Old 08-19-2008, 01:57 PM   #1 (permalink)
'92 VR4
ras463us's Avatar
Drives: 1992 VR4
Trader Rating: (13)
ras463us Level 3ras463us Level 3ras463us Level 3ras463us Level 3
Default Help! No 5th or Reverse - 5 Speed
Like the title states I have a freind with a 91 VR4 that has no 5th or reverse.
The shifter goes into place but there is nothing there. This issue developed after the tranny was removed for an engine swap.
Ricer: from the latin word Ricarius meaning to suck at everything you attempt
A person who makes unnecessary modifications to their most often import car (hence the term "rice") to make it (mostly make it look) faster. The most common modifications are (but not limited to):
- Huge exhaust that serves no purpose but to make the car louder
- Large spoiler on the back that looks like something Boeing made for the 747
- Lots of after-market company stickers they don't have parts from, but must be cool
- Expensive rims that usually cost more than the car itself
- Body kit to make the car appear lower, usually accented with chicken wire
- Clear tail lights and corner signals
- A "performance intake"- a tube that feeds cold air to their engine usually located in areas of excessive heat (behind or on top of the engine)
- Most of these riced cars (a.k.a. rice rockets or rice burners) are imports; Honda Civics, Accords, Integras, CRXs, RSXs, Del Sols Mitsubishi Eclipses, Lancers, Subaru Imprezas, however there are some domestics such as Chevrolet Caviliers, Dodge Neons, Ford Focus; small, slow, economy cars designed specifically to go slow. Please note that some 3000gt's Supras, Skylines, WRX's and other higher performance imports are designed to go fast, and are therefore not always considered rice, but it really depends on the severity of the case.
(courtesy urban dictionary)
ras463us is offline   Reply With Quote
Old 08-19-2008, 03:26 PM   #2 (permalink)
Born In Italy
italiano3kgt's Avatar
Drives: 1993 3000gt vr4
italiano3kgt is an unknown quantity at this point
Default Re: Help! No 5th or Reverse - 5 Speed
check all the linkage.. make sure that the lower coolant hose is out of the way as much as possible. did you take the trans apart?????
She love's the way i drive her!!!!
italiano3kgt is offline   Reply With Quote
Old 08-20-2008, 11:33 AM   #3 (permalink)
jackstransmissions.com
JackM is an unknown quantity at this point
Sounds like the fork pin backed out of the rail for 5th/R...
Jack
www.jackstransmissions.com EVO VIII, DSM, 3S tranny rebuilding.
JackM is offline   Reply With Quote
Old 08-20-2008, 01:52 PM   #4 (permalink)
'92 VR4
ras463us's Avatar
Drives: 1992 VR4
Trader Rating: (13)
Jack
Thanks Jack, I was hoping you would drop in.
I was also thinking that it would be a shift fork issue. FYI the car drives and shifts just fine in 1st through 4th, and the engine swap included the tranny, so it was actually an unknown and the donor car had taken a front end hit.
Is this a servicable issue? How deep into it would I have to go to replace the rail and fork assembly? From the details in the manual it would appear that the bell housing and center case would need to be removed to gain access. If that is the case, would it be safe to open it up replace/fix the broken rail/fork and put it back together?
Old 08-20-2008, 10:29 PM   #5 (permalink)
Stealth Like A Ninja
Darksurfr's Avatar
Drives: '91 Stealth TT
Trader Rating: (14)
Darksurfr is an unknown quantity at this point
haven't ever looked at the end of a AWD trans but the FWD the 5th gear fork is in its own 7 bolt cover on the end of the transmission so to service it you just go into the passenger side wheel well and take off the cover and go at it. something tells me its not that easy with the AWD transmissions. I don't think i remember seeing a 5th gear service cover on it
ECG '05- '08 / Attended NEG '05 - '08 / Attended
Darksurfr is offline   Reply With Quote
Old 08-21-2008, 09:16 AM   #6 (permalink)
Dont Make Me Lose My Mind
Dakken's Avatar
Drives: 92 Stealth RT TT
Dakken Level 7Dakken Level 7Dakken Level 7Dakken Level 7Dakken Level 7Dakken Level 7Dakken Level 7Dakken Level 7Dakken Level 7
I would not recommend trying to pull the shift forks out of a 5 spd AWD tranny with it on the car. You would have to take the input shaft and intermediate shaft out with the shift forks. They may come out but it would be hell getting everything lined up again for the reinstall.
In theory, you can disassemble the whole transmission and leave the bell housing attached to the engine. I don't know of anyone that has done that but I think it would be more trouble than it is worth.
Dakken is offline   Reply With Quote
Old 08-21-2008, 12:57 PM   #7 (permalink)
I think the fork is fine, you just have a pin that backed out. I would just remove the trans end-cover with the unit in the car and take a look. If the pin is backed out I would just pull the pin and replace it with the fork in place and pop the cover back on.
Note the cover is tricky as the input shaft is pressed to it. so removing and installing it can be difficult.
Jack
Old 08-21-2008, 01:13 PM   #8 (permalink)
'92 VR4
ras463us's Avatar
Drives: 1992 VR4
Trader Rating: (13)
Jack
Would a little bit of heat help loosen the hold on the input shaft and make diassembly easier? I see they recomment preheating the outerbearing and case prior to reassebly.
Thanks again. I think it just might be worth the time to try it. Worse case is that I have to pull the whole tranny.
Old 08-22-2008, 10:37 AM   #9 (permalink)
When we have a hard time pulling them apart here, heat doesn't seem to help. Just pulling on the cover evenly and being careful not to damage the case is really all you have to worry about.
Jack
