#562 (permalink) |
Gear Head
I updated the first post so people know to contact Gatecrasher for springs and balls.
Gatecrasher - Double check the info to make sure it is correct. I don't want to give people wrong information. By the way.... LOVE the avitar! I would recommend compairing the bearing numbers anyway to make sure you didn't receive the wrong part on accident.
![]() 250 RWHP If you want the exploded views of both 5 and 6 speeds or pics e-mail me at SavagTiger@AOL.com. 94 VR-4 Panama Green Tan Interior RPS II, gutted cats, flipped BPV, 3SX control arms, 3SX shift bushings, Red Line, Auto-Meter. Rebuilt TC, transaxle, steering rack, heads, and turbos. 360cc's blue printened with in 1%. New short block. RWD convertion and welded rear end. |
#564 (permalink) | |
Banned from Classifieds
Also, I'm having a bit of trouble finding part numbers for Getrag parts in this thread, searching hasn't yielded good results. Can one of you kind fellows point me in the right direction? ![]() |
#566 (permalink) | |
#568 (permalink) |
Here is what I have for bearing sizes out of a 6 speed:
Intermediary shaft: 30209 front, 30208 rear Center diff assembly: 32010 front, not sure on rear Front diff pinion: 32009 x 2 Front diff case: 32008 x 2 No guarantee on the accuracy, I scribbled these numbers down a couple months ago ![]() And yb the way, only the 5 digits matter, the letters are just references used by different manufacturers, the numbers are the size of the bearing which is standardized accross manufacturers. |
#569 (permalink) |
Verified
I guess the only ones i'm unsure of are the VCU front and the counter shaft rear. I read the counter uses a 30208 & 30209, but in my pile of used bearings i don't have a 30208 but i do have a 30207. I'm assuming it came from the counter shaft rear, because the counter is the only part that uses bearings that start with "302..."
