Old 05-08-2006, 05:23 PM   #721 (permalink)
no speed limits here
BLACK94TT's Avatar
Drives: A109E
Trader Rating: (20)
BLACK94TT is an unknown quantity at this point
Default Re: Getrag 440/446 parts.
Originally Posted by KORMEX
5spd is the same if any help .
Frank, I know you don't need the props, but that's the kind of post from you we've grown accustomed to here. We appreciate you man.
Steve
BLACK94TT is offline   Reply With Quote
Old 05-08-2006, 08:42 PM   #722 (permalink)
Here for the tuna.
lawdogg's Avatar
Drives: The Speed Limit
Trader Rating: (66)
No, sorry I dont have the 1/2 slyder, 5spd is the same if any help .
Thanks so much for the info, I'll keep looking!!
I don't really know what you guys are all talking about Kormex, I've bought a complete 1-2 synchro with blocking rings, reverse gear with synchro and blocking rings, prices and service were always great.
But I would imagine, like any shop, things are overlooked from time to time. Happened to me with the IPS AEM WB02, but it doesn't make them any worse of a shop. Hell, I've worked in shops my whole life and I've seen it happen MUCH more frequently. For whatever that's worth.
-Ryan
94 VR-4: 11.8 @ 116, 17psi, pump, 13Ts
Old 05-09-2006, 09:15 AM   #723 (permalink)
KORMEX's Avatar
Trader Rating: (11)
KORMEX Level 7KORMEX Level 7KORMEX Level 7KORMEX Level 7KORMEX Level 7KORMEX Level 7KORMEX Level 7
-Ryan
Ryan,
going by the pictures that I saw of your 1/2 slyder, you should be able to put it on a lathe and clean the alumn off
its the fork that you absolutely need to replace .
KORMEX is offline   Reply With Quote
Old 05-09-2006, 12:04 PM   #724 (permalink)
Here for the tuna.
lawdogg's Avatar
Trader Rating: (66)
Frank-
Not a bad idea at all. I did buy a used shift fork, which looks decent enough I guess. I have no time this week (college sucks haha) but this weekend hopefully I'll be able to try it out.
-Ryan
Old 05-09-2006, 09:05 PM   #725 (permalink)
Gear Head
Bret Brinkmann's Avatar
Drives: Rear wheels only...
Bret Brinkmann Level 7Bret Brinkmann Level 7Bret Brinkmann Level 7Bret Brinkmann Level 7Bret Brinkmann Level 7Bret Brinkmann Level 7Bret Brinkmann Level 7Bret Brinkmann Level 7Bret Brinkmann Level 7Bret Brinkmann Level 7
The 5 and 6 speed 1/2 collar did have some minor design differences, thus different PNs, but they are interchangable. If no one else has either, then try getting up with AutoCraft again and asking if they have a 1/2 collar for either the 440 or 446.
250 RWHP
Old 05-09-2006, 09:15 PM   #726 (permalink)
Here for the tuna.
lawdogg's Avatar
Trader Rating: (66)
Bret do you know exactly what the design differences are? I'm imagining identical splines and tooth profiles, but different lengths?
I so don't want to play the "get-in-touch-with-Bill-Lane" game again.
Old 05-09-2006, 09:22 PM   #727 (permalink)
Gear Head
Minor differences around the dog teeth (but not the teeth themselves) if I remember correctly. I have used a 5 speed one in a 6 speed and vis versa and been unable to tell any difference while operating the car. It has been a while and all of my parts are packed away for a few months other wise I would check for you.
Old 05-09-2006, 09:24 PM   #728 (permalink)
Here for the tuna.
lawdogg's Avatar
Trader Rating: (66)
Thanks man, I was just curious. I might have access to a 5spd part anyway, I'll check as soon as I'm back at the shop. Wouldn't that be nice?
Old 05-09-2006, 09:24 PM   #729 (permalink)
Drives: 96 CE LT4 vette
Trader Rating: (6)
ubnpast is an unknown quantity at this point
Hey,
you are in easton pa? I am 30 min's east of easton, I have these parts for a 6 speed:
1-2 shift fork, nothing wrong, retails for $170, asking $60 shipped (or will drive to you)
Second gear (teeth on side of gear may need to be grinded to a point by a machine shop, because slight rounding), but everything else is fine.
2nd gear retails for $315 asking $30
2nd gear inner ring, absoutly nothing wrong with it retails $75, asking $50
2nd gear outer ring, also nothing wrong, $20
1st and 2nd friction rings, also nothing wrong, $25
I also have the HUB and SLEEVE assembly with the 3 springs and square pieces and balls. I am not a trans specialist, but should work fine. Retail $250, asking $30.
ubnpast is offline   Reply With Quote
Old 05-09-2006, 09:29 PM   #730 (permalink)
Here for the tuna.
lawdogg's Avatar
Trader Rating: (66)
Originally Posted by ubnpast
Hey,
OH MY GOD I LOVE YOU
Would you be willing to bring all that stuff to GZP in Easton so I can see what you've got? I'll probably buy the HUB & SLEEVE assy from you, and maybe the 1-2 fork, if it's in better shape than the one I already have. We might be interested in more of it as well. If not, I'll try to find a ride to you if you like.
Please let me know ... thanks!
-Ryan
