)
Paid Member
hobby shop was closed tuesday and wednsday. im gonna pull the t case tommorow and see what the deal is on that end.
unless im retarded, the shafts were all connected properly.
i still cant figure how this happened. the car worked just fine when the lift went up, it just went apeshit when the lift came down
Old 04-15-2008, 06:43 PM   #19 (permalink)
91 RT/TT
EvanH's Avatar
Drives: 91 RT/TT
EvanH is an unknown quantity at this point
anyone ever figure out what this was? did you take your e brake off? lol
EvanH is offline   Reply With Quote
Old 04-15-2008, 10:30 PM   #20 (permalink)
Paid Member
yes i took the ebrake off thanks...
its at the shop right now. i couldnt find the issue.
i think it might be a jacked up axle after all. wierd cause when i checked them i saw no splines and they were firmly in place.
ill find out more tommorow
