Old 05-10-2008, 10:12 PM   #11 (permalink)
My name is.. Eli
Drives: '92 Stealth TT
mynamiseli Level 1mynamiseli Level 1
Default Re: How do these 5-speed synchros look?
Here is a link to my recent thread, you can check out the responses I received: Rebuilding trans-Input on 3rd gear? Pics inside
As I said, my 3rd looked nearly the same as yours. I would at least pick up a good used 3rd gear to replace that one.
mynamiseli is offline   Reply With Quote
Old 05-11-2008, 04:24 AM   #12 (permalink)
Corn Its whats for boost
Import Power's Avatar
Drives: Vicki Insane
Trader Rating: (210)
Import Power Level 7Import Power Level 7Import Power Level 7Import Power Level 7Import Power Level 7Import Power Level 7Import Power Level 7Import Power Level 7Import Power Level 7Import Power Level 7Import Power Level 7
3sfever
Yes, those flat spots both on the gear dogs and on the slider will cause a problem. Replace both.
As for the friction ring. What do the ball detent pads look like? That is the place that really wears and causes the ring to not travel foward and stop the gear in time.
AEM Factory Trained Tuner
91VR4 Black-5027s-3.0L-Stock heads and Cams- 770AWHP 670AWTQ uncorrected 33psi E90 Daily Driver
T4 AWD 9.21 @ 154.98
T2 FWD 10.19 @ 140.31
T2-820FWHP 3.1L 27psi C16
91VR4 Red-17Gs w/supporting mods-sold
93SLTT/T2
91VR4 Pearl White-sold
91VR4 Black-sold
92VR4 Sandstone-sold
94VR4 Green-sold
93VR4 Pearl White-sold
NG09 Title Sponsor
3SX Performance
3SX Performance Service Email
Old 05-11-2008, 06:30 AM   #13 (permalink)
3Sfever's Avatar
Drives: '91 Stealth TT
3Sfever Level 43Sfever Level 43Sfever Level 43Sfever Level 43Sfever Level 4
How the heck did I miss this thread???? . . . Many of my questions would have been answered here.
Oh, , I did notice some marks on the backs of the rings . . . now this is starting to make sense, how these things work. (I think) . . .
I will go take some pictures of that.
Thanks guys!
-Ron
'91 Stealth TT
purchased Aug 2004
3Sfever is offline   Reply With Quote
Old 05-11-2008, 07:26 AM   #14 (permalink)
3Sfever's Avatar
Here are what my detent pads look like. Again, 3rd gear (top) is clearly in worse shape than 4th.
It is interesting, I took these pictures to show the detent pad, but the second picture clearly shows wear on the teeth of friction ring, as mentioned in mynamiseli's thread.
I thought I would mention again, these are steel rings, even though the color is more like brass/bronze.
