Old 10-25-2007, 02:57 PM   #11 (permalink)
1fstascar's Avatar
Drives: Just a V6.
1fstascar is an unknown quantity at this point
Default Re: How do I bullet-proof my Drivetrain?
Sorry off topic but are you moving here to Jacksonville NC?
Originally Posted by Yume View Post
I think at this point, financially, I'll have to go with a stock replacement. I need my car running for the Littleton, MA to Jacksonville, NC trip. With the new clutch and flywheel, and the fact I haven't driven her in SO LONG (1 year) I 'm not gonna beat on my car at all...
So, now I have to figure out, 18 or 25 spline, big or small input sleeve, correct?
"Mustangs are like tampons, every Pus*y has one"
1fstascar is offline   Reply With Quote
Old 11-07-2007, 07:59 PM   #12 (permalink)
DarkHeroKOTRAJ's Avatar
Drives: 1993 3000GT VR4
DarkHeroKOTRAJ is an unknown quantity at this point
Cool Re: How do I bullet-proof my Drivetrain?
Just an FYI for any one else that reads this post... You most defently want to upgrade your transfer case with the steel setup other wise yours will look like mine:
http://www.macross-plus.com/carp/getrag-broken.jpg
I broke mine on the third day of running 18psi around town (Note my tran and transfer have 100K on them but EVERY thing else is new under 7K miles on it) and it was not even a hard launch. Luckly I caught it right after I did it (could smell the redline fluid.) Anyways getting my parts from 3sx on friday and I am going to order a Maximal Performance brace as well just in case...
Happy racing
David P.
Savannah, GA
1993 3000GT VR4 :: Mods :: New Short Block, APR Head Studs, Multi Layer Head Gasket, Port/Polish Heads, 560cc Lancer Injectors, 15G Turbos, 3.5 GM MAF With Translator, Dejon Blow Though Pre Turbo Pipes, 36x14x3 FMIC, 3inch Custom intake, 255 Walbro fuel pump hot wired, Fuellab Fuel Pressure Regulator, Precats removed, Greddy Type-RS BOV, Greddy E-01, AEM Wideband Air/Fuel, Fidanza Aluminum Flywheel, SPEC Stage 3 Plus Clutch, All sensors replaced, and some other stuff
DarkHeroKOTRAJ is offline   Reply With Quote
Old 11-13-2007, 09:05 AM   #13 (permalink)
Breaks all but Xfer case
flyman1981's Avatar
Drives: 08 RAM HEMI, 93 VR-4
Trader Rating: (7)
flyman1981 is an unknown quantity at this point
I have a NoCar Xfer case and haven't had an issue yet. I dont know if he is making anymore or not, but thats another option.
CFDS will also help take the shock adn stress away from your xfer case. Solid/poly mounts will help from pinching the xfer case when you launch.
Black 93 VR-4
12.60 @ 108 w/ 9b's, 550's BlowThrough MAFT and E-Manage
11.77 @ 123 w/ 14b's (22psi), FMIC, MAFTPRO, 650's
??.?? @ ??? w/ 14b's (26psi)
??.?? @ ??? w/ 14b's (24psi) + NOS (35shot)
Show and Go:
98 rear garnish, EGR block off plates, Intrax, JayVR4 control arms, 1-4 Syncros, Kormex output shaft, RPS MAX Street Disc, Resurfaced Flywheel, ATR Downpipe, HKS SQV, Dejon dual intakes, AEM Wideband, mobo shift/ebrake boots, Battery Relocation, MAFT PRO, 14B Turbos, DNP TDO5 Headers, Tial Wastegates, DNP FMIC, P+P Heads, 99 Lifters, Vac Reduction, 98 Body kit, 94 Robot headlights, Ross Pistons, Balanced Crank, 720cc's, IPO FPR w/ Gauge, Flexalite fans, Boost a Pump, ARP Head Studs, CF 575 Hood, 50HP NX Wet Kit, NOCAR Xfer Case, Veilside CF spoiler, ACPT CFDS, 19x9 SSR D5R, Blitz SBC-ID, Prosport gauges, Boomslang harness, Corbeau LG1's, Yogurt's 4" cat-back, dual feed fuel system
flyman1981 is offline   Reply With Quote
Old 11-13-2007, 09:14 AM   #14 (permalink)
Spartan for Life!
aaronatstate's Avatar
Drives: A Dodge Import.
aaronatstate Level 7aaronatstate Level 7aaronatstate Level 7aaronatstate Level 7aaronatstate Level 7aaronatstate Level 7aaronatstate Level 7aaronatstate Level 7aaronatstate Level 7
The stainless steel transfer case is for 25-spline and late 18-spline transfer cases only. It's the big bearing housing. If you have your original TC from a build date of 1990 you do not have a big bearing 18-spline or a 25-spline TC. The best thing to do would be to get a 300M shaft, and a TC bracket.
aaronatstate is offline   Reply With Quote
Old 11-14-2007, 10:35 PM   #15 (permalink)
91 RT/TT
EvanH's Avatar
Drives: 91 RT/TT
EvanH is an unknown quantity at this point
I am looking into the same thing. what I gather from this is the front and mid housing are the weak parts of the 18/25 spline 5 spd, and the rear section is fine? Along with adding the Tcase bracket? It should be good, or is the rear section weak as well?
EvanH is offline   Reply With Quote
Old 11-17-2007, 02:54 PM   #16 (permalink)
I'm a Troll
rotneM sliveD is an unknown quantity at this point
Nice thread! Sub'ed
rotneM sliveD is offline   Reply With Quote
Old 11-17-2007, 03:14 PM   #17 (permalink)
rock on, yeah rock on
spfan's Avatar
Drives: 4 x 22,000 lbs jets
Trader Rating: (6)
spfan is an unknown quantity at this point
the front and mid housings are the only parts that have an aftermarket replacement. some believe the tail section will now take more abuse than it has previously seen (due to the newer parts) and will break sooner than it would before. it may have been the strongest of the three originally, but now it's the weakest part (assuming you have the front and mid housings) and some believe that the new parts will actually make the tail section fail sooner. i personally am not sold on the idea yet since there's not a lot of data out there, but i can see how the idea makes some sense.
Dyno Collection Thread
1993 Dodge Stealth ES, White, April 2002 - April 2005, SOLD 1 of 53
1993 Dodge Stealth TT, Black, Since April 2004, 1 of 5 ever made more rarity info
2003 Subaru Forester 2.5X, Blue, Sept. 2005, Daily Driver with 165 HP of Fury! At least it's AWD.
305 awhp, 325 awtq(BPU minus full catback exhaust)Mods at that time
13.02@104.67 (9bs, dp, fipk, 15.5 psi, bov, no cats, streetmax clutch, 1.77 60', decent conditions, full weight (even spare tire/jack)
13.09@105.08 (1.80 60', same conditions as above)
Beyond BPU: (meaning upgraded turbos/fuel/etc) before engine rebuild Mods at that time
12.38@113.00(20 psi, 110 octane, massive knock above 6k rpms)
12.41@115.10(ditto)
After Rebuild: Current Mods Dyno Tune by IPS
12.8@108 (12.5 psi dropping to ~11 @redline, 2.0 60', pump gas, my tune)
spfan is offline   Reply With Quote
Old 11-19-2007, 06:44 PM   #18 (permalink)
I personal don't believe that it will weaken the tail due to all the stress is on the output shaft not on the housing UNLESS you have failing barings (and if this was the case it would be because the shaft is shifting around/not staying strait.) If you have opened up the tail, it is only bolted to the mid section which is where all the output parts are compressed to.
David P.
Savannah, GA
1993 3000GT VR4 :: Mods :: New Short Block, APR Head Studs, Multi Layer Head Gasket, Port/Polish Heads, 560cc Lancer Injectors, 15G Turbos, 3.5 GM MAF With Translator, Dejon Blow Though Pre Turbo Pipes, 36x14x3 FMIC, 3inch Custom intake, 255 Walbro fuel pump hot wired, Fuellab Fuel Pressure Regulator, Precats removed, Greddy Type-RS BOV, Greddy E-01, AEM Wideband Air/Fuel, Fidanza Aluminum Flywheel, SPEC Stage 3 Plus Clutch, Steel front and mid transfer case upgrade, All sensors replaced, EGR block off, 3sx engine mounts, and some other stuff
Old 11-19-2007, 09:32 PM   #19 (permalink)
Paid Member
NoBrakes's Avatar
Drives: 92 VR4
NoBrakes is an unknown quantity at this point
What are the tell tale signs of a worn output shaft? I have noticed when I take my foot off the clutch after I have shifted I get a clunk or thud. When I try to release the clutch slowly, it engages smoothly. Could this be from my output shaft starting to strip, or do I just need to learn how to drive a stick? I thought at first that it could be worn motor mounts with excessive play, but I just threw on Maximal's solid mounts and it still does it.
93 Mustang GT, white 5spd- broke tranny, traded for:
91 Galant VR4, belize green 1189/2000 - broke tranny, sold
02 Focus SVT, black 3 door - drove it like I stole it for a month and traded for:
00 Mustang GT, dark red 5spd - a year of burnouts and donuts, sold
92 3000GT VR4 - safe for now
NoBrakes is offline   Reply With Quote
Old 11-30-2007, 06:38 AM   #20 (permalink)
Ask me about Getrag's!
DarkHelmet's Avatar
Drives: Space ball one
Trader Rating: (11)
DarkHelmet is an unknown quantity at this point
Originally Posted by aaronatstate View Post
The stainless steel transfer case is for 25-spline and late 18-spline transfer cases only. It's the big bearing housing. If you have your original TC from a build date of 1990 you do not have a big bearing 18-spline or a 25-spline TC. The best thing to do would be to get a QUADCO shaft, and a TC bracket.
fixed that for ya
DarkHelmet is offline   Reply With Quote
