Old 04-21-2006, 10:43 AM   #701 (permalink)
Gear Head
Bret Brinkmann's Avatar
Drives: Rear wheels only...
Bret Brinkmann Level 7Bret Brinkmann Level 7Bret Brinkmann Level 7Bret Brinkmann Level 7Bret Brinkmann Level 7Bret Brinkmann Level 7Bret Brinkmann Level 7Bret Brinkmann Level 7Bret Brinkmann Level 7Bret Brinkmann Level 7
Default Re: Getrag 440/446 parts.
I don't know why I didn't earlier up I updated the first post of this thread to include AutoCraft's fax number and information that will help members get a hold of Bill faster. I also added that Mentor Mitsu is no longer able to supply us with Getrag parts, made it more clear that Applied is the place to get roller bearings, and a few other minor details were changed.
250 RWHP
Old 04-29-2006, 06:02 PM   #702 (permalink)
3si #1390
david1 is an unknown quantity at this point
some one have pic on how the reverse gear is put on 5 speed awd on to
side cover remove bolt when put in in output shaft
1992 dogde stealth Evo3 turbo,660 injector, 85 mass air flow and translator 2.1 ,water/methanol injection,
supar fuel pump, k@n air filter, greddy blow off valve, , ips front mount interccoler and pipes ,tires BFG KD d@n down pipe , no cats, blitz sbd-id, msd wires, cross drilled rotors.pst drive shaft ,msd, e2k TC bracket . lsd .spec 3+ clutch
Dr650 1/8 7.5 at 94mph 453HP 470 Torque
Evo3 1/8 7.3 at 98mph 559hp 514 Torque slipping cluch
david1 is offline   Reply With Quote
Old 05-02-2006, 09:21 PM   #703 (permalink)
Gear Head
I'm not sure what you are asking. Can you be a little more clear?
Old 05-02-2006, 09:48 PM   #704 (permalink)
Here for the tuna.
lawdogg's Avatar
Drives: The Speed Limit
Trader Rating: (66)
Thanks Bret, looks like I'll be needing a 1-2 shift fork and a 1-2 collar now. Autocraft the best source?
94 VR-4: 11.8 @ 116, 17psi, pump, 13Ts
Old 05-02-2006, 10:26 PM   #705 (permalink)
Gear Head
Yes. Call in the AM if you don't have a fax.
Old 05-03-2006, 09:59 AM   #706 (permalink)
The Codebringer
Gatecrasher's Avatar
Drives: 81 Fiat Panda
Trader Rating: (7)
Gatecrasher Level 7Gatecrasher Level 7Gatecrasher Level 7Gatecrasher Level 7Gatecrasher Level 7Gatecrasher Level 7Gatecrasher Level 7Gatecrasher Level 7Gatecrasher Level 7Gatecrasher Level 7Gatecrasher Level 7
I've faxed, I've emailed and I've left messages. Still nothing. At least have the courtesy to tell me to go away if you can't or won't sell me parts...
-= sig goes here =-
Gatecrasher is offline   Reply With Quote
Old 05-03-2006, 09:17 PM   #707 (permalink)
The Codebringer
Trader Rating: (7)
I FINALLY heard back from Bill. Looks like I have enough parts coming to do 2 more trannies.
There is so much cool shit I could do with these things if I could just get parts reliably. It's so aggravating...
Old 05-03-2006, 11:33 PM   #708 (permalink)
Here for the tuna.
lawdogg's Avatar
Trader Rating: (66)
How did you hear back from him? Fax, phone, email?
Old 05-04-2006, 04:29 PM   #709 (permalink)
The Codebringer
Trader Rating: (7)
He finally called be back. I've only had the same contact info for 2 years now...
Old 05-04-2006, 08:36 PM   #710 (permalink)
Gear Head
How long were you trying to get upwith him? Thelongest it ever took for me was the next day. And that was only because I faxed him later in the afternoon. Every time I faxed him the morning I got a reply that afternoon.
