#42 (permalink) | |
93 VR4: 2006 Engine Rebuild/Port and Polished Heads, '99 Lifters, DR 500's, CFDS, TC Bracket, Custom Catback/DP w/precat elims, Unichip, EBC, 680cc injectors w/Denso/AEM fuel reg/Hotwired, H&R springs(-1")-new struts, SPEC 3/PLUS clutch w/Fidenza Flywheel(new), MAFT, Front/Rear strut bars, polished plenium and chrome engine dress, 18" chromies. Newer TC (recall but never had problem!) 60k tune with all new parts(redone during rebuild).
93 SL: DP/ 3sX Lightened pulley, K&N intake w/ SuperMac Cold wall. SS Grey!(Died 2/07 |
#45 (permalink) |
Here are the 'turnbuckles' on my shifter cables. Let me know if yours are way different or similar. I can email a larger pic if needed. These are in the spot where I get the best shifting. Its not great, still notchy but the best it gets.
#46 (permalink) | |
what would dave thomas do
also last night i swapped in some straight redline mtl. and it feels a little better. i'm gonna give it a week or so cause i only put like... 11 miles on the car. but yeah i'll tell you guys if i feel a difference after putting some miles on it |
#47 (permalink) |
Someone else's mistakes
WHen it was mentioned that it was stuck in first gear and you have notchiness shifted and have to stay in neutral, that absolutely sounds like clutch drag. I have another way to check/prove this. When you shift from 1st to 2nd give it a every so slight throttle to take the load off of the trans, if it comes out magically then your clutch is absolutely dragging. You can, but I don't reccomend shift without a clutch this way without hurting your trans, if you rev match, again only do this WHILE using your clutch, and try to rev match on other shifts as well and see if it is better. What type of clutch do you have? Was it changed when the transmission was? Was the shaft the throwout bearing lubricated? Was the spline the clutch disc rides on lubricated? Is the flywheel fresh ? If any of these are unsure you WILL wreck your tranny if noit correctly. A properly operating clutch is paramount for proper shifting!!! It could be yor entire problem. You can also check the freeplay per the sevice manual and also go to stealth316.com and look for clutch not disengaging properly section about the bolt falling out, lot's of good info there.
-Ron
DR650R's, supra fuel pump hotwired and aem fuel pressure regulator with bob beck adapter, addicted performance front mount intercooler and piping, ceramin coated inside and out, ebay knockoff DN headers, cusom stillen downpipe, Borla catback, precision turbo 550cc injectors, RPS MAX series clutch, street disc, and RPS segmented aluminum flywheel, 3sx braided stainless turbo feed and return lines, 3sx braided clutch line, fidanza adjustable cam gears, arc2 fuel controller with ford MAS, greddy E-manage blue for fine tuning and timind control, Greddy profec E-01 for boost control, AEM widemand O2, arm-1 narrow band o2, autometer boost gauge, HKS ssqv with custom recirc adapter, 3sx fuel rail adapter.
#48 (permalink) | |
Originally Posted by Paradigm There have been other threads that had nothing to do with Kormex, but as soon a Komex was mentioned...guess who shows up? I wouldnt be surprised if he hits the search button every morning just to see whats brewing -------------------------------------------------------------------------------- Quote: Originally Posted by Paradigm Did i lie....? Quote:
I bet you are an employee and not an owner or partner in your business. If you were you'd understand. If my business was being talked about you bet I'd follow conversations closely. If they are talking about my business, you are essentially talking about me. I think it's admirable and smart that Kormex cares to know what the current buzz is in the tranny rebuild business in general and about their own company in particular. (I'm just saying that's how it appeared.) Last edited by Audiophobe : 04-25-2008 at 04:15 PM. |
#49 (permalink) | |
I do watch the board , is that a problem ? not as much as I used to, cus the newest members aren't very intresting . Dave , I know you've been cool about it , and so has driver17 . I 'll help as much as I can man . |
