Old 09-13-2006, 04:38 PM   #841 (permalink)
The New Super Pimp
maddog's Avatar
Drives: FASTER THAN VIPERS
Trader Rating: (7)
maddog Level 1maddog Level 1
Default Re: Getrag 440/446 parts.
Originally Posted by DigiiManDan3KGT
In good spirit ill just ignore all the attacking. Sorry If i caused that or if ur just having a bad day.
The turbo engine went in and the car was converted from ATX to a Getrag 5speed AWD converted to FWD. The motor spun all 6 bearings in 3 days complete oil pump failure. Then once a new motor was purchased wheelhop on solid mounts with a SFR lsd causes the differential to explode. Well i didn't know that untill it happened twice. I lost 2 awd getrag transmissions due to an exploded Differential. I've now ditched the SFR LSD and the transmission now just breaks the axel instead of the differential. Ive replaced 2 axels so far, much cheaper then transmissions. So when i made that post i had 2 perfectly good gear sets sitting in my garage. Recently ive sold them for 100$ now that i read this thread i see i lost out on alot of money by doing that because those syncros were in good shape.
Currently I have several 5spd transmissions, are the syncros the same in 5spds and 6spds?
only some. not all of them
93 Sandstone VR4
11.66 @ 117.48mph with Maddog Performance Engineering 13T's
This weeks specials:
CUSTOM RUBBER INTERCOOLER PIPING AT 50% OFF!!!
28 HOUR ENGINE REBUILD ONLY $700
maddog is offline   Reply With Quote
Old 09-14-2006, 07:33 AM   #842 (permalink)
2 Time Member of SBC
DigiiManDan3KGT's Avatar
Drives: 80Gig WesternDigital
Trader Rating: (7)
DigiiManDan3KGT is an unknown quantity at this point
Its a new problem every day it seems, I'm currently leaking transmission fluid from the passenger side oil seal MB837029, Should i no longer be contacting Auto-Craft for a part like this?
Green 1995 3000GT FWD-TT 8:1 // ATX to MTX // NA to TT // Completed in 2005 // Purchased 11/12/02
White 1999 3000GT Black Dash/Tan Leather Interior // SOHC // MTX // Stock Daily Driver Purchased 7/25/07
Red.._1992 Stealth RT/TT Twin Turbo AWD // Project Car for AWD // Purchased 05/19/08
<-- Click Here Join FL3S
DigiiManDan3KGT is offline   Reply With Quote
Old 09-14-2006, 09:27 AM   #843 (permalink)
The Toy Maker
enollava's Avatar
Drives: 96 perl white VR-4
enollava Level 2enollava Level 2enollava Level 2
I wasn't suggesting a group buy, I was thinking of a fund that people can donate money into that would go to getting parts created that are no longer available. It would be sorta like a 3S charity. The big problem would be deciding who is in control of what. I just envision something where there could be a section for different things needed for our cars, and that people could donate to funds to help support the development of those parts. Like maybe having a fund for Synchros if we can't get them anymore, and having another fund for another part that is no longer available. I'm sure this is just a dream but I definately wanted my thoughts to be understood. It wouldn't be a group buy. No way we would get people to do that. But I personally would donate money to a fund if it helps keep our cars on the road.
Rico
96 VR-4 purchased July 14th. Bone stock.
Sept. 3rd 04 K&N intake installed.
Dec. 20th. 04 RFL BOV installed.
Feb. 17th 05 Car is 100% paid off.
Mar. 23rd 05 Borla cat back installed
Apr. 22nd 05 MR gear arrived
Sept 20th Got my AEM ECU, 3.5 bar sensor, IAT sensor. Now I need to learn to tune my car. Should be fun. Assistance with that project is welcome.
More mods to come.
enollava is offline   Reply With Quote
Old 09-14-2006, 10:14 AM   #844 (permalink)
Hitokiri Battousai
Jeremy C's Avatar
Drives: A car that runs
Trader Rating: (47)
Jeremy C is an unknown quantity at this point
Hmmm, do you have proof that the SFR LSD insert was the cause of the failure? I just popped something in my trans (again) and it's sounding like the diff. I'll know for sure when I pull it out but I know it's not gears like the last 2 times I broke things - just sounds far too different. I also have an SFR LSD insert in my trans (though mines an F5 and not a W5/6). I'm interested in what lead you to that conclusion.
Jeremy C is offline   Reply With Quote
Old 09-14-2006, 10:31 AM   #845 (permalink)
Trader Rating: (7)
Im at work, but i have pics that show the differential exploding starting from the SFR LSD outward. Ive blown 2 trannys and i know 2 other board members that have with the SFR LSD and Andy ES3000TT allso blew up his tranny with the SFR LSD installed. Currently im running No LSD, and es3000TT is running a Quaffie. We have now been running for 1/2 a year with out exploding a differential. Befor i couldnt last more then 2-3 months befor blowing it.
I have no real proof just some small evidance. I like that fact that now I have wheelhopped a few times and it breaks the Axel instead of the Transmission's bellhousing. Solid mounts dont help btw they actually assist in cracking the bellhousing. I have pics with Evidance on that allso. (not 100% proof)
btw, where do i go to order this oil seal now?
Old 09-14-2006, 12:48 PM   #846 (permalink)
91 Stealth TT
jwetzler's Avatar
Drives: 91 Stealth TT
Trader Rating: (8)
jwetzler is an unknown quantity at this point
Yeah I'm willing to make a donation or whatever in order to help get some of these parts available. I would need to see who/what company I'm donating to, and see the results/progress of my donations. I would want it laid out real nice. I have MONEY IN HAND for this.
Currently a member of the Spun Bearing Club
-15G's, MBC @ 7psi
-ARP Head Studs, Ported Heads
-.80 Ross 8.5:1 Pistons & Crower Connecting Rods
-RPS Street Max Clutch & Pressure Plate
-ESP Downpipe, Gutted Cats, EGR Blockoffs
-3SX Polyurethane Motor Mounts
-Hotwired Supra fuel pump, Resistor Bypass
-Fuel Labs AFPR @ 44psi
-Dejon Dual Intakes
-MAFT-Pro in Speed Density
jwetzler is offline   Reply With Quote
Old 09-14-2006, 02:30 PM   #847 (permalink)
The Toy Maker
enollava's Avatar
I don't wanna sound like I have something running for that type of program, I was just trying to get an idea out there for this to happen. I don't know exactly how this would be set up. I think one of the reputable shops would have to take my idea and do something with it. I just know that I would be willing to donate money to get parts made for our car even if I never end up needing that part. Like I said, this is just my vision, it is not a reality, and I wouldn't be part of the fund. I know I'm an honerable person but I don't have the ability to do something like this. I hope my vision comes to reality. If we getting to the point where synchros aren't available anymore I think this might be the only way to get new ones. Same goes for any other part for our car.
Old 09-14-2006, 02:44 PM   #848 (permalink)
91 Stealth TT
jwetzler's Avatar
Trader Rating: (8)
I understand where you're coming from. I know you were just throwing that vision out there, I was lettin ya know that I support that vision as well, and would be willing to put some money down if we can find some one reputable to take a project like that on in the future. That is if everything else falls through.
Old 09-14-2006, 02:50 PM   #849 (permalink)
The Toy Maker
enollava's Avatar
Cool, I just didn't want anybody to think I was running something. I have no time or ability to take on a project like that. All I have is the vision and money to donate to a program if it is set up in a way I trust.
Old 09-14-2006, 03:50 PM   #850 (permalink)
Ask me about Getrag's!
DarkHelmet's Avatar
Drives: Space ball one
Trader Rating: (11)
DarkHelmet is an unknown quantity at this point
just relax. Northbend technologies is on the case as I've said before. we have 1/2 for both transm,issions. we have 6 speed 3/4 in production that should be ready in a week or so and we're working on 3/4 for the 5 speed which is also 5/6 for the 6 speed. have no fear. we will have synchros for all
DarkHelmet is offline   Reply With Quote
