Old 04-11-2004, 09:57 AM   #81 (permalink)
Drive it hard
Theo_VR4's Avatar
Trader Rating: (14)
Theo_VR4 is an unknown quantity at this point
Default Re: Getrag 440/446 parts.
Originally Posted by ifithas2be
On a side note:
A member of my club is in dire need of an input shaft bearing, can anyone help. Cant find the part anywhere.
CRS Doesn't have a bearing? I ordered both input shaft bearings a couple weeks ago no problem.
Theo_VR4 is offline   Reply With Quote
Old 04-11-2004, 01:35 PM   #82 (permalink)
3SNY President
ifithas2be's Avatar
Drives: 91 VR4
ifithas2be is an unknown quantity at this point
called CRS & Kormex no part
3000GT STEALTH CLUB of NEW YORK
ifithas2be is offline   Reply With Quote
Old 04-11-2004, 02:06 PM   #83 (permalink)
POLYCHRONOPOULOS
RobBeck's Avatar
Drives: On 1 Wheel
Trader Rating: (223)
RobBeck is an unknown quantity at this point
Damn that is most likely the most important and exposed to extensive wear bearing we have in the trans... I certainly hope this is not Out of stock to.
Is there any chance someone is holding out on us?
Rob
RobBeck is offline   Reply With Quote
Old 04-12-2004, 02:57 PM   #84 (permalink)
Gear Head
Bret Brinkmann's Avatar
Drives: Rear wheels only...
Bret Brinkmann Level 4Bret Brinkmann Level 4Bret Brinkmann Level 4Bret Brinkmann Level 4Bret Brinkmann Level 4
CRS still does remans for Mitsu. I don't know if they deal witht he general public in such matters. I'm still waiting for a responce from Getrag. I called thema while ago and again today. They are hard to get a hold of. Unless the input shaft bearing/seal is leaking I wouldn't worry about it. They are usually pretty long lasting.
250 RWHP
Old 04-12-2004, 03:04 PM   #85 (permalink)
The Chaosbringer
Gatecrasher's Avatar
Drives: 81 Fiat Panda
Trader Rating: (7)
Gatecrasher is an unknown quantity at this point
I thought all of the bearings in the trans were generic metric bearings? Every one that I've seen says Timken on it. Is the input bearing different?
Gatecrasher is offline   Reply With Quote
Old 04-12-2004, 04:22 PM   #86 (permalink)
POLYCHRONOPOULOS
RobBeck's Avatar
Drives: On 1 Wheel
I think that the input shaft bearing could NOT long lasting... especially with our cars. I have personally changed one of them in a DSM... with about 130k miles on it (I still have it if you want pics). It is thrashed and in a daily driven economy car. The problem with it is that the snout of the shaft does not ride in the rear of the crankshaft (maybe less important with transverse mounted engines ), and without that there is no real support for the input shaft aside for that bearing... and I bet you could imagine the forces that go thru that. Not that I would arbitrarily replace it, but I definitely would check it and not assume to be ok, even if there is little to no leaking from the seal.
Gatecrasher I would think it is just a common bearing, but seeing since it is Getrag who knows.
I spoke with TurboJJ today on the phone, talking about this issue... and he said that he HEARD that our trans has the same guts as the 911 6 speed Turbo... anyone know if thats true or how to confirm or deny it?
Rob
Old 04-13-2004, 05:30 AM   #87 (permalink)
Warning: I'm an asshole
SkortchGT's Avatar
Drives: 1992 3000GT VR4
Trader Rating: (10)
SkortchGT Level 7SkortchGT Level 7SkortchGT Level 7SkortchGT Level 7SkortchGT Level 7SkortchGT Level 7SkortchGT Level 7SkortchGT Level 7
Rob
Thats very interesting....I wonder if our 5spds have the same guts also....
1992 3000GT VR4
--Completely rebuilt 5/06-4/07. Everything new. For a list see: http://www.3si.org/forum/showthread.php?t=372579
--First time on dyno: 364AWHP@16psi with a 10.3AFR (now tuned at 11.4-11.6 with timing control, time for another dyno run soon)
--Mods: DR Stage I heads, 3rd gen lifters, TD04L 13Gs, DSM SMICs, PTE 550s, Apexi SAFC, Apexi SITC, Walbro FP, IPO hotwire, Robbeck adapter & AEM FPR, 3SX underhood fuel gauge, 3SX fuel rail loop, DN Y-pipe, HKS SSQ BOV, K&N FIPK, Greddy Profec Spec S, AEM WB02, Autometer C2 boost, egt, oil press & water temp gauges, MSD wires, NGK BCP7ES's, TEIN FLEX coilovers, Maximal performance control arms, solid engine mounts & powdercoating, RPS Streetmax Clutch, RPS Flywheel, NBT Tranny (cryotreated OS, shift forks & rails), updated speedo gear, solid shifter bushings, full 2nd gen brake conversion, 3SX SS brake & clutch lines, Carbotech Panther+ pads in the front & Bob Cats in the rear, 3SX clutch vac delete, EGR delete, vac reduction, Ebay DP, gutted pre cats, Bronze FN01RCs 5Zigen 18x8.5 + 30 offset, Pirelli P-Zeros, engine dress up kit, Bigtyla ground wire kit.
--Daily Driver: 98 Malibu, 4cyl, auto
SkortchGT is offline   Reply With Quote
Old 04-13-2004, 06:10 AM   #88 (permalink)
The Chaosbringer
Trader Rating: (7)
I highly doubt that. Just based on the layout, our trans looks to be loosely based on Mitsubishi's own W5M33 AWD trans used in the DSMs and Asian market GTO SRs (among others) It's possible that our trans and the Porsche unit share some common engineering since they're both Getrags, but I'd really be shocked to see any parts (besides a bearing or two) that coule be a direct swap.
It's still worth looking into, but I wouldn't get my hopes up over it.
Old 04-13-2004, 06:23 AM   #89 (permalink)
SkortchGT's Avatar
Trader Rating: (10)
I was thinking the same thing. I would be great if more then 1 part matched our trans, however I don't want to get my hopes up over it.
Do we have any new info regarding parts available for our trannies?
Old 04-13-2004, 09:28 AM   #90 (permalink)
Gear Head
An individual from Getrag refered me to some one at Mistubishi Motor Sales of America. I have sent that person an e-mail and left a voice mail message concerning parts suplliers and how to become a parts supplier. I'll let every one know what happens as soon as I hear back from them.
It has been my experience that the input shaft bearings are relitively long lasting, 100K+ miles is not unusual. I have only heard of one or two that have leaked. I haven't heard of any that have pitted. (Unlike the transmission in my old C1500.) The rollor tappered bearings on the ends of the shafts also last a relitively long time. I hear of more people damageing them through improper disassembly rather than an actual failure. I have seen several failures but only one was NOT due to a fluid level concern. (They didn't have enough fluid and ran dry basically.) The input bearing does look very similar to other input bearings. I'd be surprised if it wasn't used on at least one other model.
Some one could just call a Porsche dealer and talk to a tech. I bet they would be able to tell us what model the Getrags were in those trannys. Speaking of which, if createing a parts supllier does not work then I will attempt to find some sort of parts interchangeability between Getrag models with "servicable" transmissions/transaxles.
