#1 (permalink) |
My friend has a '91 VR-4 with about 80k on it. He called me and told me he limped his car about a mile home after losing all clutch pedal.
We looked at it and found a nice puddle of fluid below the slave cylinder. Ordered a new one from 3SX, installed, bled the system multiple times until it was good clean and air free fluid. Right after that he is experiencing a few issues... Having to hold the pedal down for a extended period of time to shift into first. Down shifting to 3rd and 1st occasionally causes grinding and lastly up shifting into 3rd creates notchyness. We are going to work on it tomorrow, obviously starting with the least expensive first. I found a video on here by a transmission shop that explains how to properly adjust the master cylinder rod. How much success has everyone had with this? I suppose next step would be changing the fluid with redline 2.3q 50/50 mix of MTL & MT90. Any input on this would be great, thanks. |
#3 (permalink) |
Breaks all but Xfer case
he is probably out of clutch fluid and its not disengaging the clutch enough to let the syncros work. try refilling it, bleeding the lines and adjusting the master cyl screw just above teh clutch pedal under the dash.
FYI - small adjustments on the master screw! it makes pretty big changes.
![]() Black 93 VR-4 12.60 @ 108 w/ 9b's, 550's BlowThrough MAFT and E-Manage 11.77 @ 123 w/ 14b's (22psi), FMIC, MAFTPRO, 650's ??.?? @ ??? w/ 14b's (26psi) ??.?? @ ??? w/ 14b's (24psi) + NOS (35shot) Show and Go: 98 rear garnish, EGR block off plates, Intrax, JayVR4 control arms, 1-4 Syncros, Kormex output shaft, RPS MAX Street Disc, Resurfaced Flywheel, ATR Downpipe, HKS SQV, Dejon dual intakes, AEM Wideband, mobo shift/ebrake boots, Battery Relocation, MAFT PRO, 14B Turbos, DNP TDO5 Headers, Tial Wastegates, DNP FMIC, P+P Heads, 99 Lifters, Vac Reduction, 98 Body kit, 94 Robot headlights, Ross Pistons, Balanced Crank, 720cc's, IPO FPR w/ Gauge, Flexalite fans, Boost a Pump, ARP Head Studs, CF 575 Hood, 50HP NX Wet Kit, NOCAR Xfer Case, Veilside CF spoiler, ACPT CFDS, 19x9 SSR D5R, Blitz SBC-ID, Prosport gauges, Boomslang harness, Corbeau LG1's, Yogurt's 4" cat-back, dual feed fuel system |
#4 (permalink) |
Maybe it was flexible line to start with, not slave?
94 3000GT VR4 (upgraded)
"Your 1994 Mitsubishi 3000GT VR-4 is one of 1650. There are 57 other cars that were made with both the same interior and exterior color. Exactly Identical - 8" For sale: 1. used A/C belt (10K on the belt) 2. Stock front and rear sway bars. 3. 3SX dual O2 simulator 4. Used 2'' couplers/reducers/hump hoses 5. Used stock flywheel |
