Old 05-21-2005, 07:49 AM   #571 (permalink)
Verified
jackhammer's Avatar
Drives: RC46 / IS300
Trader Rating: (55)
jackhammer Level 1jackhammer Level 1
Default Re: Getrag 440/446 parts.
Originally Posted by Gatecrasher
I've got 2 6-speeds torn apart right now. I was planning to do exactly what you're doing so we can have a bearing catalog. I'll have some numbers to compare to yours shortly.
Cool.........
jackhammer is offline   Reply With Quote
Old 05-22-2005, 01:34 AM   #572 (permalink)
Banned from Classifieds
doctorstupid's Avatar
Drives: 3100GT VR-4
Trader Rating: (37)
doctorstupid is an unknown quantity at this point
Originally Posted by MitsubishiSpecialties
I guess the only ones i'm unsure of are the VCU front and the counter shaft rear. I read the counter uses a 30208 & 30209, but in my pile of used bearings i don't have a 30208 but i do have a 30207. I'm assuming it came from the counter shaft rear, because the counter is the only part that uses bearings that start with "302..."
The intermediary (aka counter) shaft rear was without a doubt 30208 in the last 6 speed I was working on here, I know this because I replaced it
Are you working on a 5 speed? This could very easily explain any discrepencies in our numbers. Sometime this month I'll be picking through my 6 speed giving it some TLC and resetting preload throughout, in doing so I will have removed all the races and will happily record al of the numbers if for nothing more than comparison
Gatecrasher, I still need 1-2 and 3-4 stiffer syncrho springs to throw in while I have my tranny open, what do I need to do to get the from you?
doctorstupid is offline   Reply With Quote
Old 05-23-2005, 06:27 AM   #573 (permalink)
Verified
jackhammer's Avatar
Trader Rating: (55)
Yep, i'm working on a 5 speed. The 30207a is definitly for the counter shaft rear. I tested it yesterday.
So the only one i'm lacking is the VCU front, these are all correct for the 5speed
- Fr Diff 32008 & 32009
- Fr Diff Idler sleeve 32009 (qty 2)
- Counter shaft 30207 & 30209
- VCU Rear 32009
Old 05-23-2005, 09:29 PM   #574 (permalink)
The Chaosbringer
Gatecrasher's Avatar
Drives: 81 Fiat Panda
Trader Rating: (7)
Gatecrasher is an unknown quantity at this point
Doc, use the email link and get me your info. I'll get them sent out. The 1/2 springs are $5 each and the 3/4 springs are about $1 each. Don't ask me why the 1/2 springs are so expensive. My cost on them is $4.60. I just round it up to $5 for convenience.
I've got all the 6-speed bearings cataloged. I'll post them tomorrow. I don't feel like going out to the garage to get my notebook right now
Gatecrasher is offline   Reply With Quote
Old 05-23-2005, 09:50 PM   #575 (permalink)
Drives: 3100GT VR-4
Trader Rating: (37)
Will do
Old 05-24-2005, 05:59 AM   #576 (permalink)
Verified
jackhammer's Avatar
Trader Rating: (55)
Anyone know the number for the front VCU bearing??
I don't want to have to make 2 1hr trips to the press, i want to have all the parts on hand the first time.
Old 05-24-2005, 06:20 AM   #577 (permalink)
KORMEX's Avatar
Trader Rating: (10)
KORMEX Level 3KORMEX Level 3KORMEX Level 3KORMEX Level 3
Which one ?
KORMEX is offline   Reply With Quote
Old 05-24-2005, 06:24 AM   #578 (permalink)
Verified
jackhammer's Avatar
Trader Rating: (55)
#32010, right next to the vcu housing gear
5 speed
Old 05-24-2005, 08:01 AM   #579 (permalink)
KORMEX's Avatar
Trader Rating: (10)
5 speed
Yes thats a 32010
Actually that drawing is wrong on all 32209 it should be 32009 the same with 32208 it should be 32008.
Old 05-24-2005, 08:41 AM   #580 (permalink)
Verified
jackhammer's Avatar
Trader Rating: (55)
OK, heres the complete 5 speed taper bearing list
- VCU Rear 32009
- VCU front 32010
Please add that to post 1
