Old 12-17-2007, 10:20 PM   #1 (permalink)
SerebReal's Avatar
Drives: '95 VR4
SerebReal is an unknown quantity at this point
Mitsubishi Hard to shift into 1st or 2nd when cold?
First off, forgive me if these are noob questions, but I'm brand new to MTX and AWD platform. When my VR4 is cold and not warmed up yet, shifting into second can be difficult - kind of clunk/grind goes along with the shift sometimes. Going back into first is the same deal. After a few shifts back and forth - or the car warming up a little, not sure which - it seems to shift mostly fine.
I don't know what trans fluid is in it right now, or really any of the history of this car at all. It has 75k miles, BPU stage 1 mods.
Any ideas?
Thanks!
SerebReal is offline   Reply With Quote
Old 12-17-2007, 10:27 PM   #2 (permalink)
Drives: 91' Stealth
Stelthturkey is an unknown quantity at this point
Default Re: Hard to shift into 1st or 2nd when cold?
Same thing, its normal...
Just try take it easy, and try not to downshift a lot.
Also, it's always good to let your cars sit for a bit and idle before driving them. (not that you don't know that already)
Stelthturkey is offline   Reply With Quote
Old 12-17-2007, 11:09 PM   #3 (permalink)
Robbie1902's Avatar
Drives: 92 stealth tt
Trader Rating: (11)
Robbie1902 is an unknown quantity at this point
Agree when its cold out its gonna be tough to shift just got to let it warm up a bit
Robbie1902 is offline   Reply With Quote
Old 12-18-2007, 01:04 AM   #4 (permalink)
Certified White Boy
92stealth15g's Avatar
Drives: 1992 Stealth RT/TT
92stealth15g is an unknown quantity at this point
yeah, its just because its cold. It can also have a lot to do with your tranny fluid. i think BG syncroshift II has good cold shift performace.
1992 Dodge Stealth R/T Twin turbo AWD, Dynamic Racing stage II heads, 99 lifters, 6-speed Getrag from 99 vr4, Southbend Stage 4 DXD-B Clutch, TEC 15g's, Greddy blow off valve, Dejon Powerhouse Blow-Thru Intake Pipes, DSM sidemounts, Denso fuel pump, 550cc fuel injectors, Apexi SAFC, HKS VPC, Apexi AVCR, msd ignition dis-4, MSD 8.5mm wires, NGK coppers 1 stage colder, y-pipe, borla catback, ATR downpipe, highflow cat, Lowered, Nitto tires.
In the future: intercooler hard pipes, hopefully close to 500 horsepower after a good tune.
When im rich: A second gen TD-05 VR4 monster.
92stealth15g is online now   Reply With Quote
Old 12-18-2007, 05:01 AM   #5 (permalink)
Here for the tuna.
lawdogg's Avatar
Drives: The Speed Limit
Trader Rating: (58)
It sounds normal, mine does this when I first start driving on a cold morning.
However, I would recommend draining the mystery fluid and filling with Redline fluids. A 50/50 mix of MT90 and MTX.
2002 WJ -- 1994 VR-4 -- 1993 ZJ --Canon Rebel XTi
Old 12-18-2007, 04:39 PM   #6 (permalink)
boy_genius94's Avatar
Drives: 92 vr4
boy_genius94 is an unknown quantity at this point
+1 my car doesnt do that, shifts the same warm or cold. But! I would strongly recomend you check all the fluids. Had my car checked out after I bought it and rechecked it my self after the dealer had checked it. Found out I only had at most 2 cups of fluid in the tranny!
So check all your fluids, it couldnt hurt.
boy_genius94 is offline   Reply With Quote
Old 12-18-2007, 06:24 PM   #7 (permalink)
Certified White Boy
dont you mean a 50/50 mix of MT90 and MTL?
Old 12-18-2007, 07:55 PM   #8 (permalink)
phantomrt's Avatar
Drives: fast
phantomrt is an unknown quantity at this point
No, he was talking about when its cold. Like 10 degrees Fahrenheit cold. Not 55 degrees Los Angeles morning cold.
Good idea to check the fluid level for sure... especially since these cars are old, probably leak, and the fluid level may have never been checked before. Most manual transmissions I've ever driven in a variety of cars would be tough shifting into the lower gears until the fluid circulated and got warmed up a bit. I wonder why they want 80w90 gear oil in these transmissions.... I was thinking of trying some lighter 10w 30 or something. Anyone try that? It should help in the cold. Other manual transmissions out there use 10W30 engine oil with no problems. Maybe the friction material on the synchros need it or something?
phantomrt is offline   Reply With Quote
Old 12-18-2007, 11:51 PM   #9 (permalink)
Certified White Boy
Im talking about NEGATIVE 10 degree Wyoming mornings!! hah.
Old 12-19-2007, 04:37 AM   #10 (permalink)
Here for the tuna.
lawdogg's Avatar
Trader Rating: (58)
Yeah, I do. LOL! Good eye.
