#1 (permalink) |
im going to look at a 92 vr4 for sale. its currently not running and the owner bought it that way so he doesn't know anything about the transmission. is there anything i can do to determine if it has any kind of problems without driving it. also how much does it usually cost if it grings in 1st and 2nd like a typical problem like that? also anything to check with the transfer case, besides an obvious leak? thanks
#2 (permalink) |
About the best you can do is make sure it goes into all gears, no obvious external damage, and the clutch pedal feels ok. Probably run you anywhere from $1500+ to replace the synchros if you have a shop do it.
