#1 (permalink) |
Ok, yeaha I know that its expensive to work on, but I do need it. My tranny is a pain and I have some other stuff I need to put on also. I just wondering that: Is there anyone willing to lend me a hand to fix my tranny?--Maybe just a cheap fix....to get it rolling again.
![]() ![]() [IMG] |
#2 (permalink) |
Here for the tuna.
Ouch. Everything else looks decent though. If you were closer to PA I'd love to help you rebuild it.
![]() I actually may have one of those for sale, if you want it: http://www.3si.org/forum/f4/6spd-shi...arness-413847/ Actually looking at it, that looks like your 5-6 fork ... dude how did you do that!
2002 WJ -- 1994 VR-4 -- 1993 ZJ --Canon Rebel XTi ![]() |
#3 (permalink) |
I broke it by "doing the one-thing we should never ever do"-Powershift!! I only did it once, and next day it broke-off without a warning.
~5/6th shiftfork is broke (might torch weld it) ~cheap fix: up to ~$1000 (all syncros, throw-out bearing, clutch disc & mics) |
#4 (permalink) |
Update: Well!, Its final, I will be towing my car home with no tranny. My car will be put to sleep
I wish that I could finish this and move on, but oh well someday it will be back.....and with a built trany & mics parts. As for SCE---"Stay working on those trany projects/products, I'll be ready someday." ![]() Last edited by ACZEP : 04-22-2008 at 05:53 PM. Reason: edit |
#6 (permalink) |
Update 2: I'd noticed a small crack on my bellhousing, where the big inter-
bearing located at. I got it all packed-up a ready to go....home. The car ran fine before this happened. I "thinking" about selling parts off my tranny...but IDK! I'm stuck borrowing my moms car that gets horrorable gas milage then my Stealth! My wheel hubs are bad~brake rotor wouldn't come off!! Lug studs possibly bent-in & rubbing against rotor! My exhaust system is rusted, needs new, but I have a 4" muffler. Paint is cracking off where its flex. Has minor surface rust issue on some suspension area, it can be sanded of blasted off. Needs cleaning & repainting on the underbody chassis to prevent rust. ~Alot of small stuff, but It can be done! Just need time & money....It will be like new!! ![]() |
