Old 03-29-2008, 02:52 PM   #1 (permalink)
Paid Member
Drives: 92 Sandstone VR4
bert0mac Level 4bert0mac Level 4bert0mac Level 4bert0mac Level 4bert0mac Level 4
Angry need help fast
i just finished installed my TEIN S-tech springs. everything went well. no problems that i noticed.
when i was done and cleaned up all the tools and whatnot(on base at hobby shop) i tried to back the car out. as soon as i started to let the clutch out. i heard a nasty grinding noise.
the car will not move whatsoever under its own power. i can let the clutch out all the way without giving throttle. but it grinds horribly.
the guy at the hobby shop said it sounds like a throwout bearing. but i have a nasty feeling it might be the tranny/transfer case.
i did a search and couldnt find anything, but ill keep looking. please help
92 sandstone vr4
dr-500 turbos
custom made exhaust
fipk
walbro fuel pump
more to come
bert0mac is offline   Reply With Quote
Old 03-29-2008, 05:23 PM   #2 (permalink)
Paid Member
Default Re: need help fast
buuump
Old 03-30-2008, 07:42 AM   #3 (permalink)
Paid Member
come on guys. someone must have an idea whats wrong.
help
Old 03-30-2008, 09:53 AM   #4 (permalink)
Senior Member
defgh1's Avatar
Drives: 99 VR4, 04Volvo V70R
Trader Rating: (8)
defgh1 Level 7defgh1 Level 7defgh1 Level 7defgh1 Level 7defgh1 Level 7defgh1 Level 7defgh1 Level 7defgh1 Level 7defgh1 Level 7defgh1 Level 7defgh1 Level 7
Probably not the TOB since the most stress on the bearing is when you apply the clutch not while releasing it. If you can let the clutch out all the way without the motor stalling it sounds like your clutch is shot. How many miles on the current clutch.
Doug H
91 Sandstorm TT, 431 AWHP, 433 ft-lbs. , Kormex 25 spline,LSD, RPS CC Clutch, 4 bolt conversion, Super 15Gs, Stage 3 heads, DSM Sidemounts, PST Driveshaft, Blitz DSBS, HKS Exhaust, 3SX Downpipe, Supra Pump, 780 cc PTE Injectors, SX Fuel reg. & dual feed, AEM, Duel WJO Wideband, HKS DL1, Alcohol Injection. Photos: -->
defgh1 is offline   Reply With Quote
Old 03-30-2008, 10:24 AM   #5 (permalink)
est. sept, 2000
91vr4n00maxima's Avatar
Drives: slow 97 VR4
91vr4n00maxima Level 791vr4n00maxima Level 791vr4n00maxima Level 791vr4n00maxima Level 791vr4n00maxima Level 791vr4n00maxima Level 791vr4n00maxima Level 791vr4n00maxima Level 791vr4n00maxima Level 791vr4n00maxima Level 791vr4n00maxima Level 7
pull the transfer case and check the splines on the OS.
sounds like a coincidence failure.
also make sure 1 of the halfshafts didnt pop out of the trans. this is more likely since you were just in the area.
97 VR4 12.417@111.16 9b time. full weight almost BPU
95 mark viii. 14.35@98
03 cobra vert. 4 mods=118mph traps
91 stealth TT. td05 18G, heads/cams, 3000lbs
91vr4n00maxima is offline   Reply With Quote
Old 03-30-2008, 10:40 AM   #6 (permalink)
Sandstone Club
VR(ich)-4's Avatar
Drives: '93 vr-4
VR(ich)-4 is an unknown quantity at this point
+85
my baby's toys:borla catback//k&n cone//blitz bov//swoosh turbo timer//NGK laser etched iridiums//12 l/b's of boost//moda r6 18x9(full set now ftw thanks to njstealth)//removable sunroof//SANDSTONE exterior
VR(ich)-4 is offline   Reply With Quote
Old 03-30-2008, 11:13 AM   #7 (permalink)
ACZEP's Avatar
Drives: 94' Stealth RT Turbo
ACZEP Level 1ACZEP Level 1
**If you press the clutch in/down to the floor, and then slamming it into (Rev) it should go "clunck", the car many move a bit in reverse.
*Possible causes:
-worn clutch
-worn throw-out bearing
-clutch not disengaged fully
-needs adjusting
-or syncro ring is worn
Hopefully this helps.....
ACZEP is offline   Reply With Quote
Old 03-30-2008, 11:35 AM   #8 (permalink)
carkidnos's Avatar
Drives: 93 Stealth ES
carkidnos is an unknown quantity at this point
I would def check to see that you didnt pull the half shafts out of the tranny seeing as you were playing in that area it is def possible that they slipped out enough.
When all else fails... Use a bigger hammer and some duct tape.
carkidnos is offline   Reply With Quote
Old 03-30-2008, 01:02 PM   #9 (permalink)
Paid Member
i tried taking a look at the halfshafts today. i think that is what happened. but i couldnt figure out how to fix the problem. i disconnected them from the rotors and pushed them in as best i could.
it worked for about 5 feet and then stopped.
now its grinding and squealing.
this blows
Old 03-30-2008, 02:35 PM   #10 (permalink)
Drives: 92 TT
Trader Rating: (16)
plainoldstealth is an unknown quantity at this point
It sounds like the clip on the end of the shaft is not engaged-meaning the shaft is not all the way in. Or maybe there is no clip on the axle, and the shaft is popping out?
It takes a good amount of force to slam the axle into the trans, are you sure they are in all the way?
At this point the splines might be messed up, and not allowing the shaft to couple with the trans.
plainoldstealth is offline   Reply With Quote
