Old 12-19-2007, 06:23 AM   #11 (permalink)
SerebReal's Avatar
Drives: '95 VR4
SerebReal is an unknown quantity at this point
Default Re: Hard to shift into 1st or 2nd when cold?
Hey guys, good to hear I'm not alone, I feel better about this.. and I'll add checking/changing the fluid to the list of to-do's. Thanks!
SerebReal is offline   Reply With Quote
Old 12-19-2007, 11:33 PM   #12 (permalink)
Certified White Boy
92stealth15g's Avatar
Drives: 1992 Stealth RT/TT
92stealth15g Level 192stealth15g Level 1
Yeah, I do. LOL! Good eye.
Haha, thanks. Thats one of the only things i have done right in my life so now i feel special. haha.
"Clutch-Eater"
-1992 Dodge Stealth R/T Twin turbo AWD, Dynamic Racing stage II heads, 99 lifters, 6-speed Getrag from 99 vr4, SPEC Stage 4 clutch, TEC 15g's, Greddy blow off valve, Dejon Powerhouse Blow-Thru Intake Pipes, DSM sidemounts, Denso fuel pump, 550cc fuel injectors, Apexi SAFC, HKS VPC, Apexi AVCR, msd ignition dis-4, MSD 8.5mm wires, NGK coppers 1 stage colder, alamo y-pipe, custom exhaust from turbos back, highflow cat, Lowered, Nitto tires.
"Knockin' Beater"
-1996 Mitsubishi Eclipse GS
92stealth15g is offline   Reply With Quote
Old 12-21-2007, 08:13 PM   #13 (permalink)
USMC
vr4_rider's Avatar
Drives: 3/S
Trader Rating: (12)
vr4_rider is an unknown quantity at this point
I so wished I Didn't drain the fluid in my tranny. It was NEVER hard to shift into second. I live it Iowa, had my car for nearly 9 years, and never had a problem shifting when it was cold...that is until I changed the fluid to GM synchromesh after reading all the good things about it.
vr4_rider is offline   Reply With Quote
Old 12-21-2007, 08:56 PM   #14 (permalink)
Certified White Boy
Why does everyone keep saying GM synchromesh is so good?! I only hear negative things about it like gear wear and bad stuff.. i would like to see where all these good things about synchromesh are?
Old 12-25-2007, 06:10 PM   #15 (permalink)
phantomrt's Avatar
Drives: fast
phantomrt is an unknown quantity at this point
Yea, -10 degrees fahrenheit is getting on the cold side! Been there many times. By the end of January, we get kinda used to it and its just like... meh, its cold outside again. Oh well.
Just use the gear oil Mitsubishi recommends. But I'd be tempted to try 15W40 engine oil in cold climates. Mine goes into 2nd with a Ca-chunk when it is cold and when it warms up after a few miles, its fine. Automatic transmission fluid may work quite well, since the synchronizers use a friction material similar to what automatic transmissions use in their clutch packs. Maybe it is hard on the VCU? I dunno.
92 Stealth R/T TT 73k
92 Daytona ES 2.5 Turbo / A523 103k
92 Lebaron GTC Conv. 2.5 Turbo / A568 158k
91 Daytona ES 3.0 V-6 / A543 190k
93 Geo Metro 1.0/5spd 126k *resurrecting*
phantomrt is offline   Reply With Quote
Old 12-26-2007, 06:35 PM   #16 (permalink)
Certified White Boy
lol, yup, thats about how it goes here. Doesnt start feeling cold unless we are in the negatives and even then its like, eh, whatever, its cold. I work at a GM dealership and we had to start all the new cars today in -15 degree weather. The cars would barely start. hah.
