Old 07-20-2008, 01:36 AM   #1 (permalink)
Drives: 1991 3000gt VR4
lickbeeeznutz Negative 2
Default Need help! 3rd Gear pops
I have a problem with my 18 spline tranny. So my throw out bearing was going and so was my input shaft bearing. I knew it was going bad by the sound. So as I was driving home from buying tools(to take it apart) all of a sudden i was driving and shifted into the third, as I accelerate normally it just pops out. Shift it back in and it pops out. It never grinded before at all. When i dropped the tranny the input shaft bearing n throw out bearing was completely gone. What could the problem be? Since it never grinded before EVER, it was buttery smooth. It couldn't be the synchro right? And if anyone can give me a link to a transmission rebuild write up or take apart. I couldn't find it. Any help would be greatly appreciated!. Thank you in advance!
p.s. I bought the car with a short shifter and sometimes shifting it feels as if there is play. As in when its in gear there is play. Just thought this might help out.
lickbeeeznutz is offline   Reply With Quote
Old 07-21-2008, 04:36 PM   #2 (permalink)
Default Re: Need help! 3rd Gear pops
no one is willing to help? Where are the good fellow members of this forum?
Old 08-08-2008, 10:49 AM   #3 (permalink)
Breaks all but Xfer case
flyman1981's Avatar
Drives: 08 RAM HEMI, 93 VR-4
Trader Rating: (7)
flyman1981 is an unknown quantity at this point
Usually when it pops out of gear like that, its a bent shift fork.
Black 93 VR-4
12.60 @ 108 w/ 9b's, 550's BlowThrough MAFT and E-Manage
11.77 @ 123 w/ 14b's (22psi), FMIC, MAFTPRO, 650's
??.?? @ ??? w/ 14b's (26psi)
??.?? @ ??? w/ 14b's (24psi) + NOS (35shot)
Show and Go:
98 rear garnish, EGR block off plates, Intrax, JayVR4 control arms, 1-4 Syncros, Kormex output shaft, RPS MAX Street Disc, Resurfaced Flywheel, ATR Downpipe, HKS SQV, Dejon dual intakes, AEM Wideband, mobo shift/ebrake boots, Battery Relocation, MAFT PRO, 14B Turbos, DNP TDO5 Headers, Tial Wastegates, DNP FMIC, P+P Heads, 99 Lifters, Vac Reduction, 98 Body kit, 94 Robot headlights, Ross Pistons, Balanced Crank, 720cc's, IPO FPR w/ Gauge, Flexalite fans, Boost a Pump, ARP Head Studs, CF 575 Hood, 50HP NX Wet Kit, NOCAR Xfer Case, Veilside CF spoiler, ACPT CFDS, 19x9 SSR D5R, Blitz SBC-ID, Prosport gauges, Boomslang harness, Corbeau LG1's, Yogurt's 4" cat-back, dual feed fuel system
flyman1981 is offline   Reply With Quote
