Old 01-27-2008, 06:41 PM   #941 (permalink)
Super Member
Boostaddict's Avatar
Drives: First e16g 3/S
Trader Rating: (37)
Boostaddict is an unknown quantity at this point
Default Re: Getrag 440/446 parts.
This has already been discussed. The only way to compare actual shaft properties (other than software modeling) would be to destructively test one of each shaft. No one is going to destroy $1000 of product and pay another $1000 to have the testing done. Charpy, tensile, or any other mechanical test would not be relevant on a carburized part. A properly carburized alloy shaft will always out-perform a through-hardened alloy shaft, so I'll place my money on the NBT product...
Originally Posted by AlmosN8kd View Post
Even though they are different processes, you can still compare them. Has there been any destructive testing (Charpy V-notch test, Nil Ductility transition test, drop weight test, etc; yes, I know these are unlikely) done on the two materials to give a strength yeild? I know the corrosion resistant coating is a bonus but how much rusting do you really have on the splines of your stock output shafts? I know I have some small amount but it is minimal so I'm not sure the corrosion inhibiter is absolutely necessary. To be quite honest, I'm not really sure which to go with, the Mark Williams output shaft is more widely available (easy to find at Supercar) but then I've heard a lot of good things about NBT; price is a concern but I'd rather just go with the better of the two.
Quaife Front LSD for AWD
Ksport Suspension Kits
Specializing in 3/S Suspension, Billet Transmission Shift Forks, 300M Output Shafts, Front AWD and FWD LSD, Transmission Rebuild Parts, STOPTECH Brake Kits, Big Reds, and Custom Brake Upgrades! More Products to Come.
1993 3000GT-VR4: AEM EMS, etc
663 awhp, 607 tq (retired tdo5-e16g's)
10.835@132.69 -26psi
Boostaddict is offline   Reply With Quote
Old 01-27-2008, 06:49 PM   #942 (permalink)
The New Super Pimp
maddog's Avatar
Drives: FASTER THAN VIPERS
Trader Rating: (7)
maddog Level 1maddog Level 1
I dont know how much salting they do is WA but in Chicago, Detroit, and other places the salt does a number on the output shafts. NBT being from Detroit have first hand experience into why the research was done.
93 Sandstone VR4
11.66 @ 117.48mph with Maddog Performance Engineering 13T's
This weeks specials:
CUSTOM RUBBER INTERCOOLER PIPING AT 50% OFF!!!
28 HOUR ENGINE REBUILD ONLY $700
maddog is offline   Reply With Quote
Old 01-27-2008, 07:07 PM   #943 (permalink)
Forest Gump
cbehnken's Avatar
Drives: 1992 Stealth TT
Trader Rating: (42)
cbehnken Level 7cbehnken Level 7cbehnken Level 7cbehnken Level 7cbehnken Level 7cbehnken Level 7cbehnken Level 7
If you have a 25 spline I'd go with the northbend stuff just to support their research.
For us 18 spliners M.W. is/was our only choice.
Power: DSM 13G/DR650 Combo, DSM 450 cc bluetops MAXED out, SAFC I, K&N, Ebay Downpipe, ATR Dual Catback,
no cats, DN Y-Pipe, Polished Plenum and Valve Cover, HKS SSQV, HKS EVC 5 at 14.5PSI, Walbro 255 with AN Bulkhead
Suspension: KYB GR-2 - Tein S-Techs, Crossdrilled/slotted rotors, 17" chromies, Nitto 555s
Drivetrain: RPS Street Max, M.W. 300m O/S
Etc: Smokinvr-4 Corner box, 10" Rockford Fosgate Punch sub, Eclipse Headunit
Leatherseats.com Charcoal/Dove Grey Interior, 99 front end/lights/wing
Maintenance New VSS, all 60K stuff, new 1st,2nd, 3rd syncro, trans seals, oil pump, rod and main bearings.
JEDI MASTER SAFC NARROWBAND BASED TUNER, LORD OF THE DANCE ALSO
cbehnken is online now   Reply With Quote
Old 01-27-2008, 07:54 PM   #944 (permalink)
TPW: The Prophet
AlmosN8kd's Avatar
Drives: without wearing much
Trader Rating: (40)
AlmosN8kd is an unknown quantity at this point
My car is a NY car which has been exposed to salt for most of it's life. The underside of my car is fairly rusted as a result and despite it's life in the various states in which I've lived the output shaft doesn't have an appreciable amount of rust.
AlmosN8kd is offline   Reply With Quote
Old 01-27-2008, 07:57 PM   #945 (permalink)
TPW: The Prophet
AlmosN8kd's Avatar
Trader Rating: (40)
I have a 6 speed so I have some options.
Old 01-27-2008, 08:02 PM   #946 (permalink)
TPW: The Prophet
AlmosN8kd's Avatar
Trader Rating: (40)
I guess I'm just not familiar with the carburized process to really understand. I have some experience with destructive testing and despite the fact that it is expensive it does prove which alloy/process is better. Anyhow, I'll take a better look at the NBT shaft; I just want to make sure I get the better piece is all. Out of curiousity, where does one buy a NBT output shaft? I'm pretty sure the 25 spline group buy is probably closed by now.
Old 01-29-2008, 08:32 AM   #947 (permalink)
Drive it hard
Theo_VR4's Avatar
Trader Rating: (14)
Theo_VR4 is an unknown quantity at this point
Has anyone else gotten the end case input shaft bearing from applied?
They said they had the 57497 one and couldn't find a listing for the 6405C3 number. So I got the first one, it's the same size however mine has a beveled edge where it sits under that plate that bolts on top of it and the new one didn't. They took it back no problem but just wondering if anyone knows how to get the correct one?
Theo_VR4 is offline   Reply With Quote
Old 02-17-2008, 12:09 PM   #948 (permalink)
coz
Drives: 3000GT
coz is an unknown quantity at this point
My first find =)... almost...
I google:d 040.8.0051.10 (1-2 synchronizer outer ring) and found that this getrag number is also in a transmission called F-28.. wich can be found in Opel Calibra Turbo 4x4, (vauxhall vectra)
11,7 sec. with td04HL 16T 7cm2 (on e85)
xx,x sec. with twin Holset HX-35 (still on e85)
coz is offline   Reply With Quote
Old 02-22-2008, 09:14 AM   #949 (permalink)
Gear Head
Bret Brinkmann's Avatar
Drives: Rear wheels only...
Bret Brinkmann Level 3Bret Brinkmann Level 3Bret Brinkmann Level 3Bret Brinkmann Level 3
Just edited the first post again. I included the new part suppliers mentioned previously and updated what each vendor supplies.
Theo VR4 - I know we have one of the OEM bearings brand new in stock at 3SX if you are having trouble locateing one. We have the alternitive number ordered but it has not come in yet. We currently have quite a few new and used parts in stock.
250 RWHP
Old 02-22-2008, 10:08 AM   #950 (permalink)
Trader Rating: (6)
1997GTX is an unknown quantity at this point
I know this isn't the best thread to post "what I need" information, but I'm desperately looking for a 2nd gear synchro and slider and 3rd gear slider for a 92 18-spline VR4 if anyone can help out.
Thanks!
--Adam
97 Black Grand Prix GTX Supercharged -- well modded
97 Black VR-4 -- Borla TT Cat-Back, 3SX DP & Cat, K&N FIPK, Greddy Type-S BOV and Adapter, ProBoost MBC, Cobalt Boost Gauge, Stealthify Blue Needle Glow Kit
Project Underway:
92 VR-4 w/ new motor, dr-650r's, Stage 3 Heads, Spearco FMIC, Greddy E-Manage w/ Profec E01, W/M Injection, 720cc's, Carbon/Carbon clutch, etc ... Needs Tune ... FOR SALE FOR SALE
2002 Audi S4 - Just a chip =)
1997GTX is offline   Reply With Quote
