Old 04-08-2004, 09:21 PM   #71 (permalink)
3S Obsessed
HydeDW's Avatar
Drives: 97 VR4
Trader Rating: (7)
HydeDW is an unknown quantity at this point
Default Re: Getrag 440/446 parts.
I have been searching for the last week for W6MG1-0-FNBR synchronizers and the 'single use' parts for a rebuild.
I have not yet initiated phone calls but all email queries out to Kormex and Team RIP have been met with dead silence this week. I have an email out to CRS to see what inventory they may have remaining. I hoping to be able to pick up at least some of the parts and 'hope' I can lay hands on others eventually.
We'll see....
I'm about to pull the trigger on a remanufacture from Mitsubishi soon. I can't wait much longer for 'a fix' to my shifting issues.
Dan (3SI #37)
Pearl White 1997 VR4 (117K 4/2007)
Engine: 13T Turbos - Rob Beck engineered
Engine: AEM EMS; GM 3.0 MAP, GM IAT, GM EBC, RC550's
Intake: Dejon Hardpipes; Dual K&N
Drive Train: RPS Carbon-Carbon Clutch;
Drive Train: Kormex LSD;
Drive Train: PST CFDS;
Suspension: TEIN Flex w/EDFC;
Brakes: StopTech ST40 brakes & 355x32MM AeroRotors® rotors (Front) SuperCar Engineering;
Brakes: StopTech ST22 brakes & 328x28MM AeroRotors® rotors (Rear) SuperCar Engineering;
Wheels: PIAA 18x9.5 FR-S w/45mm offset ;TOYO Proxes T1-R 18x275x35;
Gauges: Defi-Link (EGT, Water Temp, Fuel Pres, Oil Pres, Oil Temp, Boost and Display);
Gauges: 2 AEM WB02 (Left & Right Bank);
Cooling: Fluidyne DB-30816 Front Mount Oil cooler (currently deinstalled);
Cooling: 3SX Dual-Pass Radiator w/Flex-lite fans;
Cooling: Waterless NPG+
HydeDW is offline   Reply With Quote
Old 04-08-2004, 10:31 PM   #72 (permalink)
POLYCHRONOPOULOS
RobBeck's Avatar
Drives: On 1 Wheel
Trader Rating: (219)
RobBeck is an unknown quantity at this point
Remanufacture is the key word. You can get these from Mitsubishi as remans? If that is the case, mitsubishi sure knows how to get parts.... right? Why cant we figure out where Mitsubishi gets parts to remanufacture.... or where or who the remanufuctures (???) really are?
Rob
RobBeck is offline   Reply With Quote
Old 04-09-2004, 04:51 AM   #73 (permalink)
Gear Head
Bret Brinkmann's Avatar
Drives: Rear wheels only...
Bret Brinkmann Level 3Bret Brinkmann Level 3Bret Brinkmann Level 3Bret Brinkmann Level 3
CRS does the remans for Mitsu. CRS gets part from Getrag in MI. Getrag only sells in bulk. That is what this thread is all about. To get a list together from Getrag with all the Getrag part numbers for all the parts to the transaxles (and may be the transfer cases) as well as prices and the minimum quantity of each part that has to be ordered.
250 RWHP
Old 04-09-2004, 05:36 AM   #74 (permalink)
POLYCHRONOPOULOS
RobBeck's Avatar
Drives: On 1 Wheel
So is CRS gonna stop doing remans since it is running out of parts?
Rob
Old 04-09-2004, 05:49 AM   #75 (permalink)
Warning: I'm an asshole
SkortchGT's Avatar
Drives: 1992 3000GT VR4
Trader Rating: (10)
SkortchGT Level 7SkortchGT Level 7SkortchGT Level 7SkortchGT Level 7SkortchGT Level 7SkortchGT Level 7SkortchGT Level 7SkortchGT Level 7
Rob
Read the first page of the thread.
1992 3000GT VR4
--Completely rebuilt 5/06-4/07. Everything new. For a list see: http://www.3si.org/forum/showthread.php?t=372579
--First time on dyno: 364AWHP@16psi with a 10.3AFR (now tuned at 11.4-11.6 with timing control, time for another dyno run soon)
--Mods: DR Stage I heads, 3rd gen lifters, TD04L 13Gs, DSM SMICs, PTE 550s, Apexi SAFC, Apexi SITC, Walbro FP, IPO hotwire, Robbeck adapter & AEM FPR, 3SX underhood fuel gauge, 3SX fuel rail loop, DN Y-pipe, HKS SSQ BOV, K&N FIPK, Greddy Profec Spec S, AEM WB02, Autometer C2 boost, egt, oil press & water temp gauges, MSD wires, NGK BCP7ES's, TEIN FLEX coilovers, Maximal performance control arms, solid engine mounts & powdercoating, RPS Streetmax Clutch, RPS Flywheel, NBT Tranny (cryotreated OS, shift forks & rails), updated speedo gear, solid shifter bushings, full 2nd gen brake conversion, 3SX SS brake & clutch lines, Carbotech Panther+ pads in the front & Bob Cats in the rear, 3SX clutch vac delete, EGR delete, vac reduction, Ebay DP, gutted pre cats, Bronze FN01RCs 5Zigen 18x8.5 + 30 offset, Pirelli P-Zeros, engine dress up kit, Bigtyla ground wire kit.
--Daily Driver: 98 Malibu, 4cyl, auto
SkortchGT is offline   Reply With Quote
Old 04-09-2004, 10:26 AM   #76 (permalink)
POLYCHRONOPOULOS
RobBeck's Avatar
Drives: On 1 Wheel
It doesnt say that CRS remans trannies does it? Brett just said they did... so I guess they are gonna discontinue the reman process tho since the parts that run out. If it turns out that CRS doesnt reman our trannies, then who does, and where do they get the parts from?
Whatever I just hope the problem gets fixed.
Rob
Old 04-09-2004, 10:57 AM   #77 (permalink)
Boom Boom Sucky Sucky
geoffw's Avatar
Drives: '92 Talon Tsi AWD
geoffw is an unknown quantity at this point
I am still able to buy in bulk from Getrag and sell to the 3/S community for very reasonable prices, if you guys can get minimum order #s and prices, etc. That would make it that much easier.
'92 Blue Eagle Talon Tsi AWD
ProStreet Race Engine
Hacked MAS
SAFC2
Big 16G
Full 2.5" Exhaust w/High Flow Cat
UICP w/SSQV
Friends Car:
'92 Panama Green 3000GT VR4 (??? miles)
Matrix Intake
Blitz DSBC Spec-R (Indigo)
ESP "Race" Downpipe
3.0" Test Pipe
Gutted Pre-Cats
Custom Cat-Back
3560 lbs (No Driver, Empty Tank)
geoffw is offline   Reply With Quote
Old 04-09-2004, 12:38 PM   #78 (permalink)
rdzombie's Avatar
Drives: 91 VR4,
rdzombie is an unknown quantity at this point
Originally Posted by geoffw
So what are the people like me(18yo makin $12/hr) gunna do when our tranny goes?
cry
rdzombie is offline   Reply With Quote
Old 04-09-2004, 12:40 PM   #79 (permalink)
SkortchGT's Avatar
Trader Rating: (10)
Originally Posted by rdzombie
cry
What a wonderful first post.
Old 04-10-2004, 10:30 PM   #80 (permalink)
3SNY President
ifithas2be's Avatar
Drives: 91 VR4
ifithas2be is an unknown quantity at this point
Ok, I dont know a thing about our trannys or how they work but I am a good friend of Ray Pampena. He is the creator of the 300M output shaft, well at least hes the one that had it made. I remember him telling me that its no simple task to re-create stock parts. Things like they we they are balanced, tolerances, and the whole engineering process behind it is what makes it difficult. Hence $600.00 for an output shaft. Ray has opened a shop and no longer works for mitsu so ill mention the idea tranny parts to him again or just let him know about this post.
On a side note:
A member of my club is in dire need of an input shaft bearing, can anyone help. Cant find the part anywhere.
3000GT STEALTH CLUB of NEW YORK
ifithas2be is online now   Reply With Quote
