#671 (permalink) |
The New Super Pimp
kormex?
supposedly there are some synchros being made but there are kinks to be worked out
93 Sandstone VR4
11.66 @ 117.48mph with Maddog Performance Engineering 13T's This weeks specials: CUSTOM RUBBER INTERCOOLER PIPING AT 50% OFF!!! 28 HOUR ENGINE REBUILD ONLY $700 ![]() |
#672 (permalink) | |
no speed limits here
Steve
#673 (permalink) | |
The Codebringer
-= sig goes here =-
#674 (permalink) |
Any ideas on where to get a 3rd gear synchro, 1st and 2nd gear synchro (inner, outter and middle rings) for a 6 speed? Also an input shaft bearing/seal?
CRS: Only has the outter and inner rings for 1st and 2nd gear. Kormex: Only has the middle ring for 1st and 2nd gear Supercar Engineering: Only has 1st and 2nd get synchro for $215. I'm not sure if this is all three rings or just the middle. So basically I'm looking for a 3rd gear synchro and input shaft bearing/seal. It looks like I should be able to mix parts from CRS, Kormex or SCE to get 1st and 2nd gear done. If anyone else has any ideas for the 3rd gear synchro let me know...
1994 Mitsubishi 3000GT VR-4
1990 Plymouth Laser RS Turbo |
#676 (permalink) | |
The New Super Pimp
crs is out of the input shaft bearing/seal and thrid gear synchro too? supercars is only the middle friction ring or so his description says. |
#677 (permalink) | |
The New Super Pimp
thats about it then. supercar may have something, its worth a try. for crs many of the times you have to buy the slider assembly, you cant just buy the slider itself. the assembly comes with the hub,slider, balls and springs. think it was pretty $$$$ a month ago |
#678 (permalink) | |
I forgot to ask Kormex if they had it, but I'll check tomorrow. Anyways I guess I'll go ahead and get 1st and 2nd from CRS/Kormex and put it back together. Also I guess it's safe to swap the position of the 3rd and 4th gear synchro since they're identical? That way it will hopefully improve 3rd gear and make 4th the notchy one. I'd rather have it like that since you use 3rd a little more than 4th. Once I can actually get a hold of a 3rd gear synchro I'll drop the transmission again this summer to replace it because there's no point waiting months and month on one synchro.Last edited by Jason_99ozGS : 01-31-2006 at 03:47 PM. |
#680 (permalink) |
Gear Head
I just got parts today from AutoCraft. 1/2 synchros (all three), 1/2 synchro assembly, reverse synchro ring, 2nd gear, axle seals, input shaft plug, and output shaft seal. It was about $800 total. The 1/2 outer rings are coming from Germany right now and so are $70. They are still out of 3/4 rings.
If your input shaft bearing/seal is not damaged or leaking, then don't worry about it. It's not worth holding off the rebuild for. If you need a 1/2 collar, then you also need a 1st or 2nd gear too. I had a guy confirm that the TT 6 speed Supra 1/2 frictions rings are identicle to ours. I talked with him on the phone and told me that he had them in his hand and could not tell them appart. He quoted me about $35 each. AutoCraft has them now for less than that.
250 RWHP If you want the exploded views of both 5 and 6 speeds or pics e-mail me at SavagTiger@AOL.com. 94 VR-4 Panama Green Tan Interior RPS II, gutted cats, flipped BPV, 3SX control arms, 3SX shift bushings, Red Line, Auto-Meter. Rebuilt TC, transaxle, steering rack, heads, and turbos. 360cc's blue printened with in 1%. New short block. RWD convertion and welded rear end. |
