Old 10-19-2007, 08:42 PM   #1 (permalink)
Yume is an unknown quantity at this point
Default How do I bullet-proof my Drivetrain?
'91 VR-4 (built 8/8/1990)
My Output shaft is about done. So, now what can I do about it?
I am lost in the confusion of the 18 or 25 spline, what part is what and how to have a set-up that will last me street and strip time... Any answers from anyone?
Yume: Translated as "dream" in Japanese
1991 MITSUBISHI 3000GT VR-4 BLACK
2111/US Marine Corps, SOI EAST
Photobucket
Yume is offline   Reply With Quote
Old 10-19-2007, 10:49 PM   #2 (permalink)
wytaco's Avatar
Drives: 91 vr4, 04 tacoma
wytaco is an unknown quantity at this point
Default Re: How do I bullet-proof my Drivetrain?
Upgrade to a 300m outputshaft and get a tcase bracket. You should look at getting some poly or solid motor mounts also. If you have the money get all of the above with the cast steel tcase from lse.
wytaco is offline   Reply With Quote
Old 10-20-2007, 08:10 PM   #3 (permalink)
Being a 91, with an early production date (1990), can I switch from the 18-spline to the 25 spline? That means I get the new t-case shaft sleeve, and the new output shaft?
Who makes the transfer case? Links? I know of 3SX's stainless steel front and mid section replacements. Who also makes the bracket?
Old 10-20-2007, 08:12 PM   #4 (permalink)
Fool...No man can kill me
JasonY's Avatar
Drives: -tee-dee-oh-fived-
Trader Rating: (25)
JasonY Level 5JasonY Level 5JasonY Level 5JasonY Level 5JasonY Level 5JasonY Level 5
300M OS, with the steel front and mid case is about as solid as you can get.
Jason
"Busting your butt doesn't guarantee success but sitting on your butt will pretty much guarantee failure"
Quality parts and service from I.P.S. And yeah, ^^^ is a real one...
2001 Silver Dodge Ram/Cummins diesel - tow vehicle for ^^^
JasonY is online now   Reply With Quote
Old 10-20-2007, 09:16 PM   #5 (permalink)
wytaco's Avatar
lse performance carries the t-case
maximal performance has a t-case bracket
Supercar engineering has the outputshaft
Old 10-20-2007, 11:43 PM   #6 (permalink)
I think at this point, financially, I'll have to go with a stock replacement. I need my car running for the Littleton, MA to Jacksonville, NC trip. With the new clutch and flywheel, and the fact I haven't driven her in SO LONG (1 year) I 'm not gonna beat on my car at all...
So, now I have to figure out, 18 or 25 spline, big or small input sleeve, correct?
Old 10-23-2007, 08:11 PM   #7 (permalink)
Drives: '91 VR4 - RIP
Trader Rating: (13)
The cheapest and most reliable thing to do is to buy an 18 spline 300m OS. If you do a 25 spline conversion I think you are going to need the 25 spline VCU & planetary, as well as the 25 spline transfer case spool. Somebody please correct me if I'm wrong.
Old 10-24-2007, 07:27 AM   #8 (permalink)
No more DSM...
DSM Performance's Avatar
Drives: 91 TT Stealth
DSM Performance is an unknown quantity at this point
This is probably what I'm gonna do actually, but however I have a question, does the Tcase from LSE is a full tcase or only the housing ?
Because LSE sells their Tcase 1K$, and 3SX sell the front and mid housing for 1250$... so what's the catch ?
thanks
DSM Performance is offline   Reply With Quote
Old 10-24-2007, 10:29 AM   #9 (permalink)
rock on, yeah rock on
spfan's Avatar
Drives: 4 x 22,000 lbs jets
Trader Rating: (6)
spfan is an unknown quantity at this point
thanks
the LSE and 3sx tcase are the same thing. LSE did the r&d and sold them originally, and 3sx now resells them. it is just the front, main housing. unless you also get the mid housing. then you will still reuse your stock tail end of the tcase. it is JUST the housing, none of the innards. you can also get the mid housing through the place LSE had make them. at least you could as of a few months ago.
Dyno Collection Thread
1993 Dodge Stealth ES, White, April 2002 - April 2005, SOLD 1 of 53
1993 Dodge Stealth TT, Black, Since April 2004, 1 of 5 ever made more rarity info
2003 Subaru Forester 2.5X, Blue, Sept. 2005, Daily Driver with 165 HP of Fury! At least it's AWD.
305 awhp, 325 awtq(BPU minus full catback exhaust)Mods at that time
13.02@104.67 (9bs, dp, fipk, 15.5 psi, bov, no cats, streetmax clutch, 1.77 60', decent conditions, full weight (even spare tire/jack)
13.09@105.08 (1.80 60', same conditions as above)
Beyond BPU: (meaning upgraded turbos/fuel/etc) before engine rebuild Mods at that time
12.38@113.00(20 psi, 110 octane, massive knock above 6k rpms)
12.41@115.10(ditto)
After Rebuild: Current Mods Dyno Tune by IPS
12.8@108 (12.5 psi dropping to ~11 @redline, 2.0 60', pump gas, my tune)
spfan is offline   Reply With Quote
Old 10-24-2007, 03:24 PM   #10 (permalink)
No more DSM...
If I understand well the research I've made, the t.case bracket and the upgraded housing are mostly usufull if I want to launch the car. There is little chance (still possible I gess) to break the t.case on highway pulls ?
In my case my car is for the street only with no intention to drop the clutch ever. I'm upgrading to 15Gs only.
Thanks for the info.
