#661 (permalink) | |
Gear Head
250 RWHP If you want the exploded views of both 5 and 6 speeds or pics e-mail me at SavagTiger@AOL.com. 94 VR-4 Panama Green Tan Interior RPS II, gutted cats, flipped BPV, 3SX control arms, 3SX shift bushings, Red Line, Auto-Meter. Rebuilt TC, transaxle, steering rack, heads, and turbos. 360cc's blue printened with in 1%. New short block. RWD convertion and welded rear end. |
#662 (permalink) |
ZoomZoom?
please help i have a 97 Vr4 6speed, with a 2nd gear grind. i have called Kormex, they dont have the synchro and have not had it for a while. Bill Lane @ AutoCraft he told me they have the synchro on back order for 4months now and he does not think they will get anymore of them so where can i find the 2nd gear synchro at
update i called Mentor Mitsu, Howard was not in. i talked to some one else he said he cant get any of the synchro any more. he said i will need to buy a new Tranny
1992 Silver 3000GT VR4 BPU
![]() 1997 Black 3000GT VR4 Fast Stuff: IPS Stage 3 block with Pauter forged rods and CP pistons , DR Stage 3 heads with High Rev Valve Spring Kit and Titanium Retainers AND Rays head lift fix , IPS EVO 3 kit with turbo porting and Ceramic coating, IPS 272 Cams, IPS Fuel rails, fuel rail loop, Aeromotive A1000 FPR, PET 780CC Injectors, South Bend Stage 4 FE clutch, IPS NO-MAF intake pipes, 2 AEM Dry flow filters, AEM EMS, AEM map sensor, AEM IAT sensor, IPS intercooler kit w 750hp Spearco core, RPS flyweel, 2 HKS BOV, MSD 8.5MM wires, MSD Coils, Stillen downpipe, 3 inch custom exhaust W Apexi N1 tip, 3sx aluminum crank pulley, Walbro fuel pump, hotwire fuel pump kit, solid motor mounts, EGR block off Kit, red top Optimia battery, Flexalite twin 12" fans, Koyo aluminum radiator, polished front/back valve covers, polished plenum, polished throttle body, IPS polished coolant pipes, manifold / downpipe turbo hot side polished ceramic coating, Turbo intake side polished. Interior&Audio System: Corbeau CR1 Seats In Black, Corbeau Black 3Point Harnesses, Apexi AVC-R Boost Controller, Apexi Turbo Timer, Defi-Link Meter BF Gauges In White, Boost/Psi, Water Temperature, Oil Presure, AEM Wideband, SmokingVR4 Duel 10Inch Sub Box, 2 PPI 1000 Watts RMS Subs, Alpine IVA-D901 In Dash Flip Out Screen With Nav. Suspension: KYB Struts, Tien S. Tech Springs, 19X9 SSR D5R in bronze with a polished lip, 245/35/19 Toyo Proxes T1R, Proracer Racing Lug Nuts in red, Rear Strut Bar. Body: Viper alarm system, 8,000k HID. www.ipsmotorsports.net www.dynamicracing.com www.kormextrans.com Last edited by HumanVr4 : 01-19-2006 at 04:24 PM. |
#663 (permalink) |
The New Super Pimp
u could try supercar engineering. i know he sorda has a source. only thing is hes harder to get in contact with than Bill Lane
good luck and let us know how it turns out
93 Sandstone VR4
11.66 @ 117.48mph with Maddog Performance Engineering 13T's This weeks specials: CUSTOM RUBBER INTERCOOLER PIPING AT 50% OFF!!! 28 HOUR ENGINE REBUILD ONLY $700 ![]() |
#664 (permalink) | |
ZoomZoom?
#666 (permalink) |
ZoomZoom?
well thanks for the help : ) it looks like he has them on his page is this all i will need to fix my tranny? http://supercar-engineering.com/sc2/...roducts_id=161 i bought it with a 2nd gear grind if i wait till the rpms drop to 1k it goes in fine with no grind.
#667 (permalink) |
Gear Head
It looks like SCE only offers the friction ring for the 1/2 synchros. If your inner or outer blocking ring are worn then that will not correct your problem. ONce you get the tranny appart you should also inspect the dog teeth on the gear and synchro collor for wear. If they are worn, then thay should also be replaced. AUtoCraft WILL get mor in evenchually, it's just not certain when.
#668 (permalink) |
10.15@142.00
It was once discussed that the 6spd supra synchro friction rings(1st and 2nd?) were the same as ours. Has anyone verified that? Seems reasonable...why wouldn't Getrag try to reuse some parts?
May result in another source.
1991 Dodge Stealth RT/TT
2008 mods: DR1200s (it's running!!) 10.15@142.00 |
#670 (permalink) |
Banned from Classifieds
i need the 1-2 gear syncro hub, the shop got most everything else taken care of that hub is the last item that needs replaced. One side of it is significantly rounded/worn, it may work for a while but I am thinking it may also cause pre-mature wear of the friction rings.
Anyone know where I can get one quick?? Autocraft is out. It would be badass if some machinist picked up and started making syncros for us. |
