#582 (permalink) |
The Codebringer
Got the email. I'll round up everything in the morning.
Here's the bearing list I took from the last 6-speed I was working in. I should have a 25-spline 5-speed this weekend. Not sure how different those are from the 18-spline models. Inboard means close to the bell housing, outboard means towards the end cover and the side of the car. I included the brands just in case it matters. Input shaft inboard: FAG 308-410 Input shaft outboard: FAG 57497A (might be a little off. The writing wasn't clear) Intermediate inboard: FAG 30209A-H84 Intermediate outboard: Koyo Hi-Cap 30208 J-N Center diff inboard: FAG 32010X-H84 Center diff outboard: Timken Y-32009X Front output shaft inboard: Timken Y-32009X Front output shaft outboard: Timken Y-32009X Differential inboard: Timken Y-32008X Differential outboard: Timken Y-32009X |
#583 (permalink) | |||
Verified
#584 (permalink) |
Banned from Classifieds
Your numbers look right to me, Gate. And the 6 speed intermediary outboard is without a doubt 30208, unless I'm reading it wrong it is in fact the only one that differs, though the input shaft outboard is questionable, I can verify on my own when I get around to it. But I'm in the process of moving, so I make no promises of when that will be
#585 (permalink) |
Slow in the driveway
You guys are terrific! I just had to order intermediate shaft taper bearings, but I didn't have the busted ones to get the numbers off of. Good timing with your list.
P.S. Gatecrasher -- I just sent you an email about a spring... |
#589 (permalink) |
Gear Head
I up dated the first post to include the bearing numbers for all of the shafts/diffs. Thanks for the info guys. It will make getting bearings from Applied much easier. I checked the Japan version of CAPS and it confirms that the bearings are the same for all years except for the end cover side bearing on the counter shaft. It was changed when Mitsu switched from the 5 speed to the 6 speed. I noted this in the bearing number list on the first post. If anyone sees an error in the numbers please let me know and I will correct it.
DocEBrown - I checked Japan CAPS and it does not list a PN for the bell housing, gear housing, or end cover. mikes2nd - Mentor will have the PNs for the front differential ring and pinion gears found in all Japan spec 6 speed transaxles, MR or not. Kormex may have some in stock and will most likely be cheaper. You may be interested in a thread I started about these gears. Check it out. Gatecrasher - I came across some thing interesting a while ago. Things have gotten too busy for me lately to finish looking into it but maybe you would be interested sense you are looking into different synchro options. The MKIV Supra TTs appearently use the same 1/2 friction ring as our 440/446 trannys. Getrag makes their trannys too. I believe there are some similarities between these trannys and a few Getrags found in BMW applications also. To top it all off, Toyota and BMW have always offered internals for these transmissions unlike Mitsu. If you go to www.supraforums.com find the guy from Champion Toyota in TX.
250 RWHP If you want the exploded views of both 5 and 6 speeds or pics e-mail me at SavagTiger@AOL.com. 94 VR-4 Panama Green Tan Interior RPS II, gutted cats, flipped BPV, 3SX control arms, 3SX shift bushings, Red Line, Auto-Meter. Rebuilt TC, transaxle, steering rack, heads, and turbos. 360cc's blue printened with in 1%. New short block. RWD convertion and welded rear end. |
#590 (permalink) |
The New Super Pimp
i knew it!
they would have to share parts. why not? more money for them. were the hell is the russian. he should have found this out first. dammit he owns one. now who wants to go buy a bunch of bmw's so i can tear the trannies apart good work bret sorry i couldnt make it out there a few weekends ago i had to rebuild a freinds engine.
93 Sandstone VR4
11.66 @ 117.48mph with Maddog Performance Engineering 13T's This weeks specials: CUSTOM RUBBER INTERCOOLER PIPING AT 50% OFF!!! 28 HOUR ENGINE REBUILD ONLY $700 ![]() |
