Old 04-17-2007, 12:02 PM   #1 (permalink)
www.TN3S.com
user3977's Avatar
Drives: 91 stealth RT/TT
user3977 is an unknown quantity at this point
Default lower control arm question
are the TT and NA compatible, also are all years compatible? i was looking it up they have posted before and after 11/99 as a split when searching for a 91 tt lower control arm. My car was made in march/91 so does that limit me to a very small window of parts that i can get for the control arm?
thank you
matthew
user3977 is offline   Reply With Quote
Old 04-17-2007, 12:28 PM   #2 (permalink)
est. sept, 2000
91vr4n00maxima's Avatar
Drives: slow 97 VR4
91vr4n00maxima Level 791vr4n00maxima Level 791vr4n00maxima Level 791vr4n00maxima Level 791vr4n00maxima Level 791vr4n00maxima Level 791vr4n00maxima Level 791vr4n00maxima Level 791vr4n00maxima Level 791vr4n00maxima Level 7
Default Re: lower control arm question
ill assume you mean front?
all ive been ablke to find were these. to 11/91. 11/91-9/93, and 95-99. i didnt search 94 since thats obviously irrilevant.
i would like to know too if the 95-99 are interchangable with the earlier 1s. i need to put my 91s front subframe into my 97 but dont want to use the 91 control arms. if i can use my 97s control arms i have a complete early 91 front suspension.
97 VR4 12.417@111.16 9b time. whats next?
95 mark viii. 14.35@98
03 cobra vert. 4 mods=118mph traps
91 stealth TT. td05 18G, heads/cams, 3000lbs
91vr4n00maxima is offline   Reply With Quote
Old 04-17-2007, 06:03 PM   #3 (permalink)
www.TN3S.com
user3977's Avatar
lol dibs on front pass side lower arm
Old 04-17-2007, 06:33 PM   #4 (permalink)
est. sept, 2000
Drives: slow 97 VR4
lol. if i end up needing 1 thats the 1 i need. i need to get off my ass and drop the subframe to see if 97+ arms fit a 1G sub.
can someone with CAPS check to see if the front subframe that the steering rack mounts to has production cut-offs?
Old 04-24-2008, 07:47 PM   #5 (permalink)
USMC
vr4_rider's Avatar
Drives: '93 Vr4; '06 675cc
Trader Rating: (10)
vr4_rider is an unknown quantity at this point
I couldn't find the answer...
What is compatible with a 1993 TT?
Thanks,
T
Trung [1993 Pearl Black VR-4]
Appearance//1999 Front end//ground controls w/ adj. rear control arms//18x9 5Zigen 5ZR wrapped in 245 front, 275/35/ZR18 Falkens//DR Racing Black lugnuts
Mods//GReddy EBC Spec-II//Greedy Type-S BOV//Unorthodox UD pulley//ATR Downpipe//IPS Single Shot Magnaflow//255 Walbro pump//GReddy Profec Spec II EBC//JET tuned ECU//AutoMeter Boost gauge//HKS Turbo Timer//Gutted Hi-Flow DynoMaxx CC//Vac Reduction//EGR Block off//PRO-M 80mm MAS and MAF-T Tuner//EVO 8 560cc injectors //Shriver's datalogger
Turbos: 13Tx2
Current Problem(s): Cherries in the rear view mirror
In the Process: Nothing
Want to Trade/Buy: Cams and springs, non-OEM clutch and flywheel...
vr4_rider is offline   Reply With Quote
Old 06-09-2008, 12:02 AM   #6 (permalink)
POC3000gt's Avatar
POC3000gt is an unknown quantity at this point
i would really like to know too
POC3000gt is offline   Reply With Quote
Old 06-17-2008, 04:39 PM   #7 (permalink)
zero0's Avatar
zero0 is an unknown quantity at this point
i'm pretty sure it will fit the part numbers are the same for all years and models..also get the control arms from a 97 hyundai sonata v6 version they cost around $130 each and are the same exact part. i saved alot of money and they work fine. cuz at almost 340 each from mits dealer no thanks!!!
zero0 is offline   Reply With Quote
